50's Classic Tele (MIM) question
Just picked up a white one for a really nice price (seller advertised it as a MIM Standard, so I moved fast!).
I cleaned it up, gave it new strings and a setup, and it plays really nicely. Compared to my '94 52RI, it's a full pound lighter, neck feels every bit as nice, and I'm pretty sure the body is one piece (ash). It does have a slightly different timbre than the 52RI, but that may be because of the steel saddles (50's classic) vs. the brass saddles (52RI). Paid just over three bills for it - probably the nicest guitar I'll ever see for that price! Anyway, I do have a question and I'm wondering if this is common to all 50's Classics. In order to adjust the E/A saddle so that the action is acceptable, I had to adjust the height adjustment screw such that the top of the screw protrudes WAY above the saddle. Looks like it could be a real palm ripper if I hit it just so (I play hybrid style and mute with my palm at times). What can I do to remedy this? Can I get a shorter screw somewhere? Interestingly enough, my 52RI isn't like this. What gives? |
| Sponsored Links |
You bet you can get shorter screws. Any guitar shop could fix you up there and probably for free. The 50's classic has been on my wishlist for quite some time now. You are a lucky man to pick one up for that price. Enjoy. 8)
my personal remedy is:
measure from the surface of the bridge plate to the top of the saddle while the strings are in place, and the action is set as you prefer... then simply remove the screw and trim it to that length {taking care NOT to trim the adjustment side of the screw....i finish it up by rounding the trimmed end with a small file... result ? smooth palm muting surfaces ! |
great axes..
I just picked up a brand new '99 sunburst from a guy in Chicago for $360...it is my second one.
The screws are an easy fix.. buy em' , which is the easiest way..or just get out the old 6" Grinder and wire wheel. Knock off 1/4 inch and remove the burrs with the wire brush. I did this to the first one, same issue that you are having. Move the end of the scew into the grinder wheel very slowly..very slowly...hold it with a vise grips or something like it, do not damage the threads. You can protect the threads by putting several small nuts on the screw before grinding. WEAR SAFETY GLASSES !! PLEASE !!! Or do it like Terry's method above, just be careful, don't take some of your finger off. Before you re-assemble just make sure they are all about the same length or so... I did just replace the steel saddles on the new one with threaded brass saddles that I bought who knows when off of EBay, those came with shorter scews which I used. very fine guitar, I think one of the best Tele bargains on the planet, even at full price... by the way, most are 3 piece bodies, not 1 piece. good luck happy twanging t |
take 1 out,carry it to your local Hdwe store,get several of the same size just different lengths and get extras for when you do this again.I like the allen heads better than the slotted screws, they will refer to these at the Hdwe store as set screws and you will have a couple of dollars invested when your through
Great guitar for a great price.
Not a 1 piece body tho more like 3 pieces they hide the seams really good. The 50's and 60's Classics are my fav Teles.
I'm so blind my seeing eye dog needs glasses. |
Thanks for the replies!
I think I'll go the "buy" route for the shorter screws, great to know they can be gotten. I've been looking really really close and I sure don't see any seams in this thing. I can't imagine it could possibly be a one piece body for this price, but there is a grain pattern that starts near the left side of the lower bout, sweeps around under the bridge, and ends on the right side and I cannot for the life of me see where it is interrupted. But heck, if this thing were ten pieces I'd still be very happy with it. What strikes me is how much lighter it is than my 52RI. I'm hard pressed to see any appreciable differences between these two instruments. Let me qualify that by excluding pickups that would come stock - my 52RI has Bardens in it, and I have a custom Duff sitting here that I'll be putting into the MIM. One thing I'm not blown away by is the neck pickup in the 50's Classic - I still neeed to play with the height, but it sounds a bit too muddy and woofy on the low end. |
![]() Here is a 50's Classic stripped of most of its finish. MY 1st 50's Classic was 6.5 lbs my 2nd one was 7.5 my new 50's Classic Esquire is 6.3 lbs my 1988 52ri was 9.1 lbs.
#14 (permalink) | |||
#15 (permalink) | |
Re: stripped MIM
