Old October 19th, 2005, 03:41 PM   #1 (permalink)
Skully's Avatar
Finish Cracks In Neck Pocket
I just pulled my CIJ Pink Paisley out of the closet for the first time in about two months and noticed that were two identical finish cracks running about a half an inch out from the inside corners of the neck pocket on either side. I can't imagine what could've caused it, because it hasn't been out of the case, the case hasn't been moved, etc. Could changes in the weather have caused this?
Skully is offline   Reply With Quote
Old October 19th, 2005, 04:06 PM   #2 (permalink)
Mark Davis's Avatar
Usually caused by over torque on the neck screws but you didnt touch it so thats the only resonably explaination.
Do you live in an area with extreme temp changes?
Old October 19th, 2005, 04:10 PM   #3 (permalink)
Skully's Avatar
Not really. I live in Los Angeles. It gets very hot during the summer, but not particularly humid.
I wonder if I should find the appropriate color fingernail polish and fill in the cracks.
Old October 19th, 2005, 05:12 PM   #4 (permalink)
RichardL's Avatar
Re: Finish Cracks In Neck Pocket
Same thing happend to my 1998 CIJ '52 in the first month or two I had it. Nothing has changed in the 7 years since then.
RichardL is offline   Reply With Quote
Old October 19th, 2005, 06:18 PM   #5 (permalink)
Very common place for finish cracks. Most older poly Teles, such as from the 70s, have deep checks there. It's also a place where Tele bodies crack. It's simply an area that is stressed due to the neck attachment.
slack is offline   Reply With Quote
Old October 19th, 2005, 06:39 PM   #6 (permalink)
Skully's Avatar
That's what I want to hear. But, you know the story... The guitar was pristine and now... I have a MIJ Blue Flower that has several chunks missing from the finish. The cracks in the Paisley are only noticeable if you look very closely.
Old October 19th, 2005, 06:52 PM   #7 (permalink)
0le FUZZY's Avatar
  • If yer cracks are onlee these kind its purdy standard in our California cornditions.
  • If its li kiss won ri cheer yew may haff sum wood cracked dew tew makin them screws tew tite.(Where yew at Ian?)
  • In either kase there ain't tew much tew worry about.
  • Iffin it starts doin iss ri cheer yew gotta git it all off HEE! HEE!
    0le FUZZY
  • 0le FUZZY is offline   Reply With Quote
    Old October 19th, 2005, 09:40 PM   #8 (permalink)
    Mark Davis's Avatar
    Im in Bakersfield same basic weather conditions as LA and I have never had any cracks appear in any of my Teles or Strats.
    Old October 19th, 2005, 09:57 PM   #9 (permalink)
    0le FUZZY's Avatar
    Im in Bakersfield
  • 0le sweet thang lika jumped outta the PT Cruiser whence we passed them flower gardens that go for miles there North West of yew on hi-way 46 betwixt the cotton fields !
  • That waz a beautiful site.
  • Yew are lucky tew knott haff yer 70s TELECASTERs knott crack or craze. Yew muss haff good air cornditionin and humugidity control.
    0le FUZZY
    Oh BTW, I ain't never owned a car that dent hurt my back, legs er dairy-air after 10 anna haff hours drivin. The PT waz un-beleeb-bable.
    Old October 19th, 2005, 10:44 PM   #10 (permalink)
    Skully's Avatar
    Maybe the gods figure it was bad enough having to live in Bakersfield, you didn't need cracks in your teles, too.
    My first L.A. roommate was from Bakersfield. Other people from your neck of the woods (or arid desert) would marvel at his accent and tell him, "I'm from Bakersfield, too, and I don't talk like an Okie." He went on to play Bill Black in the short-lived "Elvis" TV series and now he has a semi-regular as a bartender on "General Hospital."
    Old October 19th, 2005, 11:07 PM   #11 (permalink)
    Bakersfield has a marine influenced Mediterranean climate? 8)
    Old October 20th, 2005, 05:03 PM   #12 (permalink)
    fndtele24's Avatar
    Those cracks are normal. They usually happen on guitars with aftermarket necks. What happens is the neck which is one type of wood and the body another type of wood react to humidity changes differently. the neck may swell up in the pocket causing the cracks. Nothing to worry about unless the crack gets bigger.
    fndtele24 is offline   Reply With Quote
    Old October 20th, 2005, 06:58 PM   #13 (permalink)
    TG
    TG's Avatar
    If it makes you feel any better, I noticed the same cracks on Steve Vai's JEM while watching the 'Live At The Astoria' DVD.
