Old October 2nd, 2005, 05:29 AM   #1 (permalink)
are there any Bigsby mods to make it easyer to change string
Its a pain
DavidMWerrick
Merricka is offline   Reply With Quote
Old October 2nd, 2005, 06:36 AM   #2 (permalink)
tjalla's Avatar
Pre-bend the ends
If you wrap the ball end of the string halfway around a pencil, it makes the string want to stay on as you string up
tjalla is offline   Reply With Quote
Old October 2nd, 2005, 07:38 AM   #3 (permalink)
TwinReverb's Avatar
I use a piece of cork that I have cut out so it will shove under the pin where you put on the string. The cork keeps it from slipping of. I also use the trick Tjalla describes.
good luck
Erik
TwinReverb is offline   Reply With Quote
Old October 2nd, 2005, 08:04 AM   #4 (permalink)
If you have a drill press you can do this.
Take your Bigsby apart--it quite easy.
Unscrew the pins from the bar.
Using the pin holes as pilots, drill out the bar all the way (6x).
Reassemble.
Now you string the Bigsby by inserting the string from the bridge side, wrap over and back to your pegs.
I had one somebody modified this way, and it was amazing. Don't know why Bigsby doesn't make them like this.
If you're not a machinist, then the cork/eraser method works well.
P.
Listen to your mother
Paul G. is offline   Reply With Quote
Old October 2nd, 2005, 10:13 AM   #5 (permalink)
jwells393's Avatar
TwinReverb has the right idea. The following is from the Bigsby website FAQs:
Re-Stringing the Bigsby Vibrato
1. Crimp the string at a 45 o angle next to the ball end (A).
2. Feed the string underneath, around and over the axle (B).
3. Place the ball end of the string onto the axle pin (C), keeping tension on the string to hold the ball in place.
4. Push a foam wedge (D) into the space under the axle to keep the string in place on the pin while winding.
5. Wind the string onto the tuning machine, tune to pitch and remove the foam wedge.
6. Repeat for each string
Old October 2nd, 2005, 11:37 AM   #6 (permalink)
Stringing a Bigsby
Try using a capo to hold the string in place once it's actually on the post. Then you have both hands free to complete the task.
Lotis is offline   Reply With Quote
Old October 2nd, 2005, 01:16 PM   #7 (permalink)
I use...
a pink eraser slid the opposite way of the foam wedge above. it works like a charm!
- Logan
I dont suffer from G.A.S., but my bank account does
Bring my Green Sauce Back
chago04 is offline   Reply With Quote
Old October 2nd, 2005, 03:25 PM   #8 (permalink)
Twangmeister's Avatar
I stumbled onto this thread....
and it was like manna from Heaven! I dread changing the strings on my Gretsch....you have all given me new hope!
"The man that hath no music in himself, nor is not mov'd with concord of sweet sounds, is fit for treasons, stratagems, and spoils."
http://www.myspace.com/jeremendelsohn
Twangmeister is offline   Reply With Quote
Old October 2nd, 2005, 05:01 PM   #9 (permalink)
Jef
Jef's Avatar
Reassemble.
That's what I use too. Works like a charm!
Jef
Amplification is not a social dinner, a literary event, a drawing or an embroidery; It cannot be done with elegance and courtesy. Amplification is an act of violence... (Mao Tse-Tube)
Jef is offline   Reply With Quote
Old October 2nd, 2005, 05:30 PM   #10 (permalink)
freshmattyp's Avatar
I use a capo at the 5th fret to hold the string in place. Works like a charm.
freshmattyp is offline   Reply With Quote
Old October 2nd, 2005, 05:54 PM   #11 (permalink)
Tele295's Avatar
Re: If you have a drill press you can do this.
Reassemble.
P.
Bigsby did make them with removeable pins for a while, it only took an Allen wrnech to get them out. It left a hole thropugh the bar the is more than adequate for the strings. My '68 F-Bigsby has these pins. I grab them whenever I can.
"Turn it up and it doesn't need any reverb." - Danny Gatton
www.dannygatton.info
Tiger Town Aces - Music That Bites Back
In Redd we trust!
Free Bill Kirchen!
If lawyers are disbarred and clergymen defrocked, doesn't it follow that electricians can be delighted, musicians denoted, cowboys deranged, models deposed, tree surgeons debarked, and dry cleaners depressed?
Tele295 is offline   Reply With Quote
Old October 2nd, 2005, 08:04 PM   #12 (permalink)
Capo to hold strings is a good tip, so is the foam/cork idea, my variant on that is to take a wooden clothes pin and break it in half (the long way at the closed end. You can wedge it to hold the ball end of string) (thanks to Mark Gamsjager of the Lustre Kings for the tip).
That & the capo make changing pretty easy. I also think locking tuners are a big plus/must w a Bigsby.
Cheers,
Jon
Jon C is offline   Reply With Quote
