tele with H/B in neck position
years ago I had a US Fat tele, which I foolishly sold...can anyone tell me if there is another mfg besides G&L who makes a tele, with that particular pickup configuration? Or, am i gonna have to try one of the custom builders? thanks in advance, emilio
Besides Fender(Squier, et. al) too?
If you don't want it to be telecaster in shape... yeah... If you want it in that telecaster shape... your choices are slim.. but, yes...
"Everyone's got to be something... Me? I'm stupid... It's all I ever wanted to be... Shock me again!" |
All of the Fender American Series and American Deluxe guitars are pre-routed for a humbucker underneath the pickguard.... a Lollar Imperial humbucker is one of the first mods for me with my Telecasters
I too had a US Fat Tele but mine was stolen. I got a 72 Custom RI and it has that same pickup config (Fender widerange hb in the neck, standard Tele in the bridge). Squier also still makes a "Fat Tele". Or as the others suggested, just pop a bucker in the pre-routed hole of any Tele and make your own "fattie".
#6 (permalink) | |
#9 (permalink) | ||
#10 (permalink) | |
I think that the current MIM 50s Classic is also routed for a 'bucker, so installing one just takes a new pickguard (or modifying your old one) and a pickup. |
#12 (permalink) | |
To those of you who've done this -- any other mods you make because of the humbucker? Like changing pots, caps, etc. |
Levinson Blade makes a fantastic tele with a neck humbucker. I belive it is the Delta Thin Line THD. F hole, VSC and coil tap. That model has been discontinued but every now and then one turns up for around a grand. Very much worth the wait, I have one and it is my #1 Tele, it's versitility is outstanding.
#14 (permalink) | ||
As far as caps, you usually see .022's for buckers and .047's for single coils. Again, no set rule. For my neck bucker, bridge single coil guitars, I use either a .033 or .047 cap with the 250K pots. I use the tone control a lot.....from just taking the edge off, to full on roll off when usuing overdrive for that wonderful "woman" tone. This is what works for me and may or may not work for you. Thankfully, pots and caps are an inexpensive and easy way to tweak your tone. |
#15 (permalink) | |
#16 (permalink) |
Yamaha makes the Mike Stern model as part of the Pacifica line of guitars. It is a Tele styled guitar and after some modifications is a great one. The neck has a Duncan 59 humbucker while the bridge has a Duncan hotrails HB p/u. Great sound and feel on the unfinished maple neck.
The bridge was absolute junk---I now have a Joe Barden bridge on there---and the frets were very rough and needed dressing. All in all, a first rate guitar after these adjustments. |
#17 (permalink) |
Build your own!
#19 (permalink) |
thanks again for all the suggestions and ideas...
Fatmanstratman, it may come down to your suggestion, I dont know, probably will just keep my eyes/ears open and look for a good deal, and then make the changes...btw, that is a cool looking tele you put together |
#20 (permalink) | |
I would suggest checking the wiring schematics for this guitar in the support section of Fender's web site (it's called the American Series Hot Rodded Fat Tele or something like that). They're available as downloadable PDF files. The setup they came up with in terms of the pot values, plus (if I recall correctly) an extra resistor in there somewhere seems to handle balancing out the two pickups very nicely. |
#21 (permalink) | |
Re: Build your own!
I've bought loads of the various types of GFS pups, both for myself and for friends who hear mine and want them for themselves! Every time they arrive, I marvel at the quality, drool over the sounds, then pinch myself when I see how cheap they are. The Vintage Split overdrives my Twin Reverb without trying; I fitted a GFS Hot TC Alnico (10k!!!) in the bridge, but rarely use it, as the neck pup is so juicy and raunchy. Additionally, the neck pup is very responsive to your picking - soft and sweet with a gentle touch, snappy and snarling if you dig in. Just how it should be. ![]() I can't recommend these highly enough - for so little money, just "buy one and try it"..... Thanks to all for the kind comments about my guitar - I really enjoyed building this one, and I have been rewarded with a beaut. |
#22 (permalink) |
what's your guy's experiences with how the two pickups combine in the middle pos.?
Isn't it sort of tricky to find a good pairing? I'm not talking about hum cancelling necessarily (a bonus), but can you still get a clucky chucka cluckster twang with botha dems? |
#23 (permalink) | |
Re: Build your own!
Or, it could just not be the sound I was looking for. Hard to tell; I find I'm pretty picky sometimes. (And not always in a good way.) |
#24 (permalink) | |
( using many different bucekrs and many different bridge pups ) with balance. They key is to use a fairly low output, PAF type pup in the neck I believe....at least thats what works for me....others experiences may be different. Anywa, I really dig the tone of a neck bucekr and bridge single coil mixed. |
#25 (permalink) | |
__________________ |
