Old July 7th, 2005, 05:26 PM   #1 (permalink)
I got a problem
:( I had a Bigsby on my Tele for a while and when I got it removed about a week ago, I put on some steel saddles and about the fourteenth to seventeenth fret or so on the E and B strings when you bend up past a whole it goes dead. I'm using 9's but I'm going to change back to 10's. Is there anyway I can fix this?
JParnell is offline   Reply With Quote
Old July 8th, 2005, 03:29 PM   #2 (permalink)
If no one's had a better idea
you might try adjusting the string height at the saddle. If that doesn't work, a small shim in the neck pocket towards the headstock end might.
Regards
Dave
There's no such thing as too much Tele!
Davey265 is offline   Reply With Quote
Old July 8th, 2005, 04:28 PM   #3 (permalink)
Rick S's Avatar
Often, when a Bigsby is installed, a shim is necessary toward the neck heel, opposite of what Dave described above. I would first remove the neck and see if there are any shims in place, and if so, remove them and see where you are at that point. Whatever it is, it's a setup problem and can be fixed, so be patient.
Rick S is offline   Reply With Quote
vB code is On
Forums Directory
