Old June 17th, 2005, 04:01 AM   #1 (permalink)
Bill  Hullett's Avatar
This Is Just Plain OUTSTANDING!!!!!!!!!!
I get the biggest charge in life when I see someone re~invent the wheel ...so to speak....ie: take a work~a~day product and create the "Dream" version of said product...
Thats exactly what Dale has done at Glendale guitars ...He took the problimatc three piece tele bridge and made it state of the art...not only does he angle the adjustment screws (like everyone else has started doing) he's taken it a step further to completion....Each saddle has a different angle !!!!! so the bridge has to be put on right (its clearly marked on the bottom of the bridge pieces) but the results are really stunning....
I'm able to play the dreaded "E"chord to "G" chord (as well as many others) all are in tune!!!!! The best part is they cost about $36 and IMHO they are worth twice as much!!!!!!!
Bill Hullett http://www.glendaleguitars.com
Bill  Hullett is offline   Reply With Quote
Old June 17th, 2005, 04:09 AM   #2 (permalink)
undafonk's Avatar
This may just be what I need for my MIM Esquire.
Thanks for the tip, Mr Hullet, I'll inquire with Glendale about availability.
undafonk is offline   Reply With Quote
Old June 17th, 2005, 08:15 AM   #3 (permalink)
Roel from Holland's Avatar
I received my set two weeks ago. The best saddles on the market I think.
Proost,
Roel
http://www.telecastergallery.com
Roel from Holland is offline   Reply With Quote
Old June 17th, 2005, 09:55 AM   #4 (permalink)
GuitarJonz's Avatar
which set?
Bill, I notice that he has a few different sets. The one he recommends is the Twang set, which has an aluminium saddle for te loe E and A. Did you get that, or the straight brass set? I notice he also has a Rockabilly set too. Who knew that choosing a set of saddles would get this complicated?? :D
Old June 17th, 2005, 10:25 AM   #5 (permalink)
GuitarJonz's Avatar
Re: which set?
Originally Posted by GuitarJonz
Bill, I notice that he has a few different sets. The one he recommends is the Twang set, which has an aluminium saddle for the low E and A. Did you get that, or the straight brass set? I notice he also has a Rockabilly set too, with steel for the low E/A. Who knew that choosing a set of saddles would get this complicated?? :D
Old June 17th, 2005, 11:12 AM   #6 (permalink)
0le FUZZY's Avatar
{no welds in the corners}
  • Shucks !! That means mine ain't no good?
    We are very close to having production bridge-plates
  • Why'd yew come in here lookin li kat ?
    If it doesn't sound good unplugged, it is not going to perform to it's potential electronically.
  • MMMMMMM !
  • Onlee way tew fine out iss tew fetch won when they git in purr-duck-shun I reckon.
  • Wunner iffin ats the same feller that drug iss here won in a few years back.
    0le FUZZY
  • 0le FUZZY is offline   Reply With Quote
    Old June 17th, 2005, 11:22 AM   #7 (permalink)
    Me Too!!
    I got some too! I got a set of each, and mixed two brass. and one alluminium on the E&A.
    They work perfectly. Not only are they accurate. The alluminium seems to sound a little less midrangey which helps a bit on low strings.
    I love em' !!!!
    Redd
    Redd Volkaert is offline   Reply With Quote
    Old June 17th, 2005, 11:32 AM   #8 (permalink)
    0le FUZZY's Avatar
  • I hate ta be a stick inna mud but years ago (20) I tried luminint rods fer poles and knott onlee did they turnt my palm black but they grooved from the string both whore-a-zon-tally as well as vertigo and sounded as flat as them crapite wonz.
  • These yew speak of muss be sum kinna luminint alloy HEE! HEE!
  • Like I say, the proof iss inna puddin.
  • Iffin Redd and Bill both like em I betcha we will tew.
    0le FUZZY
    Old June 17th, 2005, 11:38 AM   #9 (permalink)
    well actually.....
    I got a set of brass ones and aluminium ones...I've put the brass ones on one tele and I will try the aluminium on another this weekend...I don't know that I'd be in to mix and match, ( only because I'm so set in my ways!! ) but I very was curious about the aluminium too....they intonate percectly with a strobe....I mean they are really dead on.....I'm very excited about em!!!!!
    Bill Hullett
    PS hey Fuzzy....I think that Dale is using Billet aircraft Aluminium as opposed to just work a day stuff...its much stronger...the stuff they make hot rod wheels out of....
    Old June 17th, 2005, 12:07 PM   #10 (permalink)
    nasonm's Avatar
    I'll have to add them to my wish list...
    I love the idea of mixing and matching saddles!
    "i have learned to just grit my teeth, change the subject, consider their deep total ignorance, fondle the thumb picks in my pocket and go on my way" - bender-freak
    It's been lonely in the saddle since my horse died
    nasonm is offline   Reply With Quote
    Old June 17th, 2005, 12:40 PM   #11 (permalink)
    bpoe's Avatar
    I have the "twang" setup right now. The aluminum set on the E/A string really brightens the sound from those two strings, while keeping them bold. I was skeptical that there would be any difference between aluminum and brass, but there is a huge difference in tone.
    bpoe is offline   Reply With Quote
    Old June 17th, 2005, 12:55 PM   #12 (permalink)
    teleclarkster's Avatar
    I just installed a set of these on my guitar and really like the improvements. The Glendale saddles are very well made and the intonation is dead on! Also, Dale said that the bridge plates should be available in about 4 weeks.
    teleclarkster is offline   Reply With Quote
    Old June 17th, 2005, 02:44 PM   #13 (permalink)
    Geo
    Geo's Avatar
    Now this is cool. Lots of choices there.
    I'm leaning toward trying the stainless for a '62 RI.
    It has threaded steel now that seem to work well
    with the deeper sounding Texas Special pickups.
    So stainless looks like a go.
    I have brass (not his) on 2 others already but......
    may try some of the other Glendales later in place
    or.....or...... :?
    "Somewhere between culture and agriculture"
    Geo is offline   Reply With Quote
    Old June 17th, 2005, 02:45 PM   #14 (permalink)
    Geo
    Geo's Avatar
    Opps, musta been a chain reaction occurance.
    Old June 17th, 2005, 03:28 PM   #15 (permalink)
    Twangmeister's Avatar
    Awwwww, dudes..........
    Why'd ya have to go and do this? I was into year three of my love affair with Callaham bridges and saddles and now you parade this new, hot temptation in front of me!!!
    The "Twang Set?"!!!!!
    Must......not......give......in......to.....lure.. ...of.....greater........twangability.........
    "The man that hath no music in himself, nor is not mov'd with concord of sweet sounds, is fit for treasons, stratagems, and spoils."
    http://www.myspace.com/jeremendelsohn
    Twangmeister is offline   Reply With Quote
    Old June 17th, 2005, 04:15 PM   #16 (permalink)
    guitar_ed's Avatar
    When I get home, I will be getting some. Probably 2 pair. Oh well......
    Guitar Ed
    Piss off a politician, register to vote.
    When you complain about the government, remember that you ARE the government.
    Voting is the ultimate act of civil dis-obediance.
    AIM - guitar_edg
    Skype - guitar_edg (had to change on 5/16/06)
    guitar_ed is offline   Reply With Quote
    Old June 17th, 2005, 04:42 PM   #17 (permalink)
    well actually.....
    I forgot to mention that when I set the bridge up with the strobe , I would get it set for a given string and fully expecting to have to "cheat" a little when I checked the adjoining string.....In Each Case On All Three Saddles...The sister string was dead on perfect on the first pluck of the string....this is what floored me so bad....he has got these three angles DIALED IN!!!!!!! and then to sell them as reasonably as he does...well all I can say is THANK YOU DALE! and I hope he sells a million sets!!!!
    Bill Hullett
    Old June 17th, 2005, 04:51 PM   #18 (permalink)
    Scotland's Avatar
    Thanks Bill
    Just fired him a mail asking for shipping to Scotland. I'm going to try the Twang set, sounds like a perfect match for my perceived sound.
    Old June 18th, 2005, 03:38 AM   #19 (permalink)
    I've got a brass set
    ...which I'm hoping to install today.
    They look and feel extremely well made and I'm keen to try them on my Jimmy Bryant replica which has a Vintique bridge and the famous/infamous Vintique saddles. I've never been too happy with this set as the D/G seems to produce a real thing open G so I'm looking for an improvement in this area.
    Scotland, mine arrived in less than 5-working days, so Dale can turn them around very quickly.
    :D Peter
    PeterUK is offline   Reply With Quote
    Old June 18th, 2005, 05:26 AM   #20 (permalink)
    Scotland's Avatar
    Peter
    Ordered my Twang set last night, should be interesting.
    Old June 18th, 2005, 01:47 PM   #21 (permalink)
    Put To The Test....
    Well I used them last night , and really put them thru there paces in a real world senario...
    Let Me qualify this first by saying, half my life has been spent really trying to get a tele in tune great and keeping the three way bridge on it...and not to brag but I felt like I was really really good at doing this because I never got grief here in town on sessions etc etc...
    Last night , it was almost like I wasn't playing a tele....Every chord, every position, any wacky inversion , everything rang true as if I were playing the chords on a piano!!!! Because of the rich way that the chords ring, it feels like the guitar has more sustain. (its just the chords ringing clear as opposed to not) But I can easily say that its the biggest bang for buck investment I've EVER SEEN for a tele....(heck...its 1/2 as cheap as one normal aftermarket pickup)
    By the way.....I put the aluminium saddles on an Esquire and played that one also....I had the same great set up experience and they do sound different than the brass..I Like em as well.....but to my ears I think they made this Esquire sound more P~90 like....Which was very cool...I want to play the aluminium ones a little more though before I go saying too much about them tone wise, cause I just didn't play them as much as I did the brass ones....
    Dale is batting 1000 on these!!!!
    Bill Hullett
    Old June 18th, 2005, 03:46 PM   #22 (permalink)
    That's it then!
    I gotta get me some!
    If they're good enough for you Bill, and Redd as well, then they are well in excess of what I need, but I do need all the help I can get! :)
    Ron Garson is offline   Reply With Quote
    Old June 18th, 2005, 05:35 PM   #23 (permalink)
    JohnnyAtomic's Avatar
    i've had mine for over a month now and i think they're great. the machining is about the neatest i've ever seen. and i like the fact that the height screws are angled so they don't interfere w/ the bridge plate mounting screws, nobody else is doing that. the only minor thing i don't like is i like flat head height adjustment screws better than allen, oh well guess you can't have it all.
    he didn't even over a twang set when i ordered :evil: .
    oh well he's a good guy, guess i get to give him some more money
    i'm definitely getting more. i want stainless steel for B and Lil E for my bender. so i guess i want Aluminum, Brass and SS
    flaming hamper of rock!
    www.myspace.com/johnnyatomicmusic
    JohnnyAtomic is offline   Reply With Quote
    Old June 18th, 2005, 06:49 PM   #24 (permalink)
    BrianF's Avatar
    that might be the ticket
    Johnny ...that combination might just be THE ticket for B bender Teles..
    Old June 20th, 2005, 09:00 AM   #25 (permalink)
