Old June 16th, 2012, 07:48 PM   #1 (permalink)
Nashville
Are there many Nashville Tele player out there. I just picked one up and would like to hear how they are liked and any mods that have been done.
jgainer is offline   Reply With Quote
Old June 16th, 2012, 08:10 PM   #2 (permalink)
B-Bender
I picked up a B-bender in 1998 and took it to Joe Glaser and had it "Nashvilled"
I have two strats and a 335 dot, I play the tele every day. Its not a hard rock/metal guitar but everything else is covered.
Clinchriver is offline   Reply With Quote
Old June 16th, 2012, 08:18 PM   #3 (permalink)
boris bubbanov's Avatar
Well, on the MIM Deluxe Nashvilles, first thing I do is take off the 6 hammer bridge and saddles and substitute something like this:
Highway One plate, Callaham enhanced brass saddles.
Old June 16th, 2012, 09:08 PM   #4 (permalink)
I have a Nashville Power Tele that's about 10-11 years old. Right off I replaced the neck pickup with a Firebird-style mini HB and added a toggle to parallel in the bridge pu to get all possible combinations. Haven't done anything to it since (other than replacing 3 of the Fishman saddles whenever they suddenly go dead) but have been thinking about coil tapping the mini for awhile.
JeffTele is offline   Reply With Quote
Old June 16th, 2012, 09:38 PM   #5 (permalink)
I have a Gotah Bridge and saddles I thoughtr about putting on. The factory one seams pretty crappy
Old June 16th, 2012, 11:53 PM   #6 (permalink)
sjtalon's Avatar
+1 on the brass saddles and a p/p pot so you can have neck and bridge. That's a MUST !!
Old June 17th, 2012, 12:00 AM   #7 (permalink)
Sure. That might make it sound a little less twangy but that's a much, much better quality bridge and it should fit real easy.
Old June 17th, 2012, 02:05 AM   #8 (permalink)
Although it wasn't all that bad too begin with, I put on a 52RI bridge and saddles. In addition I replaced the pickups with DiMarzio virtual vintage tele set and a VV strat in the middle. No buzz or hum, even in less than ideal venues. Working man's guitar.
setlow is offline   Reply With Quote
Old June 17th, 2012, 06:54 AM   #9 (permalink)
Replaced the stock 5-way switch with a single wafer super switch.
Now the middle position is the neck/bridge combo instead of the middle pup. This is the same wiring as used in the B-Bender and the Burton Tele.
teleplayr is offline   Reply With Quote
Old June 17th, 2012, 08:02 AM   #10 (permalink)
That Burton switching sounds interesting. Where can I find the the wiring diagram for tha?/
Old June 17th, 2012, 08:11 AM   #11 (permalink)
motwang's Avatar
+1
motwang is online now   Reply With Quote
Old June 17th, 2012, 08:56 AM   #12 (permalink)
sjtalon's Avatar
note: you loose middle only
http://support.fender.com/service_di...8342C_SISD.pdf
and like teleplayr said, you need a Super Switch
Old June 18th, 2012, 07:02 PM   #13 (permalink)
I looked at the wilkenson plate with brass comp. saddles. Any good?
Old June 18th, 2012, 10:58 PM   #14 (permalink)
Make sure you get a "single" wafer super switch.
Using the typical super switch (it has two wafers) you'll have a difficult time getting it to fit in the cavity.
Old June 19th, 2012, 12:53 PM   #15 (permalink)
kubiakl's Avatar
I have the $30 Wilkinson compensated plate/saddle set up on my cheap Partsocaster and really like it. Before I went with Glendale for my new Highway One I did a lot of reading on bridge plates and saddles. Wilkinson gets quite a bit of love around here. Especially for the price - Callaham will set you back around $120, Glendale around $160.
It certainly sounds better than what came stock on the Highway One.
kubiakl is offline   Reply With Quote
