Old June 12th, 2012, 10:27 PM   #1 (permalink)
Tele Style guitar for fingerpicking
I am looking for a tele style guitar. I use a thumbpick and play a mixture of Atkins style,chicken picking and jazz. I am playing a 1960 es 330 now but would love to have a tele style guitar. On most of the tele style guitars i have played the strings are too close to the body for my style of playing. I did play a G&L tribute asat (the one with the G&L pickups that look like p-90s) that the strings are higher off the body (pretty sweet). I haven't found a JA 90 tele to try but it looks like the strings are higher off the body due to the bridge. Any suggestions. Is there a way to set up a standard style tele to get the strings higher off the body.
gripper is offline   Reply With Quote
Old June 12th, 2012, 11:29 PM   #2 (permalink)
I play same style, thumb pick all the time, and play several Tele's. I don't have a problem , BUT, you might try shimming the neck slightly, that will get the strings higher off the body, or thy a Tele with a fixed bridge(stoptail type), rather than ashtray style.
Jon
Twang Guitars is offline   Reply With Quote
Old June 13th, 2012, 11:33 AM   #3 (permalink)
You might want to check out Wendler guitars...
Stevie boy is offline   Reply With Quote
Old June 13th, 2012, 12:46 PM   #4 (permalink)
Quick search but couldn't find a website but I did run across this on a Wendler. http://www.youtube.com/watch?v=VkPPPGT0jqw
fredman is offline   Reply With Quote
Old June 13th, 2012, 12:48 PM   #5 (permalink)
Just ran into his site; http://www.electrocoustic.com/
Old June 13th, 2012, 12:59 PM   #6 (permalink)
Raising the bridge saddles and shimming the neck will get the strings higher off the body on any Tele style guitar. Simple and commonly done.
No trees were killed in the posting of this message, but a large number of electrons were terribly inconvenienced.
tpaul is offline   Reply With Quote
Old June 13th, 2012, 01:34 PM   #7 (permalink)
Phelonious Ponk's Avatar
I think you already answered your own question: ASAT. And personally, I don't think you could do much better than a Special for jazz. That big MFD pickup in the neck position makes a huge, warm, articulate sound that is perfect for fingerstyle jazz.
P
Phelonious Ponk is offline   Reply With Quote
Old June 13th, 2012, 01:42 PM   #8 (permalink)
RomanS's Avatar
Tele with a Bigsby B16 - that type of Bigsby requires a huge shim in the neck pocket, so the strings are as high above the body as on a hollowbody jazz-box.
Old June 13th, 2012, 02:16 PM   #9 (permalink)
jefrs's Avatar
I usually fingerpick but without the thumb pick.
I actually find the tele to be just about perfect spacing and not significantly narrower than the jazzbox or thin semi.
A ToM (jazzbox etc) usually has 52mm string spacing as are some teles but teles are mainly 54mm
Old June 13th, 2012, 02:56 PM   #10 (permalink)
JCW1024's Avatar
Godin Acousticaster?
http://www.godinguitars.com/godinacousticaster.htm
JCW1024 is offline   Reply With Quote
