Just received Squier Classic Vibe 50s Telecaster
New to the forum and first post!
I just bought a Squier Classic Vibe 50s Telecaster Vintage Blonde and to my disappointment, I'm having trouble dialing in a good distortion tone. I'm using a Hughes & Kettner 60DFX Amp (no pedals) and have the bass, mid, and treble pointing straight up (middle). Both knobs on the guitar at max and I played around with the Lead gain on the amp. I'm trying to get tone like the electric guitar in this song: http://www.youtube.com/watch?v=wLWUagrQVgo Did I buy the wrong guitar? Also tried all 3 settings on the guitar switch. Are there any particular uses for the 3 settings on the guitar switch or is it just based on your tonal preference? I am a beginner and play mostly power chords and some solos and am looking for a great tone (as I suspect most people here are). Would a Fender American Standard Strat sound significantly better than this? I don't know why I bought a Telecaster except that I have an Agile AL-3500 which is a Les Paul copy so I wanted to try something different. Maybe I should sell it and buy a strat? |
The guy in the video stated that he used a Seventh Heaven pedal into a Bogner amp. Your guitar is fine. Just get a decent gain pedal. You'll have to adjust some settings, but I wouldn't keep buying a new guitar to suit the song. Just play it and make it work. Those are some good guitars.
Tele's aren't as often associated with overdriven or distorted tones a Les Paul but they're certainly capable of doing it. You may need to use more gain and drive the amp harder to get it.
The guy in the video also has the benefit of using a pedal to create his tone where you aren't using one. That alone will make a huge difference. You get about the same results with a Strat. Humbuckers are a more powerful pickup than single couls but you can still get plenty of juice for distortion from them.
CS 51 Nocaster, "Nashcaster"/Nocasters, MIM Nashville/Onamacs, Squier CVC/Keystones, CV 60's J Bass/Wilde J45s, Matt Freeman PBass/Wilde P46, Taylor 414CE/Fishman Blender, Roland Cube 40xl, Bugera v5/820H, Roland BC 60/CRex, tc electronic BG250 Bass Combo. |
#4 (permalink) | |
I think you bought a very nice guitar, I have one, but it's not the same. You might be able to change pups, add a Humbucker to it. I would keep it and buy a different guitar more similar to his. You should be able to get that tone with your LP copy. He isn't playing a regular single coil Strat tone. I'm usre others with more knowledge will chime in with a better suggestion. Good luck.
Just call me Crow |
I have a CV50, and it's my favorite guitar. I put Dimarzios in it and it made a huge difference. Plenty of distortion! IMO you should keep yours... it's one of the best bangs for the buck out there.
rocknteacher |
The guy in the vid looks like he is playing a Strat with a humbucker in the bridge.
Thats gonna sound way different from a Tele.
I'm so blind my seeing eye dog needs glasses. |
Keep experimenting,find your own tone----------you have a real nice guitar!
http://www.soundclick.com/bands/0/refin_music.htm MASTER VOLUME? WHAT'S A MASTER VOLUME? |
Thanks for all of the replies. Maybe I did buy the wrong guitar since Teles aren't as often associated with overdriven or distorted tones.
I was hoping to avoid using a pedal, but it sounds like I might not be able to get the overdrive that I'm looking for from the amp and guitar alone. Perhaps I can change my amp to a decent modeling amp? All I want is the correct guitar and correct amp. I'm willing to sell everything I currently have! I'm also willing to spend more money. |
find the right amp for your purpose - this clip is a tele with low output Don Mare pickups, no pedal, through a Risson amp's high gain channel. might not be exactly what you are after - but it does serve to point out how much a factor the amp is. the same guitar through different amps sounds ... like a different guitar
http://www.myspace.com/gmothmusic/mu...-bass-82030258 |
#11 (permalink) | |
edit here: I just listened to your amp on youtube, you shouldn't have any issues with distortion, very nice amp.. These CV's are great bang for the buck. But maybe you want a guitar with Humbuckers in it. There are plenty of'em. Good luck. I just bought a very nice Epiphone ES-339 semi hollow body with humbuckers, that guitar will tear it up..lol. I love it.
Just call me Crow |
A lot of good advice here. I think the best thing you can do is research. Find out what kinds of guitars, effects, and amps are being used by the bands you want to sound like. Then look into getting similar gear.
I can attest to the amp making a huge difference. When i play my American Special tele through my Fender Hot Rod Deluxe III amp, the overdrive channel, or my drive pedals don't quite give me that fat chunky tone that is needed for metal. But when i plug the same guitar into my Fender Princeton Stereo Chorus amp, and use the drive channel, i can comfortably play All Guns Blazing by Judas Priest :) Research and experimenting are the best things you can do. and enjoy any little happy accidents you may discover along the way. wish you the best! p.s. I just ordered a butterscotch blonde CV50 a couple hours ago. I'm sad that i waited till the end of the week, now i have to be anxious all weekend long! :) |
#13 (permalink) | |
Just call me Crow |
#16 (permalink) |
If the guy is playing with a humbucker in the video and you have a guitar with humbuckers...you should probably use a guitar with single coils to duplicate his sound.
2010 Squier Classic Vibe Telecaster '50s |
#17 (permalink) |
Turn down your guitar's Tone knob to about 3 or 4 on the bridge pickup position and go from there. I promise you will get the results you are looking for.
"So I says to Mable, 'Mable', I says...." |
#18 (permalink) |
From another thread, but appropriate:
“Everything we hear is an opinion, not a fact. Everything we see is a perspective, not the truth.” -Marcus Aurelius AD 121-180 "There is no charge for awesomness, or attractiveness." Kung Fu Panda AD 2009-2010 |
#19 (permalink) |
here's a CV Tele getting some good medium-high gain going on (with an overdrive pedal) at about 3 minutes in:
Teles are great for overdrive/gain, it's just a different quality of gain than a humbucker will give you. |
#20 (permalink) | |
![]() Since when?
Put a glide in your stride and a dip in your hip and get onboard the Mothership. |
