Old May 10th, 2012, 07:21 PM   #1 (permalink)
malonius's Avatar
Switch tip coming loose...
My plastic switch tip is loose on my Tele. Every time I switch pickups I can feel it loose and it's driving me nuts....
Apart from glueing it, does any body have any quick-fix solutions?
malonius is offline   Reply With Quote
Old May 10th, 2012, 07:25 PM   #2 (permalink)
sacizob's Avatar
Krazy glue! You can still get the tip off if you have to.
Buddy Holly Lives!
sacizob is offline   Reply With Quote
Old May 10th, 2012, 07:38 PM   #3 (permalink)
tap4154's Avatar
One drop of super glue will work, but what I did on my 3 Teles was cut a tiny strip of masking tape and fold it over the top of metal tip, then push the barrel tip on. Holds great.
tap4154 is online now   Reply With Quote
Old May 10th, 2012, 07:43 PM   #4 (permalink)
telex76's Avatar
Here is a good thread on that subject with every kind of fix.
http://www.tdpri.com/forum/telecaste...falls-off.html
telex76 is offline   Reply With Quote
Old May 10th, 2012, 11:53 PM   #5 (permalink)
rp1138's Avatar
Another option is simple Elmer's glue. I used it on my Tele when I was replacing the switch tip, and the new tip was just a little too big. I put the glue into the slot of the tip and then put it on the switch. The tackiness of the glue held the tip in place long enough for the glue to fill up the empty spaces and dry. I can take the tip off and put it back on, and it stays in place.
2011 Gretsch G5120
2009 Agile AL-2000 Bird TSB
2006 Fender Classic 50's Stratocaster (My #1)
1998 Epiphone EJ-200
rp1138 is offline   Reply With Quote
Old May 11th, 2012, 05:09 AM   #6 (permalink)
Phatius's Avatar
no need for glue. I had a problem with an mij Tele before when I switched out the switch.
Just put a small strip of electrical tape on the tip on the switch. the put the switch tip back on and it should be snug.
Phatius is offline   Reply With Quote
Old May 11th, 2012, 06:19 AM   #7 (permalink)
kraigeyroxx's Avatar
+1
I did this to my Baja and its been snug ever since
kraigeyroxx is offline   Reply With Quote
Old May 11th, 2012, 06:54 AM   #8 (permalink)
Elmer's glue for me although the tape sounds like a good idea.
Jim W is offline   Reply With Quote
Old May 11th, 2012, 07:30 AM   #9 (permalink)
electrablue's Avatar
+1
electrablue is offline   Reply With Quote
Old May 11th, 2012, 07:40 AM   #10 (permalink)
Your tip is probably broken if the problem didn't occur when the tip was originally fitted.
I have a bag of tips in my guitar case because they break so often.
I used to just wrap some electrical tape around the switch to get a snugger fit, but eventually the tips always fail.
imsilly is offline   Reply With Quote
Old May 12th, 2012, 01:00 AM   #11 (permalink)
A drop of solder on the side/sides of the switch works great and is permanent.
Jasorino is offline   Reply With Quote
Old May 12th, 2012, 01:16 AM   #12 (permalink)
Bunnion's Avatar
Another one here who wraps a small bit of masking tape around the switch tip. Although I've been kinda digging the look of a strat tip on there and they seem to hold just fine stock.
Bunnion is offline   Reply With Quote
Old May 12th, 2012, 04:21 AM   #13 (permalink)
malonius's Avatar
Thanks everybody. Gonna try the masking tape 1st, then may resort to glue...!
Old May 12th, 2012, 04:24 AM   #14 (permalink)
Or you could buy a shiny brand new one for not a lot :)
notdave is offline   Reply With Quote
