Anyone NOT like the Fezz Parka mod?
I just Fezz'd my Baja yesterday while installing a PIO cap and honestly, I'm not a big fan.
I don't like losing volume when I'm trying to just bleed off highs. Also feel like the cleans aren't as defined as they used to be (especially out of phase). At this rate I'm going to switch back in a couple days. Am I missing something? I've always heard about the brilliance of this mod, but I'm really unimpressed so far.
'11 Fender Baja Tele • '11 Fender American Standard Tele • '10 Jackson SL1 • '06 Ibanez AS83 • '01 Gibson SG • '00 Ampeg AMG-1 • '99 Fender American Lone Star Strat • '97 Gibson Les Paul Studio • '96 Larrivee D-03 Acoustic • '95 Fender Tex-Mex Strat |
To each his own. I use it on some guitars, and it works. It's hard to tell what happened to your tone, though, when you change two things at once. That control plate on Telelcasters is great for experimenters because you can easily change things one at a time without taking strings off, etc. like many other guitars.
Yet another hobby that is completely out of control... |
Personally, I really like it and I didn't see any loss of tone at all.
Maker of some finely crafted, twangy redneck noise...http://www.reverbnation.com/goatwhiskey |
I have no problem with people liking this mod, but it ain't for me.
I don't like the tone/volume snake-dance it does. With the parts and wiring I use, I hear very little tone drop-off with rotation of the volume control when I use the standard tone control wiring. To each their own!
"Everything is a tone control" -donh- |
I did this to my Baja a few weeks back. Overall, I like what it does when driving tube amps, and can see it being very useful for drive tones it seemed to push them harder with a more aggressive and tight feel/tone. I also dig the slight bit of mid scoop that happens as the tone is backed off.
I did not like what it did for cleans. They seemed thinner less woody. If I back off the tone and volume a bit I can get close to the stock tones, its certainly passable. What Ive decided to do in keeping with the spirit of the Baja tele, is to make the Fezz Parka mod switchable with stock wiring. So I will be installing a Push/Pull pot, to switch back and forth as I see fit. Additionally the P/P pot will be modded to be no-load. |
With respect and high regard to Fezz, this is an OLD wiring standard. Actually Gibson was using it probably before or near 'bout when Fezz was born. It places the tone pot and capacitor in series across the output jack (in parallel) instead of placing the damn volume and tone pot in series which results in some weird losses of tone AND volume when turning EITHER.
I had 1 meg pots that were not audio taper on my thinline and threw them in the garbage because nothing happened until they were near end range. Changing the pots to 250K with an audio taper along with the "Fezz" mod turned everything upside down and into a new world. A beautiful world. Of course the keystones, with their bell-like clarity aided that quite a bit as well. All this was done at the suggestion of the good people here. If you have excessive ice pick brightness that you can't stand..........and the tone pot and knobs on your amp produce mud on the neck pickup.......do what I did. You'll be urinating in your pants with glee when it's all over and done. |
#13 (permalink) | |
Thanks for not being "mad" at me Fezz
I just feel like I'm missing something because this is generally so praised and consensus opinions on this forum have rarely led me astray on my adventure into the wonderful world of Telecasters Here are simple schematics for two versions that I've seen come across the forum. I did the one with the additional wire added because I was almost finished replacing the cap with the new PIO one when I remembered that I wanted to try the mod Fezz Parka v1: Fezz Parka v2: Quote:
#14 (permalink) |
Go here. Scroll down to '50s Vintage Wiring. In Anne's Opinion, all guitars should be wired this way. I am probably one of the few here that detest the bridge pickup. I have my keystone neck UP and the bridge PU sharply angled LOW for the B and E (high end) strings. I use the middle position (of the switch) to "change the sound". KY
http://www.premierguitar.com/Magazin...Mod_Guide.aspx |
#16 (permalink) | |
Wire the tone circuit to output of the volume pot, not the input. The signal "sees" the volume pot first and the tone circuit only affects the signal present right before it goes to your output jack. Alligator clips!!! I've used them in a/b'ing tons of wiring schemes and listening to differences in pot values, no load tone circuits, caps, etc. This has been invaluable in dialing in all of my guitars without going crazy buying/selling pickups and even guitars like a mad man. |
#17 (permalink) |
If you are of the inquisitive type
Here is a summary: Treble bleed summary 1. No treble bleed - treble loss when you back off the volume. 2. Simple cap only treble bleed - excessive high end and tinny sound. 3. Parallel treble bleed with proper cap and resistor values - preserves the tone best. 4. Fezz Parka mod - preserves treble well, changes volume pot action and changes the effect of the tone knob in a creative way. ---------------------
Felwark - the band I play in |
#18 (permalink) |
I tried it once and didn't really dig it..that was with Kinman noiseless pickups though, so that may have had something to do with it. Will have to try it again on a single coil guitar
#20 (permalink) |
I did it this weekend and it did not work for me, all it did was render the tone pot inactive.
However, when I was putting it back I noticed that my wiring was completely non-standard and that some other treble bleed mod had been done before. It took me a while of researching through schematics on the internet but this probably explains why I liked how my neck pup sounded already |
