Old March 24th, 2012, 03:24 PM   #1 (permalink)
Cheapest telecaster bodies?
Who's got the cheapest tele bodies? So far looks like allparts, but even they seem a little steep; $60 for a '2nd quality' body? All I need is an alder plank to wail on
mike is here is offline   Reply With Quote
Old March 24th, 2012, 03:48 PM   #2 (permalink)
Have you looked at Guitar Fetish? Bodies start at $49.95.
In case you're interested: http://www.guitarfetish.com/Tele-Style-Bodies_c_71.html
"Just once I'd like to hear you scream in pain"
"Play some RAP music"
TeleTim911 is offline   Reply With Quote
Old March 24th, 2012, 03:50 PM   #3 (permalink)
Prison Rodeo's Avatar
Better yet: Get a body from GuitarFetish's "Clearance" section. Occasionally they pop up for under $30.
"Remember, all you need are three chords and a good piece of wood."
-- Jeff of Honey Stump
Prison Rodeo is offline   Reply With Quote
Old March 24th, 2012, 05:14 PM   #4 (permalink)
Jim Dep's Avatar
Rondo has a couple used tele and strat bodies for cheap...under their "parts" section I think
Jim Dep is offline   Reply With Quote
Old March 24th, 2012, 05:18 PM   #5 (permalink)
...or buy the whole dang guitar for $99-ish and pitch what you don't need.
trailboss is offline   Reply With Quote
Old March 24th, 2012, 06:10 PM   #6 (permalink)
awesome, i knew i had seen guitarfetish before but i couldnt remember what it was called.
anyone know if rondo tele bodies are made to fender specs?
Old March 24th, 2012, 06:24 PM   #7 (permalink)
I tried putting together a Tele with one of the Guitar Fetish bodies I got about a week ago. The body looks great and is extremely light. The finish (Surf Green) was much better than expected.
The problem I had that made the body unusable is that the string holes were drilled at an angle. When I mounted a bridge to line up with the spring holes, the bridge was at an angle to the neck. Besides looking crooked in comparison to the pickguard, I could not get the guitar to intonate properly because the bridge was angled.
In addition, the routing for the neck pickup was so close to the neck pocket that on of the screws for the pickguard was right on the edge of the pickup route and could not be used. Finally, the neck pocket was too wide for a neck from Fender MIM Standard Tele and a Mighty Mite neck.
I've been a big fan of GFS pickups and other parts over the years. This was my first try with one of their bodies and based on this experience, i'd say it will be my last.
As for Rondo, the bodies and necks are a bit difference in size and dimension from Fender Teles -- and even among themselves. I bought a Furrian last year and liked it so much, I bought another one two month ago. On the new one, the pickup hole in the pickguard is too small for Fender neck pickups and the body shape is just different enough that Fender pickguards won't work. I tried other pickguards I got from Rondo and they are not the correct size either.
So, if you're looking for a cheap body, be careful.
Jim
jwsamuel is offline   Reply With Quote
Old March 24th, 2012, 06:25 PM   #8 (permalink)
None are made totally to Fender specs. The parts that fit vary among Rondo guitars. Fender parts may fit but don't count on it. And as I said in my other message, parts are not always interchangeable among Rondo's SX guitars. You can have two of the same model guitar and parts don't exchange.
Jim
Old March 24th, 2012, 06:26 PM   #9 (permalink)
fendrguitplayr's Avatar
No, they are not.
A goal without a plan is just a wish...
fendrguitplayr is offline   Reply With Quote
Old March 24th, 2012, 06:27 PM   #10 (permalink)
glen smith's Avatar
Jim
Was the GFS body from their "clearance" section?
glen smith is offline   Reply With Quote
Old March 24th, 2012, 06:27 PM   #11 (permalink)
No.
Jim
Old March 24th, 2012, 06:30 PM   #12 (permalink)
Super Moderator
Tim Armstrong's Avatar
If the string holes were hidden under the bridge, I'd just drill new ones. Or maybe go with a toploader.
Tim
Old March 24th, 2012, 08:53 PM   #13 (permalink)
HOBBSTER01's Avatar
I currently have the same problem with string holes.
I re-drilled mine from the top side and corrected the problem.
Wasn't pretty but it worked.
The Hobbster
"If you know "how" to play, a Peavey Bandit is all you need."
HOBBSTER01 is offline   Reply With Quote
Old March 24th, 2012, 11:33 PM   #14 (permalink)
I just got a body from USACG. Probably one of the most expensive out there. I have done the cheap route. It is hit and miss and after all the time spent making things right I am at a point where the money up front on a quality product makes for a better investment.
If you want to do some finish routing Guitar Mill has some specials right now.
onenotetom is offline   Reply With Quote
Old March 25th, 2012, 08:13 AM   #15 (permalink)
I'm not sure what I am going to do with the body. The problem is that I did not realize the holes were not drilled correctly until after I drilled the four holes to mount the bridge. So, I'll have to plug those holes first.
The big lesson is that cheap often creates a lot of extra work to achieve a result that is far from perfect.
Jim
Old March 25th, 2012, 08:22 AM   #16 (permalink)
Jim
I would fit a Wilkingson bridge .It has top loader and string through .The paulowonia wood resonates well with either .my strat body is oK .maybe just lucky
You have to be very carefule of cheap bodies .I have a great paulowonia body on my parts caster but no idea who made it .it ended up costing me 16 quid on Ebay but its very easy to damage which is great .who cares, its cheap as chips
musicalmartin is offline   Reply With Quote
Old March 25th, 2012, 09:40 AM   #17 (permalink)
HOBBSTER01's Avatar
Jim
PM me. I'll buy it.
The Hobbster
Old March 25th, 2012, 02:29 PM   #18 (permalink)
That's what I was mounting. The problem, as I said in another post, is that I already mounted the bridge by lining it up with the string through holes. That means the bridge is mounted at a slant to the neck.
Also, buying a body that is already drilled for string hole and then mounting a top loading bridge leaves holes in the backside of the body.
Jim
Old March 25th, 2012, 03:38 PM   #19 (permalink)
Is there any bodies out there that are made to Fender specs? I dont' want to spend any time or doing any extra work re drilling holes ect...I want to just mount a Fender Neck..or a fender pickguard and bridge and it lines up....simple..... I basically would like to be able to replace the body on my MIM for a different color if someday I wanted to....Which ones are Fender spec?
paulswifka is offline   Reply With Quote
Old March 25th, 2012, 03:44 PM   #20 (permalink)
USACG http://www.usacustomguitars.com/, Musikraft http://www.musikraft.com/, Warmoth http://www.warmoth.com/, and MJT http://mjtagedfinishes.com all sell bodies that will bolt on correctly to a Fender spec neck. There may be others.
