Old March 21st, 2012, 12:21 AM   #1 (permalink)
Night Prowler's Avatar
Why do only some Tele's come with a HB route in the neck position?
It would seem to me that ALL Tele's should have a humbucker route in the neck position. I mean its not like you can't still have a single coil pup mounted in the humbucker route. But if you want to install a HB pup and your Tele doesn't have the route for it, then you're SOL unless you want to go at it yourself with routing the body. So is there a specific reason why only some Tele's have a HB route?
Night Prowler is offline   Reply With Quote
Old March 21st, 2012, 12:46 AM   #2 (permalink)
If it was routed for humbuckers all the time, the neck PU would have to be screwed into the pickguard or it would fall in & many prefer their teles without those screws .. i assume .
Corduroy Pillow just made headlines .
Finnlozada is offline   Reply With Quote
Old March 21st, 2012, 12:57 AM   #3 (permalink)
androo's Avatar
Nope. Humbucker routed Teles most certainly do not require pickguard mounted neck pickups. They mount the same as a non-routed neck pup, just in the bigger route.
I'd guess it was because the original design was for single coils, and the HB route came along as a modification, most likely just like the OP said, folks went at it themselves. And then Fender followed the advice of the players. That's my guess.
Take a listen to...Gravy
androo is offline   Reply With Quote
Old March 21st, 2012, 04:05 PM   #4 (permalink)
I'm wondering if it would affect the sound at all by installing a single coil pup in the neck position that has a humbucker route.
I can't imagine it would but perhaps I'm wrong. If not then I really can't understand why all modern Teles don't come with a HB route in the neck position.
Old March 21st, 2012, 04:12 PM   #5 (permalink)
Bartholomew3's Avatar
I just put back my 68 tele pickups. It was cut for a humbucker way back and I had a D'Imarzio PAF put in.
The original neck pickup screws right down into the wood, I even kept the original screws and I don't think enlarging the cavity made any difference to the sound.
If it did I can't hear it.
Bartholomew3 is offline   Reply With Quote
Old March 21st, 2012, 04:13 PM   #6 (permalink)
KevinB's Avatar
Why stop there?
Hands up all those who want a swimming pool route so they can mount anything, anywhere.
No-one?
Typically, vintage style Teles don't have the HB route simply because the guitars they are based on didn't have an HB route: Classic 50's, 60's US RIs, etc.
KevinB is online now   Reply With Quote
Old March 21st, 2012, 04:25 PM   #7 (permalink)
5am5's Avatar
if you did that, it would remove choice and mean that you couldn't remove the pickguard and have yourself a cool guitar like this
5am5 is offline   Reply With Quote
Old March 21st, 2012, 09:48 PM   #8 (permalink)
tele-bastard's Avatar
Mexican Telecasters are routed for humbuckers... American Telecasters are not.
There is nothing like a nice piece of Ash!
http://reverbnation.com/downwithugly
tele-bastard is offline   Reply With Quote
Old March 22nd, 2012, 02:28 AM   #9 (permalink)
stilesg57's Avatar
Not exactly.
Actually it depends on model, not place of manufacture.
My Baja is MIM but has a standard single-coil route in the neck position. My MIA American Standard, however, has a humbucker route in the neck and a single-coil route in the middle:
'11 Fender Baja Tele • '11 Fender American Standard Tele • '10 Jackson SL1 • '06 Ibanez AS83 • '01 Gibson SG • '00 Ampeg AMG-1 • '99 Fender American Lone Star Strat • '97 Gibson Les Paul Studio • '96 Larrivee D-03 Acoustic • '95 Fender Tex-Mex Strat
stilesg57 is offline   Reply With Quote
Old May 22nd, 2012, 06:17 AM   #10 (permalink)
What's the extra hole for?
Keep Dreaming :-)
free2rock is offline   Reply With Quote
Old May 22nd, 2012, 06:34 AM   #11 (permalink)
Scotty 2's Avatar
The x-tra hole is to keep your picks and your tips in
And the Tele said; Why is everybody always pickin on me
Scotty 2 is offline   Reply With Quote
Old May 22nd, 2012, 11:00 AM   #12 (permalink)
And guess what? The humbucker rout in my 2008 American Standard is too shallow to fit a Gibson Classic 57.
"Life is mostly Froth and Bubble" Adam Lindsay Gordon
chezdeluxe is offline   Reply With Quote
Old May 22nd, 2012, 11:42 AM   #13 (permalink)
This happens not to be the case. The American Deluxe and American Standard Teles, at least, are routed for a humbucker at the neck and for a single Strat-type pickup in the middle, along with the usual Tele pickup at the bridge.
dconeill is offline   Reply With Quote
Old May 22nd, 2012, 12:00 PM   #14 (permalink)
waparker4's Avatar
What bodies are routed for a single coil currently that aren't reissues or vintage-styled (classic player series)?
Mex Std., Am Std., Am Del., Am Special all HB routed.
I don't personally care, unless I plan to do a HB build, or I plan to go no-pickguard.
waparker4 is offline   Reply With Quote
Old May 22nd, 2012, 12:09 PM   #15 (permalink)
pondcaster's Avatar
FWIW, both my CVC and my CV50 BSB have HB routes in neck position... none of my old MIMs or MIAs ever did.
pondcaster is online now   Reply With Quote
Old May 22nd, 2012, 03:55 PM   #16 (permalink)
Because some people like to burn in hell
StratBluesRock is offline   Reply With Quote
Old May 22nd, 2012, 04:14 PM   #17 (permalink)
73Telecaster's Avatar
Its a ceremonial spirit box. You put your weed in here!
I wasn't looking too good, but I was feeling real well...
73Telecaster is offline   Reply With Quote
Old May 22nd, 2012, 04:34 PM   #18 (permalink)
Fresh's Avatar
It is for ease of manufacturing, if you work at fender you
1. Pick up a body
2. Pick up a loaded pick guard
3. Insert pick guard into body.
4. Move guitar along the assembly line
5. Start process all over again.
It does not matter, the body or the loaded pick guard they fit. Of course, this is just an educated guess on my part. Nevertheless, if you ask me I am right again as usual :) LOL
Rock & Roll is just Rock & Roll!!
Fresh is offline   Reply With Quote
Old May 22nd, 2012, 06:46 PM   #19 (permalink)
telex76's Avatar
If I don't have a Humbucker, then I don't want a humbucker route.
I sure don't want a swimming pool route.
I cut my own pup route for the humbucker in my Nocaster. No problem.
telex76 is online now   Reply With Quote
Old May 22nd, 2012, 06:56 PM   #20 (permalink)
Lenderman_k's Avatar
I have been wondering this for awhile now. Especially since the other day when I discovered my AM STD has the HB route.
"Last of the Hardcore Troubadours"
Lenderman_k is offline   Reply With Quote
