I tried; you can do it with the neck pup, rolled off a bit, and as much reverb as you think you can handle. Then, work on bending the neck for a trem effect.
OR... do what I'm doing right now and build your own. A Dano lipstick in the bridge and a Bigsby ought to cover it, or at least I hope so.
M Dixon Reading, MA |
I'm sure the idea of a catch-all 'surf guitar' is a sort of retroactive idea. The Ventures sound nothing like Dick Dale who sounds nothing like the Atlantics etc... I guess generally you want to combine a low-sustaining guitar with a hot pickup so you get a quacking sort of sound that is strong enough to make reverb springs go 'boing boing' when you palm mute.
It's called effects people...Studio recordings used Studio effects ..such as Reverb ..delay..some tremolo..etc...
Tommy Tedesco was probably the real king of Surf and everything else guitar that was such a hit in the 60s...yes..he used a Tele Me and my Tele for a Surf Classic With me Jazzmaster |
#5 (permalink) | |
#6 (permalink) | |
I wouldn't just use the middle pos. why limit yourself?
I play in a surfy sounding band with a tele. Game on. |
#10 (permalink) | |
So true, they have the mids to help them cut also. Im amazed they arent used more around here-when I see surf bands its all strats, jags, and the occasional jazzmaster. Yes they have trems-but so can teles, and many songs dont need a trem.
Ditch the front pickup, use a solid state Peavey amp and a Line 6 Verbzilla...set for "OCTO" and Echo! HA!!
(These poor guys had no idea what I was going to do at the beginning...neither did I.)
I play an Esquire because I can't afford the other pickup. |
Using your mid position (bridge and neck pups) can give you a fairly close Fender Jaguar-ish sound. Of course, everybody is right on with their advice...experiment, don't limit yourself. The Ventures' Nokie Edwards and Gerry McGee have been playing surfy tunes using Tele's and Strats for decades, and Setzer can get some great surf tones with a big 'ol 6120!
#14 (permalink) | |
The trick is big amp, big speakers, big reverb box, big room...like the Showman setup above |
#18 (permalink) |
+3 on the sound.
That's a jazzmaster. The jags sexier sister. |
#19 (permalink) |
Everything that has been mentioned already works, but after reading over at www.surfguitar101.com I think that another tip to the sound is to use thick strings, like .11s at an absolute minimum. Some of those guys over there are using .13s or .14s!
#20 (permalink) |
And on a Vox VT30 to get a surf sound with a Squier Tele I do the following
Guitar: Volume on 10, Tone on 5, middle position (no mods to this guitar yet, these settings will change when I add Fezz Parka mod and Tex Mex bridge) Amp: Tweed 4x10, Reverb on stun, Gain @ 1 o'clock, Volume at 10, Treble at 12 o'clock, Middle cranked, Bass cranked. Master volume doesn't matter but it sounds better as you get louder |
