Old April 18th, 2005, 01:01 AM   #1 (permalink)
Creating an absolute Blues machine
Ok, opinion poll time. I have a Nashville Tele which I have just posted questions about the pup wiring, and by the way thanks to all that took the time to answer.
Here's my question,
#1. If you wanted a blues machine would you stay with the nashville 3 pups or would you go the the standard 2 pup layout?
#2. What pups would you use and why?
Thanks in advance for any answer's, I sure do appreaciate all your help with the wiring answers.
DR
hmx1 is offline   Reply With Quote
Old April 18th, 2005, 01:25 AM   #2 (permalink)
SteveY's Avatar
I seem to wind up using the neck pickup generally, unless I'm doin' the Roy Buchanan stab-a-few-notes-to-death-thing, in which case it's the bridge.
I use a standard '52 RI and like the Fender Vintage pickups that come with.
The Fender Custom Shop Texas Specials are cool too. I like their rawness and oomph.
I'd stay away from SD Nashville Studio's. They sound a bit too smooth for my ears.
There's nothing that says you can't use the in-between tones on a Nashville Tele, though. If you can get emotion across, it doesn't matter what pickup or guitar you use.
Everybody has their own signature attack.
SteveY is offline   Reply With Quote
Old April 18th, 2005, 01:31 AM   #3 (permalink)
kerc's Avatar
Yeah, mine's called...uh...sloppy.
BTW, I ordered today a GFS Fat TC Alnico bridge pup. Seems to be one hot baby.
8)
Hey, try to play your guitar daily!
kerc is offline   Reply With Quote
Old April 18th, 2005, 07:40 AM   #4 (permalink)
Andre''s Avatar
I like to order pickups from smaller companys like Lollar or Rio Grande, cause these guys love there stuff, not like the guy behind the counter at guitar center.
That being said, I'm having a blues machine being built for me right now by forum member Rob Di Stefano, Fret Tech, and I'm going with a Charlie Christian pup in the neck and a vintage tele bridge by Jason Lollar.
"blues in a doggy bag, is what i got to eat!"
Andre and The Night Hounds
http://www.andreandthenighthounds.com/
Andre' is offline   Reply With Quote
Old April 18th, 2005, 07:45 AM   #5 (permalink)
Sounds great. Rob's a great guy!
That's a pick up combination I'd love to hear. Let us know it works out.
:D Peter
PeterUK is offline   Reply With Quote
Old April 18th, 2005, 09:21 AM   #6 (permalink)
maestrovert's Avatar
N'ville Pups
if'n i'm not mistaken, the Mim N'ville Pups are the "TexMex" variety .... a bit overwound (as compared to "vintage") but still with the clarity/"twang" Tele's are rightfully famous for.
Mine are GREAT and work quite well for any/everything, my #1 is a '52 RI , but uptil now the N'ville has been #2 (currently tweaking set up on a new parts/sparklecaster built with '52 RI parts/specs to be tied for #1)
if you like your N'ville, i wouldn't change a thing, i find "blues" tone has more to do with amp settings and response anyways
Sing the Song Bro'
Play on Drummer
www.godonthe.net
Old April 18th, 2005, 10:21 AM   #7 (permalink)
Durtdog's Avatar
For blues, I like the 2 pickup arrangement better than the Nashville. In my "Brownie" I have a GFS fat alnico bridge and P-90 in the neck. It'll do screaming treble icepick nasty to thick syrupy and everything in between. It's actually quite versatile.
Durtdog is offline   Reply With Quote
Old April 18th, 2005, 12:52 PM   #8 (permalink)
Nub
If you want some Strat sounds, stay with your Nashville setup, but go with a Rio Grande Dual Calibrated Nashville pickup set (you can get 'em from Rob). I just put those in one of my Teles, and they're fantastic!
For a regular Tele setup, a Rio Muy Grande set & a 4-way switch will put a huge smile on your face!
Nub is offline   Reply With Quote
Old April 18th, 2005, 01:27 PM   #9 (permalink)
Geo
Geo's Avatar
With 3 already in there you might just want to wire in the
neck + bridge combination which is real useful for a lot of
blues styles and songs.
Beyond that I like a hot bridge with good depth mids, low
end along with decent upper range. What you have may
already be like that.
"Somewhere between culture and agriculture"
Geo is offline   Reply With Quote
Old April 18th, 2005, 03:23 PM   #10 (permalink)
eryque's Avatar
Here's my great solution for a blues machine. This is Ginger after some relatively invasive surgery:
<a href=http://images.snapfish.com/3436%3A79523232%7Ffp46%3Dot%3E2334%3D677%3D953%3DX ROQDF%3E23238356%3B3879ot1lsi>Ginger the 3 pickup killer blues machine</a>
The neck humbucker is a Duncan '59, the middle pickup is a Fender pickup from the late 60s, and the bridge is an HD '54. The middle pickup sounds an awful lot like a normal tele in the middle position, and that humbucker will get growly and fat like nobody's business. It doesn't have much mud in it, either.
I originally chose the HD for the bridge because it matched well with the single-coil neck pickup before the surgery. It's thicker and smoother than a typical vintage bridge pickup, but still sounds vintagey. Now I'm thinking of replacing the bridge pickup with something that has a little more traditional twang when I want to do my lame attempt at country. There's a Donahue pickup sitting on my shelf that would make a good candidate.
Old April 19th, 2005, 07:37 AM   #11 (permalink)
Blues Machine
I have what I would consider a great Blues Machine.
Zion model 50 with a HD vintage + bridge pup, and a Vintage Vibe CC rider (Charlie Christian type) neck pu with a 4 way switch.
Great tone in every spot.
Jim Sams is offline   Reply With Quote
Old April 19th, 2005, 10:23 AM   #12 (permalink)
BootRoots's Avatar
I have three Evans single coils in my nashvile. the bridge has their Hot Lead model which sounds great. They are actually strat pickups but the bridge pickup is mounted to a tele bridge plate so it fits properly. Its wired with a 5-way mega switch model E. its just like a regular strat would be wired but in the middle position, I get neck/bridge and not just the middle. I get the best of both worlds as far as tones go.
BootRoots is offline   Reply With Quote
