Old April 17th, 2005, 08:11 PM   #1 (permalink)
Bluesdude's Avatar
Lowering a neck pocket...
I got a body from warmoth, and after everything was finished, i was adjusting the action, and noticed i had to set the saddles excruciatingly high to get even a low action. The problem is the neck sits too high in the pocket, so i either need to chisel out 1/2 a centimeter of the neck pocket, or off the bottom of the neck. So 2 questions. Should I either take wood off the bottom of the neck or take it out of the neck pocket, and whats the best method for either?
So much rythm, grace, and debonair from one man?
Bluesdude is offline   Reply With Quote
Old April 17th, 2005, 08:19 PM   #2 (permalink)
eryque's Avatar
If you're good with a router, it would probably be easier to remove that wood from the neck pocket.
However, it's probably easier yet to just shim the neck. Shim the end of the pocket away from the bridge to angle the fretboard down towards the bridge. I'd do that first, the only material required is a business card or something similar, and the only tool needed is a pair of scissors. And there's lots of room for error too.
Old April 17th, 2005, 09:16 PM   #3 (permalink)
popthree's Avatar
i just got thu doing this to a guitar. i used strips of duct tape. started with 2...worked my way up to 5 before i hit the right angle. i initially tried a business card, but it wasn't quite enough..and when i folded it in two, it was way too much.
don't taze me bro !
popthree is offline   Reply With Quote
Old April 17th, 2005, 09:19 PM   #4 (permalink)
I had the very same problem on a Warmoth body just recently. I got a Warmoth neck too and the pocket was just too shallow. I put mine on a mill and used a 1/2 inch end mill and took some out. My main problem with it was that the pocket angle was not right either so I corrected that too at the same time. Machine tools and machining is my trade so I knew what I was doing. I would suggest using a milling machine if you could or have someone do it. A router may be very difficult cause there is no support on two sides of the pocket for the most part.
P.S., .....don't cut down the neck.....that seems even more difficult cause of the possibility of changing the neck angle, plus the mismact possibility at the back of the neck and heel.
Can't play too hot, but my stuff looks good!
steve s is offline   Reply With Quote
Old April 17th, 2005, 10:03 PM   #5 (permalink)
Carefull!!
If you lower the neck pocket too much, you can pop out a couple of frets if the tips of the the screws go too deep into the neck. You can grind the tips a bit and use a neck plate pad to be sure.(the pad acts as a washer)
Ramblin Ray is offline   Reply With Quote
Old April 17th, 2005, 10:40 PM   #6 (permalink)
Caper's Avatar
I bought an Allparts neck and body, I figured it was the surest way to go, you would think the neck and body would be a perfect match, NOT. The neck pocket wasn't deep enough. The university I attend has a Machinist and Mech. Technologist program so I had one of the instructors set the body up on a CNC machine and he fixed it. I then sent it to a guy who builds guitars to have it set up. He also added a micro tilt, did an excellent job.
Caper is offline   Reply With Quote
Old April 18th, 2005, 01:29 AM   #7 (permalink)
SteveY's Avatar
Stick some nickels under the legs of your bridge.
SteveY is offline   Reply With Quote
Old April 18th, 2005, 04:22 PM   #8 (permalink)
JerryPro's Avatar
I had that same problem
I would not cut anything right now.
I would put it together with the shims and I'll bet that after about a month or so you'll be pulling those shims out.
What happens is once the neck and string pressure is on the new neck pocket it will settle in. Also I noticed a paint buildup in the pocket nearest the body. I also removed that excess which improved the angle a bit.
Mine took the full thickness of a credit at the very back edge of the neck pocket. I mean the strings were actually lying on the fretboard without it. After 3 weeks I had to remove the shim. Now it's perfect.
I was on this board asking the same questions. Now I am glad I didn't CNC the neck pocket.
...it's not the load that breaks you down it's the way in which you carry it.
JerryPro is offline   Reply With Quote
Old April 18th, 2005, 04:34 PM   #9 (permalink)
tomkatf's Avatar
Probably a Silly Question but...
... have you checked the relief (slight amount of curvature) in the neck when it's under tension (tuned up to pitch)?? If that's off you may just need to make a truss rod adjustment...I'm only asking because the last three neck/body pairs I've bought from Warmoth have been nearly perfect, only requiring a slight trussrod adjustment to taste...HTH.
Best,
Tom
"it's really groovy to be here... didn't even rain... no buttons to push"...
Jimi Hendrix, Monterey 1967
tomkatf is offline   Reply With Quote
Old April 18th, 2005, 04:34 PM   #10 (permalink)
TheGoodTexan's Avatar
Yep - the quick answer.
I would run with this method for a few weeks of playing before attempting a modification of the neck pocket.
Fuzzy had a picture of it posted a few weeks. Do a search.
Originally Posted by Sidney Vicious
If there's anything worse than whining its whining that your whining isn't being heard.
TheGoodTexan is online now   Reply With Quote
Old April 19th, 2005, 04:50 AM   #11 (permalink)
Joel Terry's Avatar
Here's FUZZY'S thread with the nickel-raised bridge saddles; unfortunately, when I read the thread, FUZZY's pics were not coming up.
Joel
Jesus saves--and He passes the savings on to YOU!
ASPCA
"Well...."
Joel Terry is offline   Reply With Quote
Old April 19th, 2005, 11:39 AM   #12 (permalink)
i've had the same issues
shimmed her up and away I went. Brought it to a respected luthier for a set up and he told me what I've believed for many years now. Warmoth rarely ever requires shims. If both the body and neck are warmoth then its probabely a matter of having the frets leveled. Warmoth does not do this on their necks.
Right now he is setting up my tele, he's gonna take out the shim, set it up, and determine if the frets need a leveling or not. Can't wait 'till friday.
gottliver is offline   Reply With Quote
