Old June 2nd, 2003, 08:50 AM   #1 (permalink)
TeleGeir's Avatar
Bigsby with Jaguar style bridge mounting?
Ok, having succeeded nicely with the Buck Owens Bigsby (not too difficult since I didn't do it myself), I am thinking about using one with a Jag bridge like this:
Now the bodies I have coming in are already drilled for a 4 hole vintage bridge. This contraption it seems will use 3 screw holes plus some big one for the bridge ferrules at the left there. Is that a correct assumption?
If so, is this going to be a bit of a mess, or are the vintage holes far enough away that it won't be a problem? Is this pic that Fuzzy posted once correct im my case?
I remember someone posted a great Bigsby "tutorial" once, but I am not sure it still exists around here...
TIA,
Geir :)
"This is a room in Paul's house."
TeleGeir is offline   Reply With Quote
Old June 2nd, 2003, 09:18 AM   #2 (permalink)
Poppatwang's Avatar
Fuzzy Pic
Looks right to me. I installed that setup on mine.
I used "paper tape", a low adhesive tape for securing
art paper to a drawing board. Applied tape to body
(mine was factory finished) as a surface to draw
template on. Measure, mark & recheck 3 times before
drilling. I put the ground wire thru the side of the
bridge ferrule hole.
Good luck!
Poppatwang is offline   Reply With Quote
Old June 2nd, 2003, 10:11 AM   #3 (permalink)
Make that a MUSTANG bridge
To save your sanity dump the jag bridge and use a mustang bridge. The small threads that are supposed to hole the strings in place do not function. The mustang bridge saddles have one groove and is the way to go.
hiptone is offline   Reply With Quote
Old June 2nd, 2003, 10:12 AM   #4 (permalink)
Old June 2nd, 2003, 10:39 AM   #5 (permalink)
Bridge plate
Also, if that's the cheap plastic bridge plate you get in those Bigsby kits, get the real thing from Allparts.
Mark is offline   Reply With Quote
Old June 2nd, 2003, 09:29 PM   #6 (permalink)
Judging from that pic, I am guessing you're getting that from RelicMasters. I have the exact same kit (as the B-50 pictured, but I have the B-5) and it is fantastic, however on the body I had, I had to route a bit away from the bridge hole to get the bridge pup to fit. You may have better luck, but I drilled the bridge ferrule holes where the centers were exactly equidistant from the 12th fret as the nut was from the 12th fret, so I wouldn't have to adjust the saddle intonation. As a result, the bridge-plate was too close to the neck to allow ample room for the pickup. In retrospect, I should have made sure the bridge pick-up fit, even if it meant drastically shifting the saddles for intonation.
Hope yours works though. Good Luck and enjoy!
Slim is offline   Reply With Quote
Old June 2nd, 2003, 09:56 PM   #7 (permalink)
TeleGeir's Avatar
Actually, I haven't yet gotten as far as deciding to get it at all. It was just an idea, based on the fact that they offer relicing (or "aging") of hardware.
Thanks for your advice and warning. And thanks to everyone else!
I'll give it all some thought. I have got the bodies and the necks now (see my new post about the other neck.)
Geir :)
Old June 2nd, 2003, 10:34 PM   #8 (permalink)
MandyMarie's Avatar
Which is mine?
Guys, I'm not too good with these other bridges - is the bridge on my '68 a Jazzmaster bridge or a Mustang bridge? I've always said it was a Jazzmaster bridge, but Hiptone made me wonder...mine holds a tune like a champ, but after seeing Tele295's pics I sure want to go back to that standard Telecaster bridgeplate.
TeleGeir - please don't make fun of me...it's taped off black binding :D
MandyMarie is offline   Reply With Quote
Old June 2nd, 2003, 11:29 PM   #9 (permalink)
0le FUZZY's Avatar
Looks lika Mustang
  • But with the pole pieces changed out with Tele 6 pole bridge pieces.
  • The Mustang had all different diameter poles.
  • Here iss watt I done with one of mine. 6 liddo rollers all inna row goin "Go man Go man Go man Go".
  • Hay it werks don't knock kit!!
  • Notice only the big E and B git bent the others come up threw the body. Kind of a cheap b-bender !! HEE! HEE!
  • I'll put it back so all 6 git bent some day when I git a roun-tew-witt.
    0.F.
  • 0le FUZZY is offline   Reply With Quote
    Old June 2nd, 2003, 11:50 PM   #10 (permalink)
    T-Joe's Avatar
    I love 'em with a Bigsby
    It doesn't matter what kind of bridge they have or what color they are. Here's the one I made with the Relicmaster set-up.
    Cheers from Beer Lake,
    T-Joe
    T-Joe is offline   Reply With Quote
    Old June 2nd, 2003, 11:55 PM   #11 (permalink)
    TeleGeir's Avatar
    Since we are in picture mode
    Here of course is mine...:
    Geir :)
    Old June 3rd, 2003, 12:07 AM   #12 (permalink)
    T-Joe's Avatar
    Touche
    I've been outdone by a double-bound! :D That is one beautiful Buck Telegeir. Hurry up with that new one.
    T-Joe
    Old June 3rd, 2003, 01:11 PM   #13 (permalink)
    MandyMarie's Avatar
    I know I keep sayin' it, but I sure like the looks of that standard Tele bridge!
    Old June 3rd, 2003, 07:46 PM   #14 (permalink)
    I think you are referring to this...
    http://photos.yahoo.com/grievousangels
    Just click on the Bigsby T... icon when you get there. Ignore the typos which I have yet to correct even though the pic's are almost a year old.
    I have a link to the pic's on my profile page also.
    The orginal bridge on the tele in the pic's is not the vintage 4-hole type like those on MIM standard teles so this might not answer all of your questions but it should be a start.
    There are 5 holes that hold down the bigsby bridge plate and two more big holes for the bridge ferrules.
    You should probably invest in a drill press, a drill bit index, a ruler graduated to 64ths, a digital caliper, a tape measure, and anger management classes just in case you mess up
    You can get away with less than that but everything I bought for my bigsby project I still use regularly -- they're just handy tohave around.
    Feel free to post questions or email me directly.
    --James W
    James W is offline   Reply With Quote
    Old June 4th, 2003, 05:36 AM   #15 (permalink)
    TeleGeir's Avatar
    Re: I think you are referring to this...
    Thanks James. That is brilliant stuff, Exactly what I was referring to. (I should be better at saving links like that.)
    Hmmm... Luckily I bought two bodies. That way "if at first I don't succeed". Knock on wood (in this case ash top and back on poplar).
    My drill press probably is not quite up to the task. I will have to check all my equipment out. I am planning on building a new garage here, and turn the old one into a workshop. That would be fun!
    Geir :)
    Old June 4th, 2003, 10:59 AM   #16 (permalink)
    Mik
    Mik's Avatar
    Mustang bridge drops right in a stock factory-bigsby Tele ('65 Stang bridge onto my '71 Tele). In fact (I think) the stang and the Btele share the same bridge cradle.
    Mik
    a "motor-bike with a touch of blood in it is better than all the riding animals on earth, because of its logical extension of our faculties, and the hint, the provocations, to excess."-T.E. Lawrence
    Mik is offline   Reply With Quote
    Old June 4th, 2003, 12:21 PM   #17 (permalink)
    More Bigsby Install Pics..... :)
    I recently mounted a Bibsby on a Mexican Tele as part of a learning experience. I used the site James W posted above and it helped a great deal.
    If you are interested, I posted some pictures of my project at http://www.1966gto.com/bigsbyDefault.aspx
    Let me know if you have any questions or can't access the site.
    Have fun!
    Jay Kardong
    Seattle WA
    Jkard883 is offline   Reply With Quote
    Old June 4th, 2003, 12:59 PM   #18 (permalink)
    TeleGeir's Avatar
    Re: More Bigsby Install Pics..... :)
    Have fun!
    Jay Kardong
    Seattle WA
    That is mighty cool Jay! Really like it! We shall see if I end up with a Bigsby on one of mine. Not quite decided yet...
    Geir :)
    Old June 5th, 2003, 12:48 PM   #19 (permalink)
    Geir :)
    Yeah, Jay took some awesome pictures -- really detailed close-ups and much better lighting than my pic's. Also, the Midnight Wine finish makes it easier to see what's going on. Great job, Jay!
    --James W
    Old June 6th, 2003, 03:21 AM   #20 (permalink)
    Mike Better's Avatar
    I'm gonna play devil's advocate here and say "do you need another Bigsby?" That Bucktele is sweet, I'd move on to a different niche in the world that is double-bound teles.. I said it a couple times before, Geir, you need a Nashville West tele in that bunch! With a bender! Talk about the most famous reindeer of all..
    Mike
    Mike Better is offline   Reply With Quote
    Old June 6th, 2003, 04:11 AM   #21 (permalink)
    TeleGeir's Avatar
    Well Mike. You know, I think I am already past "need". Seriously, when I set out on this new Telecaster mission of mine, I wanted the following:
    * A fat tele for blues (Albert Collins)
    * A tele for 5 string open G ('62 RI)
    * A Bigsby Tele (Buck Owens)
    * A Thinline (90s Thinline)
    * An Esquire (?)
    When I started, the Tux was going to be the Esquire. But as you know, it didn't end that way. Instead the Tux became the dream Tele. I know what the Esquire will be, but that is a bit down the line...
    Now that I got what I wanted, I can experiment. So far I have sort of set my gadget limit this side of the bender. But hey, who knows. So excuse my ignorance: a Nashville West bender tele would be what? Is this the Clarence White tele? Sunburst with maple neck, I guess, and I believe I heard something about a Strat PU. But what hardware and PUs? I'd need a professional installation of the bender, I am sure.
    Geir :)
