Plans for a Time Machine - Telecaster Guitar Forum
Old February 5th, 2011, 11:35 PM   #1 (permalink)
I once read how a Furniture Historian created a fake Colonial chair that fooled the Experts and ended up in a Boston Museum. Some of his techniques could be used to create a "Proper" Relic. The others are mine.
A small greenhouse made of Poly over frames must be built.The body and neck are placed inside and raw tobacco fumes are pumped in from a wood stove. The UV rays will age the wood and the smoke creates a patina.
So that the wood does not get too hot cooling is essential, basically recirculating the smoke.
A silicone "Arm" mounted to an oscillating motor driven cam rides over the mounted body to induce natural wear. Canvas shirt sleeve over the dummy arm speeds up the process, with the machine set to a random pattern of flailing the sides and top. This could run during the day while you are at work.
A silicone hand set up properly could do likewise for the wear patterns between frets, think CNC programmed accuracy.
So while neck and body are in the tent getting UV, smoked and "played" up to eight hours a day the metal parts must be attended to.
The chair Forger set his in the ocean with small chains rapped in strategic places, where the wave action beat it (I believe his name was Wallace Nutting). Salt water and hot sand would certainly get the metal parts "Right" in short order.
During assembly various chemical stains using creosote and wax applied with an artistic touch would complete the illusion.
I'm just crazy enough to try this, first I have to decide on the color and style to start with, perhaps Daphne blue and maple?
phillip lee is offline   Reply With Quote
Old February 5th, 2011, 11:52 PM   #2 (permalink)
Verne Bunsen's Avatar
Yeah, well, you know, that's just, like, your opinion, man...
Verne Bunsen is online now   Reply With Quote
Old February 6th, 2011, 12:02 AM   #3 (permalink)
Ronkirn's Avatar
No problem... except where are you gonna get chemically correct lacquer, since much of the chemistry used 50 years ago is banned, and/or no longer eve made today.... not to mention the glue...or the steel for the parts, or the Chroming done like they did back then.... or the plastic for the ..... gettin' the idea??
Just wonderin'... I could use some...
Ron Kirn
Be careful when you follow the masses, sometimes the M is silent.
Holiday Sale alive and well...
http://ronkirn.com/holiday.htm
Ronkirn is online now   Reply With Quote
Sponsored Links   #
Old February 7th, 2011, 07:00 PM   #4 (permalink)
You missed a key word, "Illusion". I want a Relic but not from the usual means. Tinted lacquer always looks tinted, UV and smoke damaged finish would look much more natural.
The wear patterns of a robotic arm properly set up and programmed would have to beat the belt sander treatment. Current relic metal parts either look cooked well done or too rare to me.
I'm not trying to fool Experts by any means.
But the Road Worn Series did show a Market for Relic Guitars.
Old February 7th, 2011, 07:32 PM   #5 (permalink)
Frontier9's Avatar
I like this idea... just think, if you get the "finger-wear" and the "arm-flailing" robots programmed correctly, you have a new bandmate! Nice little benefit on the side...
win/win
Frontier9 is offline   Reply With Quote
Old February 7th, 2011, 08:28 PM   #6 (permalink)
tgfmike's Avatar
I thought you were going to build one of these:
some of my best stuff is jibber-jabber
tgfmike is online now   Reply With Quote
Old February 7th, 2011, 08:36 PM   #7 (permalink)
Bud Green's Avatar
Bud Green is offline   Reply With Quote
Old February 7th, 2011, 08:52 PM   #8 (permalink)
Rolling Estonian's Avatar
Get a barrel, put a bunch of chains, nuts bolts in it. Put a body in there, close her up and roll it around a bit.
My bro knew of a guitar builder in Amherst MA. That did this to relic. He said it worked quite well. I would imagine so. Your method sounds good, but seems costly. Green houses and robots etc. And cigarettes aren't cheap either.
M
"This here's a joy ride so I say en-joy!" Dana Carvey as H. Ross Perot
Rolling Estonian is offline   Reply With Quote
» Random Photo for Guests
New Build..........
Fender Logan Custom Guitars
