Any threads about bigsby bridge options? - Telecaster Guitar Forum
Old January 22nd, 2011, 06:00 PM   #1 (permalink)
thegamestop's Avatar
I just installed a B5 on my tele and tried to modify my stock bridge, but it didn't work out. I have to get the tele bigbsy conversion plate, but was curious if a mustang/jaguar bridge would work with the plate (match up with the holes), or any other quality TOM bridges you guys know of.
thegamestop is offline   Reply With Quote
Old January 22nd, 2011, 08:03 PM   #2 (permalink)
Bolide's Avatar
No answer, just interested in the question and want to bump it.
Bolide is offline   Reply With Quote
Old January 22nd, 2011, 08:04 PM   #3 (permalink)
Walter Broes's Avatar
I think if I was to put a B5 Bigsby on a telecaster, with that plate, I'd get a mastery bridge - expensive, but it look SO worth it.
Walter Broes is offline   Reply With Quote
Sponsored Links   #
Old January 22nd, 2011, 08:27 PM   #4 (permalink)
the "Space Bridge" from ZZ GuitarWorks. (got mine on ebay) I have two and like them. Fits the holes etc. Needs no neck shims etc... I have also used the Mustange bridge but you WILL have to shim your neck and it raises your strings (of course you can raise your pickups .)
ID:	70504   Click image for larger version
Twang Guitars is offline   Reply With Quote
Old January 22nd, 2011, 09:29 PM   #5 (permalink)
+1
-GB
Greg Bennett (no relation)
www.thejetage.net
jetagegreg is offline   Reply With Quote
Old January 22nd, 2011, 09:29 PM   #6 (permalink)
Very cool, haven't seen these before. It's a little more than I want to spend though. Might have to go with the mustang.
Old January 23rd, 2011, 04:52 AM   #7 (permalink)
Mr. Esquire's Avatar
The Jazzmaster bridge comes standard with the Bigsby B5-F kit. The Jazzmaster, Mustang and Jaguar bridges are interchangeable, AFAIK. The problem with the Mustang bridge is that each saddle has a single string slot while the Jazzmaster bridge (and possibly the Jaguar) has threaded saddles which allows you to put each string where you want them. So if, for example, the low E is too close to the edge of the fretboard, the threaded saddles of the Jazzmaster bridge allows you to place it closer to the A string and away from the edge. This is simply not possible with the Mustang bridge.
Several people in this thread mentioned the Mastery bridge. It looks like a great product that solves many problems of the Jazzmaster bridge on a Tele. The problem is that the Mastery bridge is $175. Personally, I would never pay that much for any bridge.
I comment all the time in threads that discuss a Bigsby. And I always link up the boards.ie mods to a Bigsby B5 kit with the Jazzmaster bridge. Sorry if anyone is annoyed. I always do that because those mods worked for me so brilliantly and it was all free. The original poster to the boards.ie page claims his mods are (more or less) equivalent to a Mastery bridge. Not sure if it's true because, as I said, I would never throw down that much money for a Mastery. But if you get a B5 bridge plate with a Jazzmaster (or Mustang or Jaguar) bridge, I recommend you try those mods before dropping the big bucks on a Mastery. It might save you a few dollars. It did for me.
Mr. Esquire is offline   Reply With Quote
Old January 23rd, 2011, 10:59 AM   #8 (permalink)
Thanks for all the input guys, looking into finding a roller TOM style bridge to match up with the bigsby plate. If not I'll probably go with a mustang bridge.
Old January 23rd, 2011, 11:29 AM   #9 (permalink)
I've got a Rutters nickel plated CRS bridge on the way modified for a bigsby b-5. When I get it in this week I will post some pics. He did his brass compensated saddles but chrome plated them. He said the chrome plating would be tough and slippery.
jimmytulsa is offline   Reply With Quote
Old January 23rd, 2011, 11:49 AM   #10 (permalink)
so this doesn't work?
i just spent half an hour lookin for my old bigsby to put on ...
slapshot is offline   Reply With Quote
Old January 23rd, 2011, 12:55 PM   #11 (permalink)
GigsbyBoyUK's Avatar
Tunomatics work fine for me.
GigsbyBoyUK is offline   Reply With Quote
Old January 23rd, 2011, 12:58 PM   #12 (permalink)
This is the bridge I tried to modify. I filed out as much area as I could, but couldn't get them where the strings wouldn't rub on the original plate.
Old January 23rd, 2011, 02:32 PM   #13 (permalink)
Trying to modify an ashtray-type bridge with six saddles is usually not successful.If having six individual saddles is the highest priority,then a Jazzmaster/Mustang bridge is the way to go with a B5 installation.If the OP would be good with 3 saddles,a vintage-style ashtray works fine-there's lots of room for filing material away for clearance while still retaining enough structural strength.
Here's a pic of my Esquire with an early ZZ B5 kit.They supplied the ashtray already filed down and not slotted.
EDIT:Oops! I just noticed that the bridge on the black Tele looks like the American Standard 3 screw type.That's not compatible with the vintage 4 screw ashtray type.
Dave Hopping is offline   Reply With Quote
Old January 24th, 2011, 02:28 AM   #14 (permalink)
Marc Rutters's Avatar
Hey Jimmy I'll beat you to it this is your bridge. I did some extra smoothing and polishing around the back cuts so it feels slick, snags or sharp edges are not good.
Marc Rutters is offline   Reply With Quote
Old January 24th, 2011, 05:42 AM   #15 (permalink)
Verne Bunsen's Avatar
The modified 3-saddle bridge is definitely my preferred setup. I put F-logo B5s on both my Teles and took that approach on both of them. I started out with the Space Bridge as shown above, but didn't care for how that "lip" felt under my right hand, so I switched to a hideous palm-slicer that I filed out myself, then finally upgraded to custom machined bridges from Taipan Tone. Nice hardware.
http://www.taipantone.com/pages/full%20bridge.html
I think he charged an extra $20 or $30 for the Bigsby mod.
Yeah, well, you know, that's just, like, your opinion, man...
Verne Bunsen is online now   Reply With Quote
Old January 24th, 2011, 09:26 AM   #16 (permalink)
jefrs's Avatar
Whilst the jag/jazz bridge looks something like threaded tele saddles, it is a rocker unit, it has long post holes. Unlike a ToM, which wobble at the top, the posts wobble from the bottom. Plus is has completely different hole centres to a ToM, so if you want to change to a roller ToM (a dodge for the jag/jazz), you can't.
Another thing to consider is that the tele has a much lower break angle over the saddles with a Bigsby than does an archtop, the jag bridge is not going to rock. Hence most use a tele-type bridge of some sort. My solid Gretsch has a much higher Bigsby saddle but it still needs the B7 roller bar, like that on the B5.
Old January 24th, 2011, 01:58 PM   #17 (permalink)
A.B.Negative's Avatar
If you have a heavy right hand like me, threaded saddles aren't a good idea. The strings don't stay where you put them but get knocked into different parts of the thread, affecting tuning. With single slots, the string tends to stay in the slot unless I'm bashing really hard.
"I'm playing all the right notes—but not necessarily in the right order."
A.B.Negative is offline   Reply With Quote
Old January 24th, 2011, 07:42 PM   #18 (permalink)
Just got it Marc! Looks Awesome! Here are som pics installed:
Old April 6th, 2011, 05:24 PM   #19 (permalink)
I agree
NICE! Functional and looks great.
Sarcasm is only one service we offer.
charliebrown is offline   Reply With Quote
Old April 6th, 2011, 08:17 PM   #20 (permalink)
When putting a bigsby on, is there a certain distance that it needs to be spaced from the saddles?
wademp is offline   Reply With Quote
» Random Photo for Guests
92 MIM Hardtail
» Recent ThreadsGuests
Fender Logan Custom Guitars
