Wilde Pickups by Bill & Becky Lawrence Simmons Amp Repair Lace Music Products Acme Guitar Works GuitarSale.com Hahn Guitars Warmoth.com
Old December 9th, 2009, 08:44 PM   #1 (permalink)
Identifying Telecaster Models
Hi All,
Im new to Teles. Been playing one for a few months now. Really diggin' it. Love the playability and the overall tone.
I know my question may require a very lengthy answer but how do you identity a Telecaster model at one glance?
What are the basic telltale signs?
Is there a wiki somewhere that shows Telecaster models from every decade? Models? Specs? Differences?
Thanks to anyone who can share some some info.
Cheers!
jmreyes is offline   Reply With Quote
Old December 9th, 2009, 09:14 PM   #2 (permalink)
Unless it is a distinctive model say, a Deluxe, a Blackout, a '52 maybe, it's tough.
Teles that are of the Standard persuasion are rather non-descript except for the
occassional color change. So no-frills, so minimalist you gotta get up close and
check that serial number and even then it might be off a couple years.
BGTele is offline   Reply With Quote
Old December 9th, 2009, 10:23 PM   #3 (permalink)
Mark Davis's Avatar
First thing I look for is the neck pickup mounted to the pickguard or to the body.
Its easy to tell cause there are adjustment screws visible on the pickguard mounted ones.
That tells me right away its not a vintage speced Tele. Its the modern design which usually has a 6 saddle bridge tuners where the string goes sideways thru the tuner post instead of down the middle like vintage ones do.
I only like the Vintage style ones so as soon as I see those neck pickup adjuster screws I look elsewhere.
Old December 9th, 2009, 10:30 PM   #4 (permalink)
RodeoTex's Avatar
For normal Teles I look at the bridge first, that'll narrow down the possibilities right away, then the number of screws in the pickguard. These two things will tell you at least whether it is a newer or older model. Of course all the reissue guitars mimmic the old ones so, as BG stated the S/N and origin of manufacture will tell you a lot.
All this can go right out the window if the guitar has been modded after it left the showroom so to be more informed you might need to look at the end of the neck and in the body cavaties - thus this is why members here often ask for these photos.
I love threads where someone is trying to ID a particular guitar and the banter back and forth by the historians here. I've learned a lot this way.
Fender has tended to be very fickle about using up old parts, and their S/N-to-neck date relationship may often throw more kinks into the fray.
Old December 9th, 2009, 10:50 PM   #5 (permalink)
One day you will be enlightened, and then you'll just know.
LazerMouth is offline   Reply With Quote
Old December 9th, 2009, 11:44 PM   #6 (permalink)
Mark Davis's Avatar
Another good way is go to Fender.com look at all the Teles and their specs and see how they are all different.
Old December 10th, 2009, 02:45 AM   #7 (permalink)
Thanks Everyone.
Did some studying for a few hours. Instead of identifying exact models, I narrowed it down to years. Here's what I noticed:
50's
5 screws on pick guard (none on pickups)
Round Switch Tip
Truss Rod Adjustment hole on headstock
Round String Tree
60's
8 screws on pick guard (none on pickups)
Top-Hat Switch Tip
Truss Rod Adjustment hole under pick guard
Butterfly Type String Tree
All bridges were vintage ashtray type with either 3 steel or brass saddles.
Vintage Tuners
21 frets
Someone correct me if im wrong. Feel free to add also.
Are 70's mostly humbuckers?
Old December 10th, 2009, 02:53 AM   #8 (permalink)
Be careful...just when you "think" you have it down, something comes out of left field and leaves you scratching your head.
Remember, they did not know we would be looking at things with a magnifying glass 50+ years after they just "built the stuff". You'll see many thing on original Guitars that are there purely because the parts "were there" and they didn't want to waste anything.
The basic rule is, Fender made 1 of everything...even if it wasn't in the Catalogue. ;-)
"Here's a secret...we keep Telecasters in cases to protect other guitars from them."
- Bill Kirchen
IPLAYLOUD is offline   Reply With Quote
Old December 10th, 2009, 02:54 AM   #9 (permalink)
Mark Davis's Avatar
On the 50's Teles thats a walnut plug on the headstock it looks like it adjusts there cause of that walnut plug but it adjusts like the 60's at the back of the neck under the pickguard.
Other than that you got it right.
Old December 10th, 2009, 05:17 AM   #10 (permalink)
Most of us use this. Its the best out there, almost too much detail!
The Roadworn is the MILF of the Telecaster series!
Not that I own one; but I've tried a few out!
Tonemonkey is offline   Reply With Quote
new classic player telecaster models Artemio_Cruz Telecaster Discussion Forum 18 June 25th, 2009 07:04 PM
Telecaster paper models AmericanStd. Bad Dog Cafe 8 December 20th, 2008 08:25 AM
Famous Telecaster Players - Models TeleSVK Telecaster Discussion Forum 16 March 19th, 2008 07:27 PM
SCOOP!! Two hot new telecaster models for 08... Califatboy Telecaster Discussion Forum 32 January 11th, 2008 12:05 AM
telecaster models, where manufactured johnxy6 Telecaster Discussion Forum 1 June 16th, 2006 07:22 PM
