Old November 14th, 2009, 06:53 PM   #1 (permalink)
Squier Affinity Tele/Texas Special Pickups- Grounding Problem
I picked up a set of Fender Custom Shop Texas Special pickups to upgrade the stock pick ups in the Squier. When I took the telecaster apart, I noticed that the stock picks do not have ground wires but the new pickups do have ground wires.
Any help on how and where I should ground these wires?
Thanks!
Fred
Fredcq is offline   Reply With Quote
Old November 14th, 2009, 07:09 PM   #2 (permalink)
Normally the ground wires(black ones) go to the back of the volume pot. Maybe this diagram from the Seymour Duncan web site will help.
http://www.seymourduncan.com/support...=standard_tele
Odie251 is offline   Reply With Quote
Old November 14th, 2009, 07:17 PM   #3 (permalink)
Thanks for the reply.
The silver neck pick up has three wires...black, white and yellow. The old neck pick up only has black and white.
Old November 14th, 2009, 08:20 PM   #4 (permalink)
Fatmanstratman's Avatar
Here you go. Click on THIS LINK HERE which will open a PDF file of the wiring diagram for the AV 62 Tele - this also uses the black/white/yellow leads from the neck, so this will show you how to connect them up.
Not sure about the SWITCH you have in your Squier, but you should be able to work it out. Come back if you are having any difficulties.
"Behind every argument is someone's ignorance."
Fatmanstratman is offline   Reply With Quote
Old November 14th, 2009, 10:08 PM   #5 (permalink)
VENDOR
mellecaster's Avatar
This is the correct diagram for your Texas Specials w/ the 4-way.
Old November 15th, 2009, 07:06 PM   #6 (permalink)
Thanks to all of you for the help. I was able to get them installed and they sound really nice!
I bought the Squier tele for the sole purpose of learning guitar repair. I managed to get a great deal on it from Guitar Center. They were selling it for $179 but I they sold it to me for $125 because I pointed out a small dent and scratch on the back of the guitar. It plays nice for a cheap guitar and now it sounds even better.
Squier affinity Tele Special edition bridge upgrade playcaster Telecaster Discussion Forum 21 February 26th, 2009 11:06 PM
Questions about Squier Affinity Tele Special BSB bl4444 Tele-Tech 21 July 3rd, 2008 04:24 PM
Review: 2007 Squier Affinity Tele Special Edition, Butterscotch Blonde javajane Telecaster Discussion Forum 9 December 21st, 2007 06:49 PM
Texas Special Tele pickups NashTele Tele-Tech 12 August 16th, 2003 01:00 PM
texas special bridge pick up grounding ...? TeleTwanger37 Tele-Tech 1 May 19th, 2003 06:16 AM
