Old November 6th, 2009, 10:54 AM   #1 (permalink)
FenderJunkee's Avatar
Loud hum!
Just assembled a Tele from parts, body does not have special paint inside cavities for grounding purposes like my other Fenders. Without touching bridge or strings there is a very loud, and annoying hum. What did I do wrong?
I followed some advice from here about sheilding the pickguard with aluminum foil, if the foil touches the neck pickup cover would that cause hum?
Does this mean a bad ground somewhere inside? Would appreciate any comments on this.
Thanks
BTW, stock fender parts all the way.
FenderJunkee is offline   Reply With Quote
Old November 6th, 2009, 11:38 AM   #2 (permalink)
Alamo's Avatar
Do you have a dedicated ground wire from the Volume to the Tone-pot ?
sometimes its enough that they're grounded through the control-plate - sometimes it ain't.
I did just that yesterday. didn't notice the hum that bad until I used the Bad Monkey for some overdrive which made it loud and annoying. I hardly use that Tele.
oh, and it hasn't any shielding paint or such - but it works now.
Timebandits-Berlin
Alamo is offline   Reply With Quote
Old November 6th, 2009, 11:55 AM   #3 (permalink)
Have you got the jack socket wires the wrong ways about? That will causes one stink of a bad hum! Also very easy to do.
Armo is offline   Reply With Quote
Old November 6th, 2009, 04:38 PM   #4 (permalink)
VENDOR
mellecaster's Avatar
That would be the first place I looked also...very common mistake.
Old November 6th, 2009, 07:58 PM   #5 (permalink)
Thanks guys,
I thought I double checked both of those items, but I'll look again. It is an easy enough mistake.
I'll bet I screwed up the jack connection, I'm hoping that is all it is, not really in the mood for a witch hunt.
Thanks again
Old November 6th, 2009, 09:31 PM   #6 (permalink)
Pots are OK, jack is OK. ???
Old November 6th, 2009, 10:57 PM   #7 (permalink)
VENDOR
Have you checked the outlets and circuits in the room for proper wiring ?
Any dimmer switches on your lights ?...Have you tried it in another room (circuit) ?...Tried another cord ?....etc...etc.
Old November 7th, 2009, 12:17 AM   #8 (permalink)
Forgot to mention, 4 other Tele's and a Strat live here, no problem with them, just the newly "Franked" Tele.
The only other thing I did with this one that I haven't done before is the aluminum foil under the pickguard thing. Wich BTW was more of a PITA than it was worth, still get a scratchy sound when I rub my fingers across the pickguard.
It might get loud Boubou Bad Dog Cafe 5 June 11th, 2009 11:55 AM
''It's too loud daddy! It's too loud!'' StratDal Bad Dog Cafe 16 March 23rd, 2008 11:41 AM
top e too loud teleray Tele-Tech 3 August 14th, 2007 11:20 AM
Loud Band in a loud room Telenator Bad Dog Cafe 20 February 4th, 2006 12:34 AM
amp too loud robmish Amp Central Station 21 August 15th, 2005 10:53 AM
