Old November 5th, 2009, 12:44 PM   #1 (permalink)
NasalFloss's Avatar
Clicking sound...
Hi y'all, only been playing a short length of time so forgive my ignorance.
The problem is that every time I touch the strings (or any other metal part of the tele) there is a clicking/popping sound. This only seems to happen when the neck pickup is active.
This didn't happen until yesterday (I've had the guitar for 3 months or so) and has been doing my head in.
Any advice would be great
Chris
(I got the CV squier and it's great!!!)
I prefer watching my tele to watching the telly
NasalFloss is offline   Reply With Quote
Old November 5th, 2009, 01:00 PM   #2 (permalink)
sounds like she isn't grounded properly.
strumminsix is offline   Reply With Quote
Old November 5th, 2009, 02:29 PM   #3 (permalink)
Frontier9's Avatar
I wonder if you are experiencing static build up in the pick guard. It's happened to me. You can fix that problem by attaching aluminum foil to the back of the guard with spray-on adhesive. You would then have to make sure that the foil is grounded - usually the pots will take care of that problem if they touch the foil.
Some folks give the guard a wipe with a dryer sheet.
Frontier9 is offline   Reply With Quote
Old November 5th, 2009, 03:07 PM   #4 (permalink)
Mark Davis's Avatar
If it was a ground problem you would have noticed it the first time you plugged it in.
Id also say its a static problem since the CV's are shielded so well.
Static usually starts with it gets cold and heaters are used that dry out the air and cause static.
Old November 5th, 2009, 03:36 PM   #5 (permalink)
Couldn't the ground wire come undone due to bouncing around the guitar and a cold solder joint?
Old November 5th, 2009, 04:36 PM   #6 (permalink)
Stylemaster's Avatar
I have the same problem on a partocaster I just put a GFS pickguard on the other day. I thought it was either that the neck pickup cover came unsoldered from the wire, or static electricity. Or both. The more I rub my hand rapidly on the pickguard (as a test) the worse it gets so I think static electricity has something to do with it.
Guitars: '57 Strat, '68 ES 335, '72 Martin D28, '74 Jazz Bass, ESP Custom Strat, '04 LP DC Plus, '07 LP R0, Partocaster
Amps: Fargen Blackbird 30, Peavey Classic 30, '65 Tremolux, Marshall AVT50
My 3D Artwork:http://www.andylackow.com
Stylemaster is offline   Reply With Quote
Old November 5th, 2009, 04:54 PM   #7 (permalink)
Mark Davis's Avatar
Thats a possibility but if a ground wire did come off it would hum al the time not just when the strings were touched.
Old November 5th, 2009, 04:57 PM   #8 (permalink)
Sea Devil's Avatar
Some people put anti-static laundry sheets under the guard, or rub them on the outside of the guard, to fix this problem. If it's mild, breathing on it will make it go away.
Sea Devil is offline   Reply With Quote
Old November 5th, 2009, 05:03 PM   #9 (permalink)
NasalFloss's Avatar
Thanks guys, much appreciated. Don't know if it makes any difference, but when i said that it seemed to be the neck pickup only the same problems happen with the bridge. There also seems to be a buzz when i'm not touching it. I know there is a certain buzz from single coils but it seems to have gotten louder. Maybe it's just my imagination...
Old November 5th, 2009, 10:46 PM   #10 (permalink)
Mark Davis's Avatar
Put the switch in the middle and see if that doesnt reduce the buzz.
Annoying clicking sound Clive Hugh Just Pickups 0 November 17th, 2007 08:09 PM
static clicking noise toadman Just Pickups 15 May 7th, 2007 07:42 PM
clicking type sound coming from 57 Twin RI SinnerBoy61 Amp Central Station 29 June 7th, 2005 06:09 PM
Did ya know, clicking sound bites COST $$$ lots??/ Buck Cannon Bad Dog Cafe 2 January 9th, 2005 01:58 PM
Changed pickups, now there is a clicking sound. Dana Tele-Tech 2 October 26th, 2004 12:11 PM
