Old October 12th, 2009, 03:17 AM   #1 (permalink)
aztwang's Avatar
62 RI..string retainer question
When I do a bend between the nut and the tuners on the B and E strings, they want to go slightly sharp and stay sharp. The problem goes away if I eliminate the string retainer. Is this a normal condition? This has the T style retainer.
aztwang is offline   Reply With Quote
Old October 12th, 2009, 03:44 AM   #2 (permalink)
Have you tried using a bit of graphite or some other lube like Nut Sauce on that string tree and nut?
BuddyLee is offline   Reply With Quote
Old October 12th, 2009, 03:46 AM   #3 (permalink)
aztwang's Avatar
no..i thought about it but all I have is WD
Old October 12th, 2009, 03:50 AM   #4 (permalink)
That's odd...what you're describing sounds like the strings hanging up in the nut slots.Could be that the absence of the retainer makes for less break angle over the nut,therefore less downward pressure from the strings,therefore less friction when you release a bend and the strings more easily slide back over the bottom of the nut slots.If you want to keep using the retainer,try lubing the nut slots.
Dave Hopping is offline   Reply With Quote
Old October 12th, 2009, 03:55 AM   #5 (permalink)
Some people use a pencil. I just bought the stuff they sell at my local shop, it is white so it does not mark up the nut.
Old October 12th, 2009, 05:21 AM   #6 (permalink)
aztwang's Avatar
ok...Cleaned and cked and lubed nut. Also added a bit of lube to string and retainer. Performed a full step+ bend at the 10th fret...tuning is spot on..both B and E. Performed a 1/4 to 1/2 step bend behind the nut and instantly goes sharp..again pull strings out of retainer and tuning is spot on again....Help..!
Old October 12th, 2009, 05:39 AM   #7 (permalink)
varakeef's Avatar
Sounds like too tight slot for string in the nut. If it's too tight, lubing won't help. If you don't have skill (and saddle files) to widen it, take it to guitar repairer.
Is the string retainer straight and in right place? The strings should go straight into tuner, if there's an extra kink due to retainer there it may cause problems. Retainer should just press the string down a bit, not sideways.
If you remove the noisy stuff inside the piano it makes a great house for a dog.
varakeef is offline   Reply With Quote
Old October 20th, 2009, 02:44 PM   #8 (permalink)
aztwang's Avatar
Thank you all...and yes the problem was in the nut.Needed to be opened up and smoothed out a bit.
Bruce's round String retainer bossaholic Telecaster Discussion Forum 25 September 19th, 2009 10:27 AM
String Retainer on Tele neck ttl100 Telecaster Discussion Forum 1 October 19th, 2007 05:30 AM
Need a string retainer for a Tele 12 String rhomco Tele-Tech 4 December 23rd, 2005 01:12 AM
Correct placement of string retainer? don Telecaster Discussion Forum 6 March 1st, 2004 04:36 PM
Why the addition of the D- and G-string retainer in the '70s Joel Terry Telecaster Discussion Forum 3 December 11th, 2003 03:35 PM
