Old July 24th, 2009, 04:18 PM   #1 (permalink)
Help me date my Tele
Hello all,
I have an oldish telecaster and need a bit of a hand in dating it before moving it on (I only have rom for one guitar in my life - my CS Esquire).
Some pics of serial numbers, pots etc have been posted on the following:
http://s258.photobucket.com/albums/h...e/1975%20Tele/
Would appreciate any help/opinions anyone on here can give.
Tanks!
Ian.
Telebuddy is offline   Reply With Quote
Old July 24th, 2009, 04:22 PM   #2 (permalink)
ajgus's Avatar
"Help me date my Tele"
Just be yourself. The rest will come naturally.
Seriously though...use the serial number. By the looks of it, I would definitely say '70s. It has that huge hump where the upper bout meets the neck pocket.
"...it's just a wonderful sound..."- GE Smith
ajgus is offline   Reply With Quote
Old July 24th, 2009, 04:26 PM   #3 (permalink)
Old July 24th, 2009, 04:30 PM   #4 (permalink)
ajgus's Avatar
Check out this site. Select 'Fender', enter your serial number...
http://www.guitardaterproject.org/
Old July 24th, 2009, 04:36 PM   #5 (permalink)
The pots are from the 49th week of 1973, which would lead one to think it's most likely a 1974.
dan1952 is offline   Reply With Quote
Old July 24th, 2009, 04:58 PM   #6 (permalink)
Since you can't date a vintage Fender guitar by the serial number, and neck plates are easily swapped, that site is pretty much useless for anything more than cursory research.
slack is online now   Reply With Quote
Old July 24th, 2009, 05:05 PM   #7 (permalink)
Telebuddy, it appears to be 74 or 75. To narrow it down even more you would need to post pics of the neck butt, neck base, neck pocket and there is a code stamped on the bottom of the bridge pickup bobbin (under the baseplate). If you have the info (but not the pics) I would ask what is stamped on the neck butt or base, if the neck pocket has five or six holes in it and what names are stamped there, and what's stamped on the bottom of the bridge pickup bobbin. I would also ask if the F tuners have holes in the bottom of the gear housing, with the shaft visible, or if they are fully enclosed. (Edit: Nevermind about the tuners, I enlarged one of your pics and can see that the tuners are pre-1976.)
Old July 24th, 2009, 05:25 PM   #8 (permalink)
ajgus's Avatar
Point well taken. However, assuming its his and he knows it to be all original, I think its an adequate tool for at least narrowing down the time frame of its origin. No?
Old July 24th, 2009, 05:38 PM   #9 (permalink)
I did say "that site is pretty much useless for anything more than cursory research." So yeah, if provenance is known, it is amongst much info on the web that can give someone an idea of how old a guitar is.
It's like the serial number dating info available in the resources section here, and at Fender's site, though - it's incorrect.
Old July 24th, 2009, 06:08 PM   #10 (permalink)
KevinB's Avatar
It looks like a very nice guitar - definitely mid 70s. Is there some damage to the back of the neck, or is that just wear? And has it been dropped, or is that just wear from a heavy strap?
Anyway, it's probably worth more than your CS Esquire!
Old July 24th, 2009, 06:46 PM   #11 (permalink)
Cheers for the responses so far! Will look at getting some more pics over the weekend.
I'm not the only owner (I'm only 34!) but have had it for about 4 years now. Not sure of it's life before me although it looks like it has been gigged - definitely ageing on the body and possibly some nicotine staining.
As for the neck it has some wear on it and also looks like it has had a little bit of filler to smooth it out.
As far as cost goes I'm really not too sure what something like this would fetch - I really can't see it ever replacing my CS Esquire!
Old July 24th, 2009, 09:17 PM   #12 (permalink)
TG
TG's Avatar
Damn. Beat me to it.
Old July 24th, 2009, 10:09 PM   #13 (permalink)
ajgus's Avatar
An oldie but a goodie
Old July 25th, 2009, 01:56 AM   #14 (permalink)
ole AZ's Avatar
This made me laugh...probably a bit too hard
"I could listen to Mike Campbell play me the phone book." - Yoni
ole AZ is offline   Reply With Quote
Old July 27th, 2009, 09:32 AM   #15 (permalink)
I took a quick look last night - the neck pocket and bottom of the neck have five holes in them, obviously 4 for the screws and one extra hole.
Being a doofus I completely forgot to take some phots! Will get some up shortly.
Thanks for all the help so far - it's helping me clear stuff up! Some guy from eBay offered £1300 for it as he said there were clear indications that there were up to 5 years age difference on some of the parts (he didn't confirm which parts though!). Personally I don't really believe what he says so this thread really helps!
Old July 27th, 2009, 10:08 AM   #16 (permalink)
KevinB's Avatar
It's probably worth at least double, if not triple, what he offered!
To date the guitar you should take the neck off - it's very easy to do. The end of the neck will probably (but not necessarily!) have a date stamped on it. You can only see it with the neck off. While you are there. take pictures of any markings on the body's neck pocket.
Old July 27th, 2009, 11:52 AM   #17 (permalink)
Seriously? That sounds like a lot of money! I am talking in pounds.
The neck stamp is 13014214.
Old July 27th, 2009, 12:19 PM   #18 (permalink)
KevinB's Avatar
Yes, UK pounds.
Here's a nice '79 at Elderly for $2,850.
Old July 27th, 2009, 02:33 PM   #19 (permalink)
I previously told you the guitar is likely a 74 or 75 model...
The last four digits in that neck stamp indicate 42nd week of 74 (and it was stamped well before the neck was even completed, much less installed on a completed guitar).
It is common (and correct) for the 7th digit in that 70s stamp to represent the year. However, there are lots of examples where that does not make sense (in this case, other clues dating it to the mid 70s and that stamp format not being used in 71). In those cases, like this one, you have to interpret the code in a way that makes sense (do that a lot and you recognize that the code is inconsistent, and sometimes the numbers are transposed).
Old July 27th, 2009, 04:36 PM   #20 (permalink)
Cheers slack - that helps a lot!
Ian.
Old July 27th, 2009, 06:01 PM   #21 (permalink)
blue metalflake's Avatar
Just to add to what Slack has advised, you have a code which may be contradictory to what it seems - I've struggled with such a code since I pulled the neck off my '73 for the first time, around 10 years ago.
As Slack says, code sometimes read model, neck, week, day, year but the last two seem interchangable.
Greg Gagliano did a lot on this and concluded that it was always model, neck,week, year, day.
On that basis, I had a guitar that had all the features of a '73 body, that I bought it in September '73 (and it needed some time to get to Ireland), yet appeared to have a '71 neck (ended 38 1 3). This of course was highly unlikely, as the coding system is recognised as having kicked in in '72. I now believe the last two numbers are transposed, and its week 38, day 1, '73.
Its more like looking at all the available evidence, and using it as a whole. Nothing on its own can be trusted to give an exact date, as they're all individual manufacturing codes/dates, rather than being co ordinated. Just like Slack says, use a bit of intuition and common sense, and hope to get near the right answer.
Bet you have a great guitar though.
blue metalflake is offline   Reply With Quote
Old July 29th, 2009, 06:10 PM   #22 (permalink)
Here are some more pics - and thanks again for the helpful answers/advice so far:
Old August 2nd, 2009, 11:44 AM   #23 (permalink)
Bumped to see if anyone has any more helpful info on this.
Will also be adding this to the classifieds soon for around £1500.
Cheers,
Ian.
Old August 2nd, 2009, 01:37 PM   #24 (permalink)
jwells393's Avatar
I looked at all of the pictures in your PhotoBucket album. I didn't see a serial number for the guitar. If you don't want to post the entire serial number (very understandable), why not the first couple of digits and the number of digits?
Old August 2nd, 2009, 02:03 PM   #25 (permalink)
Whoops - bit of a schoolboy error. The serial number is 615232.
Will add a pic later. Cheers!
Old August 2nd, 2009, 02:36 PM   #26 (permalink)
What other info are you looking for?
Old August 2nd, 2009, 04:11 PM   #27 (permalink)
Hi Slack - the added photos of the neck and neck pocket were in response to your post re what would be helpful to narrow it down more. I'mpretty convinced now that it is a 74 or 75 and not a partsocaster.
Really helpful responses on this one and they are much appreciated. I'm keen to not annoy the TDPRI community by keeping his thread running longer than is necessary. I think I have enough info now and have also built up a bit of knowledge!
Cheers!
Old August 2nd, 2009, 05:52 PM   #28 (permalink)
Telebuddy's '75 looks a lot like my '75,although his is cleaner and less modded(mine has a brass nut and Schallers),which brings up a question.His has the 3 saddle bridge.Mine has a 6 saddle bridge,which was on the guitar when I bought it used in July '77.Which bridge is stock for '75?
Dave Hopping is offline   Reply With Quote
Old August 2nd, 2009, 05:58 PM   #29 (permalink)
I previously asked for pics or the date stamp and you provided the date stamp. I've got nothing to add to what I've already said; it appears to be a solid 75 Tele (nothing in the pics raise any concerns).
Old August 2nd, 2009, 06:04 PM   #30 (permalink)
Probably the 3-saddle. The 6-saddle became available in 75. It's my opinion that starting in 1975 Tele Customs left Fender with either bridge, but that most if not all regular Teles left with the 3-saddle, though the 6-saddle was available as optional hardware at dealers and shops. Thus, in the 70s countless 3-saddle bridges on Teles from the 50s, 60s and 70s were swapped out for the 6-saddle bridge.
Old August 2nd, 2009, 08:45 PM   #31 (permalink)
jwells393's Avatar
The following serial number dating information is from the vintage guitar guru's website.
580000 to 690000 = 1975
Old August 2nd, 2009, 09:34 PM   #32 (permalink)
That serial number dating info (which is all over the web, including in the resources section of this website) is often, if not usually incorrect. That data makes no sense, is outdated and has been proven an inaccurate resource for dating vintage Fender guitars. It's okay for ball-parking a guitar I guess, if you know it's entire provenance and are certain it's all original, if you don't want to properly date it.
Old August 2nd, 2009, 09:45 PM   #33 (permalink)
jwells393's Avatar
So slack ............ are you saying the serial number dating information is always incorrect or sometimes incorrect. If I'm not mistaken you said yourself that it was a 74 or 75. I was just adding another source.
Old August 2nd, 2009, 10:03 PM   #34 (permalink)
Well, you selectively quoted me, from between sentences that answer your question.
That serial number dating info ... is often, if not usually incorrect. That data makes no sense, is outdated and has been proven an inaccurate resource for dating vintage Fender guitars. It's okay for ball-parking a guitar I guess, if you know it's entire provenance and are certain it's all original, if you don't want to properly date it.
So, no. I'm not saying that data is useless or always wrong. It can be right. It's just that in reality Fender serial numbers simply do not correspond to years like that, in some chronological order with clear cutoffs and stuff. That common and widely disseminated serial info is very often wrong.
I did. And more info, including the serial number, ended up supporting my original observation. But, the serial number: 1) Would be about the last thing to consider when dating a vintage Tele; 2) Only dates it to a range of years.
Old August 3rd, 2009, 09:30 AM   #35 (permalink)
jwells393's Avatar
That's often true with the vintage dating information found on the Fender website but for the years 1954 through 1976, the guru's website matches serial numbers to specific years.
Old August 3rd, 2009, 01:53 PM   #36 (permalink)
And I confidently assert that that is not possible with Fender serial numbers. It is possible to construct a database of serial numbers whereby you attribute those to specific years based on known guitars. Sure, you can be right a lot of the time, especially from, say, 54 to the early 60s; but this is not accurate dating.
So there's no misunderstanding here, can you please provide the link to the info and site you are referencing?
Old August 3rd, 2009, 09:26 PM   #37 (permalink)
jwells393's Avatar
http://www.provide.net/~cfh/fender.html
Old August 3rd, 2009, 09:40 PM   #38 (permalink)
The serial number info on Clay's site is the same info on lots of sites. And, again, it's inaccurate.
Old August 3rd, 2009, 10:36 PM   #39 (permalink)
Some examples....
From that widely disseminated serial number dating info:
"S8 + 5 digits = 1977-1978"
S8 prefix serial numbers were used from 1978-1982 (and maybe early 1983). Just this afternoon someone asked me about a 1978 Tele with an S8 serial. He insisted it was from the 70s. It was full of 1981 date codes.
"580000 to 690000 = 1975"
"690000 to 750000 = 1976"
There are lots and lots of 1974 Fender guitars and basses with serial numbers in 600000s.
"280000 to 300000 = 1970"
Pg. 76 of Duchossoir's book references a Tele with 300612 serial and MAR70 neck stamp.
"370000 to 520000 = 1973"
Pg. 76 of Duchossoir's book indicates 400000s were used April 1973 to September 1976 (which I also don't agree with).
"L00001 to L20000 = 1963"
Pg. 78 of Duchossoir's book shows several serial numbers in that range with 62 neck stamps.
You get the idea. There is no dating a vintage Fender guitar by serial number alone, and there is no accurate serial number dating chart for vintage Fender guitars.
Please help me DATE this Tele earthling808 Telecaster Discussion Forum 10 May 2nd, 2009 07:25 AM
Can someone help me date my tele? smmjbarney Telecaster Discussion Forum 8 March 29th, 2008 05:45 PM
Date this Tele scat4me Telecaster Discussion Forum 8 October 16th, 2007 10:02 PM
How to date a Tele... Stefan Telecaster Discussion Forum 12 February 2nd, 2007 04:25 AM
Need help with a Tele date 70-71? Kurzman Telecaster Discussion Forum 22 January 15th, 2004 11:49 PM
