Is it possible to reduce "plink" in a tele?
I have a partscaster e-type that is made up of a 60's tele body/pickup and a Nocaster neck, and a 52 ri bridge plate/saddles. It is very twangy, has some bell like tones, but also has some plink. The guitar is very well set-up, good neck to pocket fit, and has plenty of threads under the saddles. The strings are Fender 150s 10-46's.
Should I try different strings, a modern style bridge, anything else? If I decide to roll another partscaster, what is the basic recipe for a "bell" like tele? |
How's your action? Low, medium low? In my case I raised the action from 4/64 to 5/64. Big difference in tone and feel. Reduced some "plink" and added some "beef". I also lowered the pickups a tad. I'd start there before trying the bigger mods.
Lots of opinions here. Many say that esquire style guitars sound more chimey and bell like because of the reduced magnet draw. That might be the sole recipe right there.
"I could listen to Mike Campbell play me the phone book." - Yoni |
Change the strings first thats the cheapest thing to do use pure nickel strings they are a tad darker than the nickel wrap ones.
If its still too twangy get a Callaham bridge that will kill some of the twang and replace it with a tad more sustain.
I'm so blind my seeing eye dog needs glasses. |
Moderator
You say it's well set up, but IME "plink" usually comes from either a) the action being too low, b) a reverse bow in the neck, or c) a fret problem, which is much less common. Try raising the strings slightly and see if that doesn't help. Best of luck, CS
"I go online sometimes, but everyone's spelling is really bad. It's depressing." – Tara, from "Buffy the Vampire Slayer" "It was born at the junction of form and function." – Bill Kirchen, from "Hammer of the Honky-Tonk Gods" |
By plink do you mean "articulate"? Meaning sharp, quick response, but a lack of sustain in some situations, kind of like a jag? It's one of those terms like "Dark". From what Mr. Davis wrote he and I have the same definition of dark. But when I talk to gibson guys I have no idea what they mean by dark...
VENDOR
You want sumptin cheaper than Mark's suggestion ?....turn your pick over to one of the rounded corners, instead of using the point (assuming you're using a std. 351 style plectrum) ?
#8 (permalink) | |
plinkiness ? i take that to mean a two sizes too light string gauge with thin plectrums and/or the action set too low type of sound, easily remedied. Bell tone.....depends on the timbre you imagine your Tele-bell having... is it Big Ben like, or a top-of-it's-range Glockenspiel ? your picking/attack is a large part of it, and your amp has a fair bit to do with it also.... can you post some examples of what you're trying to describe so we're all on the same page ? |
#9 (permalink) | ||
I can get bell like tones with a light touch, but am trying to get them with a little more force. I have tried raising/lower the string height and have found the optimal. The plink is not really that bad, but it is there and may be a result of the vintage style bridge and the old grey bottom pup. The guitar out twangs the 3 Nocasters I used to own. And, it does rockabilly with the best of them. I'll give pure nickel strings a try. But, I'll probably part the guitar out. I've talked to another forum member and have another guitar on the way that is supposed to cure my woes, but that is 3-4 weeks out. |
| "Fatter" "Rounder" "Thicker" still "Twangy" Tele pickups? | BMKindoll | Just Pickups | 45 | August 19th, 2009 03:25 AM |
| Bakersfield CBS Era TELE WRING - "1-Meg" Volume "250k" Tone | Don Mare | Tele-Tech | 35 | April 9th, 2009 05:54 AM |
| Av 52'RI Tele - "Vintage" vs "Modern" Switching Circuit... | Axtklinge | Telecaster Discussion Forum | 21 | August 30th, 2008 09:03 AM |
| Finally- The "butcher block" Tele "Lite" Special | reddogbass | Telecaster Discussion Forum | 14 | October 25th, 2007 04:36 AM |
| "plink, plink" | ye olde fretmonkey | Bad Dog Cafe | 17 | April 15th, 2006 05:47 PM |
