Anyone ever sand a vintage style bridgeplate to crazy thin?
The typical stock Fender vintage plate is .045-.050 inches, thickness.
We know than sanding the underside and getting it flat is a good deal. Has anyone kept right on sanding until the plate was .030 or even .025? What does the guitar sound like with a super-thin plate? Squeal City? Or enough twang to tie your ears in a knot?
When i listen |
As long as its flat and the pickup is potted it wont squeal.
Ive sanded them so its completly flat but never went nuts and tried to make it paper thin.
I'm so blind my seeing eye dog needs glasses. |
Hey Boris,
I ordered one to put on my 2008 HWY 1 tele. I just liked the look of the vintage one. I spent about 1 hour sanding the bottom as flat as I could get it. I had to take a few breaks, I worked up one heck of a sweat! I used several sheets of 80 grit sand paper. After an hour I still didnt get the very center as flat as the rest of the bridge. I went ahead and put it on anyway. I tried it for a few days but all of the sustain and the "certain" sound my tele had unplugged and plugged in had gone. Parts of the body that would vibrate didnt vibrate as much or at all. I put the old bridge back on...before I did I checked it with 80 grit sand paper to see how flat it was....It was dead flat!!!!. I put it back on and all the sustain and sound was back. The original bridge looked better made than the vintage which really suprised me. The original seemed just a bit heavier before I sanded the vintage. PM me if you would like the vintage bridge, I will send it to you for free and you can sand some more of it to do your test! PS Youre advice and info on the new tuners for my tele was spot on. The new vintage tuners look great and work perfect. The conversion bushings where a perfect fit. |
I went a different way. Bought a body that required a standard bridge. I was intrigued by Melancon Guitar take that drops the bridge pup directly into the body and not mounted on the bridge. My neighbor had a lathe, so I cut the pickup portion out - mounted the pickup directly to the body and kept the brass bridge at full thickness. To my ears, it did take some of the highs off but kept the resonance. Consider cutting the bridge in half and leaving the thickness alone.
If the bridge isnt flat it can make a harmonic vibration that starts the feedback chain.
I just used 320 grit black sandpaper wet on a known flat surface.
#10 (permalink) | |
Yeah, I've been fooling with half bridges, also: ![]() This Taipan/No-caster didn't kill played through the RI Twin, but through the Custom Vibrolux, yum!
When i listen |
#11 (permalink) | |
* I guess it shouldn't be too big a surprise - surely Dale Clark or somebody would've tapped into the extra twang if a thinner plate got you there. Here's what will happen. Some science guy will devise a means of establishing which frequencies a particular neck and body respond most favorably to. Then the bridge plate will be custom milled from billet to respond to the favored frequencies, like a tuned pipe on a motorcycle. Or, if the guitar sounds too 1 dimensional, to the harmonics of those primary frequencies. BTW the Taipantone plate showed above is .060. Fender and Glendale are still the skinny plate kings!
When i listen |
#12 (permalink) | |
And there's nothing wrong with that. Instruments designed by musicians usually sound better. |
boy, those glendale cold rolled steel plates are thin! i swapped out a 52 fender plate for one and it looked and felt considerably thinner. both plates sounded fine, with the glendale having more brilliance and clarity. was this because of the thinner plate? who the hell knows.
my band's myspace. featuring our new video! http://profile.myspace.com/index.cfm...ndid=261142458 |
| Replacing MIM bridgeplate with lighter Vintage | nlopez | Telecaster Discussion Forum | 11 | April 3rd, 2009 09:49 PM |
| Gone crazy - body style | robbysturgis | Telecaster Discussion Forum | 5 | September 18th, 2008 12:38 PM |
| My first neck finish. Wet sand vs. dry sand? | jguitarman | Tele-Tech | 5 | March 18th, 2008 07:25 AM |
| Desert Sand on a Vintage Telecaster? | tonewoods | Telecaster Discussion Forum | 7 | August 9th, 2007 01:47 PM |
| Can I just sand the finish to thin down the poly coat | halfmassive | Tele-Tech | 17 | November 30th, 2005 03:48 AM |
