Tuners upgrade
I have decided I need to upgrade the tuners on my Squire Custom II as I bend alot and she gradually goes out of tune as I am playing.
I have never swapped out tuners before, anyone know of a good set that will be a straight swap? thanks in advance! |
Try wilkinsons they are excellent aftermarket tuners.
http://www.axesrus.com/axemachine.htm#6inline |
Your tuners are fine You need to strech your strings.Tuners have to be really bad before they make your guitar go out of tune.When you put new strings on pull on each string at the 12th fret until it's out of tune.Repeat untill it stop going out of tune.Do this to each string.Every few days do this same process and I think you'll find your tuning problems have gone away.Better tuners will give you smoother tuning but they won't keep your guitar in tune.The sealed tuners on your Squire are not slipping ,trust me..I have lots of guitars with good and cheap tuners including a Squire Tele and they all stay in tune just fine if I strech my new strings.Even my 50's Supro with terrible 50 year old klusens stays in tune.
I agree the problem is more likely at the nut. From what I understand, the nuts on the massed produced guitars are rarely cut well. IMO I would pay the $30-$40 first on a quality bone-nut cut properly by a tech.
Another thing .Go to your local store or Musicians Friend and buy some Big Bends nut sauce.Put it on your nut ,bridge pieces,etc. I started using this 2 years ago and I've only broke one string on my 5 guitars since.I used to use vasoline and grafite but I still broke strings.This will also really help any nut problems.It's $19 a tube and I'm still on my first tube after 2 years and 5 guitars so a little goes a long way.A miracle product.
#9 (permalink) | |
VENDOR
#10 (permalink) | |
You have one of three problems:
With #2... Well, new strings need a little stretch to settle into holding a tune. Just give the bottom four a good yank and then tun back up. The B and high E... Just bend the snot out of them like you're SRV then tune them back up. With #3... The way gears work is that when there's no pressure on them there's a little slack. Some gears have better tolerance than others, but all tuner gears function the same when there is pressure. The pressure comes from string tension. If you tune up to the note you want you're going to get pressure on the gears which will hold them in place. If you tune down, you're allowing for slack. |
Thanks for your replies. The Nut info is something I didnt know about. I do always stretch strings when I put new ones on.. however these were put on by the shop owner.
I put new decent ones on (as these were only ernie balls) and now she stays in tune! I just cant believe how much I like this Tele and I cant believe how cheap they are. I just cant fault it. Tempted to buy another for a 'backup' (justification), feel like I have found a treasure. When I pickup one of my other guitars for a change I find myself glacing over to the custom II and plugging her back in again. |
| Anyone upgrade the stock Martin tuners to Waverly? | timmer | Acoustic Heaven | 11 | November 11th, 2008 10:06 PM |
| Vintage Style Tuners for Highway 1 (2005 Upgrade version) | PhillyGTR | Tele-Tech | 12 | May 18th, 2008 01:50 PM |
| Gotoh slot head tuners to locking tuners | spacebar | Tele-Tech | 1 | February 25th, 2008 09:04 PM |
| Grover tuners vs All Parts or Mighty Mite tuners | tele_jas | Telecaster Discussion Forum | 2 | March 2nd, 2006 11:05 AM |
| Should I upgrade to staggered post tuners? | prossi | Stratocaster Discussion Forum | 6 | March 18th, 2005 09:47 AM |
