Make a donation with PayPal Musician's Friend Stupid Deal of the Day
Old April 20th, 2009, 08:03 PM   #1 (permalink)
Anyone ever stripped a Classic 50's tele?
Anyone ever stripped a Classic 50's tele, and had trouble refinishing it. The paint I've got isn't taking to the old body, and the old poly finish wouldn't strip with anything I used so I sanded it.
lots of help please, and thanks..................
Anybody ever notice how bad my speling is in my posts?
Luther Perkins is online now   Reply With Quote
Old April 20th, 2009, 09:19 PM   #2 (permalink)
Lerb21's Avatar
I'm working on a bass right now... sanded it with 150 grit and the paint stuck like glue.
YMMV
Best of luck.
If it don't twang then it ain't worth havin'!
Lerb21 is offline   Reply With Quote
Old April 20th, 2009, 10:08 PM   #3 (permalink)
Mark Davis's Avatar
Here is a 50's Classic stripped using a sander.
I know lots of guys that have just roughed up the surface and painted right over it.
Maybe you used a silicone type wax that got impregnated into the finish?
Old April 20th, 2009, 10:18 PM   #4 (permalink)
surfoverb's Avatar
I stripped my poly finished CIJ with 120, 220, and finally 320 sandpaper by hand. Major PITA but well worth it!
After stripped I grain filled, then sanding sealer, and next is color coat once it stops raining. After that some clear nitro and its done.
"You released the ******* fury!"
Old April 21st, 2009, 12:06 AM   #5 (permalink)
JimmyJam's Avatar
I just did this about 2 weeks ago. Citristrip didn't work. Heat gun definitely did.
I used Formby's Paint and Poly remover to strip the front, it worked well.
JimmyJam is online now   Reply With Quote
Old April 21st, 2009, 12:24 AM   #6 (permalink)
JimmyJam's Avatar
Now I don't feel so bad. I thought what I did was sacrilege. Although consensus may say otherwise once I post the pics. I went for the mythical BSB, but in stain so I could still see the grain of the wood. Used tru-oil to finish ( I think Mark Davis did the same), couple of thin coats, just enough to seal it. Sanded down it is smooth and velvety. Kind of like those Highway 1 satin finishes.
Back on topic, I noticed I had a hard time controlling the heat gun method through the 3 layers of poly. Last layer of poly - Once it bubbles you gotta stop fast, otherwise you get charred geetar. If you try this, I recommend starting on the back near the buckle rash area. This way you get the feel for this method.
Formby's worked the best for me. I still had to sand some areas down in the last layer of poly (120 grit). Good luck. Keep us posted.
Old April 21st, 2009, 02:04 AM   #7 (permalink)
JimmyJam's Avatar
Pics of the heat gun method. The last layer looked like crappy veneer before I hit pay dirt.
I'm kind of scared to post this pic of my BSB attempt. But let's get it over with, go ahead and laugh. I don't care. Donning flame suit now.
Last edited by JimmyJam; April 21st, 2009 at 02:05 AM. Reason: last layer description correction.
Old April 21st, 2009, 02:15 AM   #8 (permalink)
ccrnnr9's Avatar
What's to laugh about. It looks good from here for BSB.
~Nick
ccrnnr9 is offline   Reply With Quote
Old April 21st, 2009, 08:47 AM   #9 (permalink)
Alamo's Avatar
Hahahaha - it's got no hardware and no nuthin' on it, like butt naked
is that it? is that it?
other than than, it looks fine
Timebandits-Berlin
Alamo is offline   Reply With Quote
Old April 22nd, 2009, 04:56 PM   #10 (permalink)
What did you all use to strip the body, cause I used 5f5 and it didn't even take any of the poly finish.
Old April 22nd, 2009, 05:10 PM   #11 (permalink)
Dizi's Avatar
Originally Posted by JimmyJam View Post
All thats missing here is the torn shower curtain, bloody knife and screeching violins!
Dizi is offline   Reply With Quote
Anyone stripped a strat or tele body and left it stripped? appar111 Telecaster Discussion Forum 22 August 22nd, 2008 07:02 PM
50's Classic vs. 60's Classic Tele J-man Telecaster Discussion Forum 31 April 24th, 2007 12:00 AM
50's Classic vs. 50's Esquire vs. 60's Classic? rockawayrocks Telecaster Discussion Forum 8 April 9th, 2007 01:36 PM
Any difference btw. Classic 50's and Classic 60's Tele Neck? blackkeysfan Telecaster Discussion Forum 6 December 31st, 2004 07:59 AM
stripped polyester off Classic 50s Tele MRK Telecaster Discussion Forum 11 January 8th, 2004 06:22 AM
