Argggg - how do I stop fret wear? - Telecaster Guitar Forum
Old April 13th, 2009, 06:52 AM   #1 (permalink)
Last summer I bought a beautiful blond tele and an old Les Paul in immaculate condition.
After a few months both started showing fret wear - as a result the Les Paul's become a case queen that I only pull out for recording and the tele will likely go that way too.
I tried wiping strings as often as I can remember to do so - and using that fast fret stuff - but for me frets still wear. It's freaking annoying.
http://www.myspace.com/soshush
ianasdfg is offline   Reply With Quote
Old April 13th, 2009, 07:20 AM   #2 (permalink)
Rob DiStefano's Avatar
fret wear is like car brake wear - both are inevitable, particularly if used daily.
wiping the frets ain't gonna help at all with where the wear comes from - metal-to-metal contact.
perhaps yer a candidate for s/s frets?
Old April 13th, 2009, 07:22 AM   #3 (permalink)
Nothing will stop fret wear, but large flatwound strings will wear the frets out slower. They also sound great.
I hope that helps.
imsilly is offline   Reply With Quote
Sponsored Links   #
Old April 13th, 2009, 07:27 AM   #4 (permalink)
far and away, flatwounds are s/s tape wound, which is harder than steel or nickel wound roundwounds, thus faster fret wear.
Old April 13th, 2009, 07:29 AM   #5 (permalink)
thanks will check out both suggestions.
Funny thing is I played in a band for ten years with an amazing guitarist who had an old strat - despite all the sweaty clubs, hot lights, smoke, outdoor festivals, etc he never seemed to get fret wear.
Maybe he just had regular refrets and never mentioned it.
Old April 13th, 2009, 07:29 AM   #6 (permalink)
Super Moderator
jkingma's Avatar
Stop fret wear = Stop playing
...and nobody wants to do that. Frets wear, so live with it and replace them when necessary.
Creator of Fine Sawdust and Expensive Kindling
Old April 13th, 2009, 07:30 AM   #7 (permalink)
Scotland's Avatar
Unless you use S/S frets, you can't stop it. Do you want the guitars to just look at or for playing also?
If it's for playing then play them, frets can take years of wear before refretting is required. No big deal when they need refretted either so I'd stop being worried and just play them.
Old April 13th, 2009, 07:32 AM   #8 (permalink)
Scotland's Avatar
None of the above wears down frets. String metal rubbing on fret metal, that is all it is.
Old April 13th, 2009, 07:32 AM   #9 (permalink)
jefrs's Avatar
Fret wear is inevitable but if both are showing excessive fret wear in less than a year then I suggest the cause is yourself - are you pressing down too hard? A lighter touch is quicker, don't fight the instruments. And don't stop playing them.
Old April 13th, 2009, 07:36 AM   #10 (permalink)
My guitars suffer likewise...then again, they have a herd of elephants tramping up and down them on a daily basis!
Maybe your guitars suffer from the same syndrome. Do you have a heavy touch?
“Everything we hear is an opinion, not a fact. Everything we see is a perspective, not the truth.” -Marcus Aurelius AD 121-180
"There is no charge for awesomness, or attractiveness." Kung Fu Panda AD 2009-2010
Tonemonkey is offline   Reply With Quote
Old April 13th, 2009, 07:38 AM   #11 (permalink)
... or the fretwire is too soft (i.e. 12% nickel-silver and not 18% hard nickel-silver). string gauge can matter as well - 11's wear frets faster than 9's. or, it's just you and the way you play. don't change yer playing, change yer worn frets.
Old April 13th, 2009, 07:43 AM   #12 (permalink)
Ronkirn's Avatar
Not only is Scotland Wise.. He’s double wise, he lives where they make the nectar of the Gods…. Single Malt….
Fret wire is directly related to your fingering style. The only way to stop it is to relearn, not at all an easy thing to do.
Stainless frets are made of a harder alloy, but are still softer than the strings; they have to be to allow for fret work. Were they the Stainless we are most familiar with, they would wear out the typical fret tools. Thus the Stainless fret’s hardness falls somewhere between that of the Nickel silver and the more commonly encountered Stainless Steel we use to cut out Steaks with.
The conventional frets are all made from about the same alloy, an 18% nickel silver. It has no Silver (Ag), but is an alloy of brass containing Nickel. There are a few cheepo frets available having less nickel, perhaps?? Thus all wear about the same. There are a few “off the mainstream” frets available, but who cares.
Ron Kirn
Be careful when you follow the masses, sometimes the M is silent.
Holiday Sale alive and well...
http://ronkirn.com/holiday.htm
Ronkirn is online now   Reply With Quote
Old April 13th, 2009, 07:45 AM   #13 (permalink)
It's usually the first three frets that go from strumming open chords - although I solo a lot the upper frets are fine.
Maybe it's because my first guitars were really crappy things with high actions
so I've just gotten used to pressing chords down hard.
Old April 13th, 2009, 07:54 AM   #14 (permalink)
Scotland's Avatar
Are you talking about actual fret wear or just indents on the frets ?
Old April 13th, 2009, 07:56 AM   #15 (permalink)
Roli's Avatar
18% nickel steel hardness is about 170 HB (Brinell hardness), stainless steel frets have around 40 HRC (Rockwell hardness C scale), which falls around 375 on the Brinell scale. So stainless steel frets are more than twice as hard as the hardest nickel silver ones.
So I say, go for stainless steel frets and you'll be set.
Sources: http://www.sintoms.infonet.by/FretsProduction.htm
http://www.engineersedge.com/hardness_conversion.htm
http://en.wikipedia.org/wiki/Brinell_hardness_test
http://en.wikipedia.org/wiki/Rockwell_hardness
[COLOR="LemonChiffon"].[/COLOR]
Roli is offline   Reply With Quote
Old April 13th, 2009, 08:06 AM   #16 (permalink)
It's indents that become fret buzz - I have an Ovation that's now unplayable because of it. Fortunately I know a tech who could probably sort it out - but the thought out handing something as precious as my Les Paul over for filing or refretting makes me a little queasy- not that the wear has got to that stage yet.
Fortunately with teles I much prefer classic players to expensive US standards - but they're still precious to me.
Old April 13th, 2009, 08:10 AM   #17 (permalink)
Thanks Roli - for the very useful info.
Old April 13th, 2009, 08:20 AM   #18 (permalink)
You could stop playing, but then you'll suck on the guitar...that will make you one of those guys that owns nice guitars but can't play. Wear those frets down, replace as needed!
psychotelepathic is offline   Reply With Quote
Old April 13th, 2009, 07:53 PM   #19 (permalink)
PJ
PJ's Avatar
I find Fender frets wear quicker than Warmoth. I have a Warmoth neck, with normal nickel-silver 6105s on it and after a few years, I see no fret wear. Fenders I have wear quicker. So, I had one of my Fenders refretted with SS frets. For just that reason. And, I like them a lot. A tad snappier in the tone department, but you can easily rolloff a little of the highs, which you probably do to some extent anyway.
PJ
"I don't know if it's art, but I like it."
PJ is offline   Reply With Quote
Old April 13th, 2009, 08:02 PM   #20 (permalink)
is there some sort of catch with ss frets? i'm assuming they're much harder for a luthier to work with, but do they have any drawbacks from the player's perspective?
jivetrain is offline   Reply With Quote
» Random Photo for Guests
Rotting Pinata`
» Recent ThreadsGuests
Fender Logan Custom Guitars
