Old February 5th, 2009, 09:25 AM   #1 (permalink)
g6120's Avatar
clicking out of tune string - pencil lead
the other day noticed while tuning one of my guitars a pinging sound and determined the string was making the noise at the nut so i broke off a small piece of pencil lead crushed it and placed in in the slot and so the string also stayed in tune better without that clicking sound as well had no problem since .
just wondering what other folks are using for that sort of ailment .
anyone use this
http://www.stewmac.com/shop/Nuts,_sa...lubricant.html
g6120
g6120 is offline   Reply With Quote
Old February 5th, 2009, 09:37 AM   #2 (permalink)
repeatofender's Avatar
Similarly I "draw" into the nut groove with a pencil when I change strings.
It makes the biggest difference with tremolo equipped guitars.
repeatofender is offline   Reply With Quote
Old February 5th, 2009, 09:39 AM   #3 (permalink)
VENDOR
Ronkirn's Avatar
at the hard ware store, you can buy white graphite powder. That way you don't have black crud on the nut.., if such things are important to ya.
Ron Kirn
www.ronkirn.com
Old February 5th, 2009, 09:42 AM   #4 (permalink)
Ron Kirn
I like the psuedo "grease monkey" appeal to the black smudges...
I'm odd I know it.
Old February 5th, 2009, 09:45 AM   #5 (permalink)
g6120's Avatar
Ron Kirn
hi ron
maybe today i take a ride to my local hardware store and check it out and the thought of grease i would think can attract dust ? but i guess a trace amount would not cause such .
g6120
Old February 5th, 2009, 09:49 AM   #6 (permalink)
CHAZ2's Avatar
anyone use this
have used pencil lead for years, works great
" "There's nothing wrong with it"
www.myspace.com/thechazsessions
CHAZ2 is offline   Reply With Quote
Old February 5th, 2009, 09:59 AM   #7 (permalink)
g6120's Avatar
you know i often wondered having this problem is it a common occurance with other guitars ive had but just lived with it . tried the pencil lead thing and it did the trick and also as the guitar ages with play i would imagine the nut wares and the sticking of that string goes away at some point -
wonder if this is something a tech could cure or do most peolpe just place a lub or lead in the slot instead of paying $
g6120
Old February 5th, 2009, 10:10 AM   #8 (permalink)
CHAZ2's Avatar
Well i'm no tech, not by a long way.... but its an age old probem especially guitars with wammy bars...strings can hit a tight spot and jump , especially the wrapped strings...i also use Vaselene..............on the guitar i mean....
Old February 5th, 2009, 10:10 AM   #9 (permalink)
Dave Yeats's Avatar
hi ron
Graphite isn't greasy. It's a dry lubricant. I have a small tube of graphite, but I've never seen it in white. Nice to know...
Dave Yeats is offline   Reply With Quote
Old February 5th, 2009, 01:46 PM   #10 (permalink)
VENDOR
Ronkirn's Avatar
Yep the graphite is a powder available in a small "puff" tube... it's available in the normal Black an in a White version..
rk
www.ronkirn.com
Old February 5th, 2009, 05:33 PM   #11 (permalink)
g6120's Avatar
just ordered
GHS GraphitAll Guitar Nut Graphite Lube cream colored
did not get it from musicians friend but this is what it looks like
http://accessories.musiciansfriend.c...&CJPID=1350534
g6120
Old February 5th, 2009, 06:07 PM   #12 (permalink)
buddywayne's Avatar
I use chapstick and pencil lead with good results.
buddywayne is offline   Reply With Quote
Old February 5th, 2009, 06:13 PM   #13 (permalink)
BritishBluesBoy's Avatar
The tech at Andy's Guitars in Denmark street, London showed me the pencil lead trick in about 1982 and I've been using it on all my guitars ever since.
BBB.
Old February 5th, 2009, 07:56 PM   #14 (permalink)
Geo
Geo's Avatar
Just curious, was it the B string that made the ping?
"Somewhere between culture and agriculture"
Geo is offline   Reply With Quote
Old February 5th, 2009, 08:18 PM   #15 (permalink)
g6120's Avatar
it may have very well been the b string but ive decided to put a bit of lead in each of the slots on the nut and noticed an improvement overall .
g6120
Old February 5th, 2009, 08:28 PM   #16 (permalink)
adifferentbreed's Avatar
I use chap stick on mine..never have that problem.
Dig the Blues? Check out the Blues Republic!
http://www.bluesrepublic.org
"Life is just a tire swing"
adifferentbreed is offline   Reply With Quote
Old February 5th, 2009, 08:52 PM   #17 (permalink)
robinje's Avatar
What about that Big Bends Nut Sauce stuff... any good?
Rockin' Robin
robinje is offline   Reply With Quote
Old February 6th, 2009, 02:09 AM   #18 (permalink)
BellyBoy's Avatar
Nut sauce works great but is pretty expensive.... I use vaseline mixed with white graphite, works awesome and stays where you put it. And I have a life time supply with one small jar and a small bottle of Graphite.
I mixed it up and got a syringe from a do it yourself ink printer cartridge kit and put it in the syringe. I just squeeze out a little bit and use a toothpick to put it in the slots.
BellyBoy is offline   Reply With Quote
Old February 6th, 2009, 03:29 AM   #19 (permalink)
JPark's Avatar
ahahaha yeah, I had this problem (or one similar to it) on my brother's guitar, the e string rang like a sitar, so as a quick fix I put a small piece of tissue under the string on the nut. Problem solved
JPark is offline   Reply With Quote
Old February 6th, 2009, 12:21 PM   #20 (permalink)
Interesting! I learned a new thing today!...I never thought using the graphite from a pencil as lubricant...excellent!
BlueRob is offline   Reply With Quote
Old February 6th, 2009, 01:49 PM   #21 (permalink)
I use the Nut Sauce already mentioned, as well as the ancient pencil lead remedy. Both work equally well in my experience.
bowman is offline   Reply With Quote
Old February 6th, 2009, 01:58 PM   #22 (permalink)
guitarzan13's Avatar
just ordered
That is great stuff.....To make it last.... I use a piece of the b or g that I just took off, stick it into the tube opening and smear it into the nut slots. Very little wasted....
TIP: I restring the guitar ,tune to pitch, lift the strings from the slot,THEN lube the slots. If you put it in and then tune most of the lube ends up about 1/2 inch up the string toward the post. It doesn't do much good there!
Practice make permanent!!!!....Perfect practice makes perfect!!!
Chris B.
www.neonjones.com
guitarzan13 is offline   Reply With Quote
Old February 6th, 2009, 02:06 PM   #23 (permalink)
refin's Avatar
All the above suggestions are good.
But first,check the slots to make sure that they are cut properly.I have a strat that I made a nut for,and I'm gonna have to recut a few slots because of the pinging (too tight).
"For You,Lord,are good,and ready to forgive,and abundant in mercy to all those who call upon You."
Ps. 86:5
http://www.soundclick.com/bands/0/refin_music.htm
MASTER VOLUME? WHAT'S A MASTER VOLUME?
refin is offline   Reply With Quote
Old February 6th, 2009, 06:02 PM   #24 (permalink)
I used to use the 'draw into the nut' technique with a pencil. It does work great, but found it made my nut look really dirty. I bought some 'nut sauce'. it comes in a little syringe. It has lasted me years. I bought it initially for a strat (to aid with whammy action) and it worked a treat. But now i only have teles I have found just a little goes a long way and makes a difference.
rcalverley is offline   Reply With Quote
Old February 6th, 2009, 06:31 PM   #25 (permalink)
JDaveG's Avatar
REAL good.
I don't know if it's any better than pencil lead, graphite or chapstick (never used any of those). For all I know, I'm wasting money on Big Bends, but that stuff cured my tuning ills on my PRS.
JDaveG is offline   Reply With Quote
Old April 24th, 2009, 10:54 AM   #26 (permalink)
TxTeleMan's Avatar
I take the paper envelope that the sting comes in and rub a pencil point along the edge, and then slide the 'penciled' envelope through the nut slot. This works pretty well in those thin slots that are too small to put a pencil point in, plus it's more precise and less messy than using a pencil point.
"Every musician adds something to a song; some when they play, and some when they don't."
-G. R. Storey
TxTeleMan is offline   Reply With Quote
Old April 24th, 2009, 11:50 AM   #27 (permalink)
Daddydex's Avatar
I go at it with butter knife, a filet knife and a piece of sandpaper and never have to lube again. Call me MacGyver.
Dan
My Music Page
Daddydex is offline   Reply With Quote
Old April 24th, 2009, 12:59 PM   #28 (permalink)
Boubou's Avatar
Ron Kirn
Wow, I really hat to disagree with ron Kirn, who am i after all.
Graphite is black.
Google
wikipedia:
Another high-temperature lubricant, hexagonal boron nitride, has the same molecular structure as graphite. It is sometimes called white graphite, due to its similar properties.
Phew, as a chemist i am glad to confirm that graphite is still black!
Actually, Ron was right, it is called : white graphite powder
Anyways, got to try the pencil lead at my next string change
Originally Posted by David Gilmour
EVH was a major influence on a lot of people, wasn't he? He changed rock music , and made a lot of very average players think they were a lot better than they actually were!
Boubou is offline   Reply With Quote
Old April 24th, 2009, 01:22 PM   #29 (permalink)
twangus's Avatar
I have a bottle of graphite powder that I got from a local locksmith. It's lasted me for years. Can get a little messy if you've been simultaneously lubing your tummy up with your adult beverage of choice though.
...course that's why a shopvac is never a bad investment.
twangus is offline   Reply With Quote
Old April 24th, 2009, 03:57 PM   #30 (permalink)
VENDOR
mellecaster's Avatar
A properly cut slot w/ a Sho-nuff Nut File works very well also....
Old April 24th, 2009, 04:32 PM   #31 (permalink)
Hiflyer's Avatar
Originally Posted by rcalverley View Post
... but found it made my nut look really dirty.
ok, I
Hiflyer is offline   Reply With Quote
Old April 25th, 2009, 12:52 AM   #32 (permalink)
I don't think anyone mentioned that pencils aren't lead anymore.......I think they are....um...graphite. When i used to frame houses,and someone would get a big piece of sawdust in their eye,I would get it out with a pencil, not a sharp skinny one,of course,but the fat carpenter one. The wood sticks to the graphite like a magnet.
Click on my name to see a couple more carved guitar threads .:
jimmybusk is offline   Reply With Quote
Old April 25th, 2009, 01:44 AM   #33 (permalink)
gitold's Avatar
Big Bends is the best .I used grafite and vasoline for years and it worked well but since I've been using Big Bends (2 years now on 5 guitars ) I never, I mean NEVER break strings any more.Including a Strat with a Wang Bar.I've had 1 tube that I paid $19 for 2 years ago.Pretty cheap if you ask me.
gitold is offline   Reply With Quote
Old April 25th, 2009, 09:57 AM   #34 (permalink)
cotecj's Avatar
Originally Posted by JDaveG View Post
REAL good.
You're not wasting your money. Big Bends works much better than pencil graphite.
cotecj is offline   Reply With Quote
Old April 25th, 2009, 12:19 PM   #35 (permalink)
some claim pinging noise can be due to a loose nut
pjam is offline   Reply With Quote
Old April 25th, 2009, 09:29 PM   #36 (permalink)
VENDOR
Ronkirn's Avatar
Well I gotta tell ya, while I was out buyin' stuff I didn't need or want, I thought I'd pick up a tube of the "White Graphite" .. They looked at me like I was a crazy guitar maker or something... in several places.... That stuff used to be as common as cockroaches in a trailer park.
I tried the internet too... zippo....
Oh well, I guess I'll treat my 30 year old tube with a bit more respect now..
rk
www.ronkirn.com
Old April 25th, 2009, 09:59 PM   #37 (permalink)
rk
thought the stuff only came in white. Wasn't that the stuff on car hinges?
