#162 (permalink) |
Esquire'd mine and put a Gotoh bridge on it. Made a new pickguard as well.
[IMG] [/IMG][IMG] [/IMG]
I am the center of the universe and so are you.
#165 (permalink) | |
Well that's just great! Is there anyway you might be able to help a ding dong with a switch install? I have a CRL switch in the house, but when I took it apart last night, it was too much for my feeble mind to handle. droo |
#167 (permalink) | |
New CV owner and first post. A lot of information to digest on this forum. I have the same issue as you, a nut cut too low. Could you tell me exactly which TUSQ nut you used and if you got it directly from graphtec? They have two , one which has a top radius of 7 1/4 and another bigger one which has a 9 1/2 top radius and flat bottom. Is the nut slot on the CV flat or curved? Thanks Last edited by mercury6; February 16th, 2009 at 10:58 AM. |
#168 (permalink) | |
#169 (permalink) | |
Where to get the orange drops
http://www.smallbearelec.com/Categor...2C+Orange+Drop |
#170 (permalink) | |
http://www.graphtech.com/products.ht...9&CurrencyID=2 You could also use one of these, since the bottom is indeed flat. http://www.graphtech.com/products.ht...2&CurrencyID=2 Hopefully this helps. - Jay
"People assume that time is a strict progression of cause to effect, but 'actually' from a non-linear, non-subjective viewpoint - it's more like a big ball of wibbly-wobbly... time-y wimey... stuff." |
#171 (permalink) |
is it worth replacing the bridge and saddles on the CVT? seems to me (havent played one yet but from what i have been reading) that upgrading the bridge and saddles would definately do this guitar justice. which bridges have been used that are a direct retrofit? and what are the advantages/disadvantages to steel saddles vs. brass? i have looked at Callaham Vintage T Model bridge and wasnt sure if they bolted right on without having to drill new holes. or is it not worth it to replace the enitre bridge and just install new saddles?
i have read its great out of the box but the electronics are the weak link, and that some have had problems installng an aftermarket switch because the routed area under the switch plate isn't deep enough. has anyone found 3-way and 4-way switches that fit without having to route the area under the switchplate? |
#172 (permalink) |
bug music thx, I was looking at a Tusq job on my to do list -you've saved me time there. I am upgrading the tuners so I'll do a nut jobbie as the same time.
Regarding the tuner upgrade: Up thread the Wilkinson Vintage were mentioned - ordered some, wrong sort sent to me; no stock available. Next I have checked out the Fender Vintage style tuners (pn 0992040000). The Fender set do not drop in to the headstock holes and to use them will require reeming out the holes (and they look absolutely identical to the CV tuners anyway). Moving on to check the Gotoh Deluxe Vintage tuners: pricey and also appear to be american sized.
God Bless The United Estates of America. |
#173 (permalink) | ||
I put Callaham vintage on my CV -straight fit. I would go for a Glendale or Callaham bridge on any Tele, even CS, with compensated saddles. Quote:
#174 (permalink) | |
The bridge is actually a little thicker chunk of metal that the Genuine Fender bridge I have off a nashville deluxe tele. I simply added the $14 set of compensated brass saddles from stew mac, and it is AWESOME. You can drop big $$$ on a blingy bridge, but I think all you need is the saddles. I put in a genuine Fender 3 way with no routing required. Definitely worth upgrading the switches and jacks as I did on both my CV 50s tele and my CV 50s strat. The tele had full size alpha pots which are ok, but i'll probably put in some CTS solid shaft pots eventually. The strat had mini-pots and now has full size CTS pots. |
#177 (permalink) | |
I do intend to work on it though, it was one of my New Years resolutions. - Jay
#180 (permalink) |
They're AllParts Nickel Dome knobs. And, I used the little brass pot sleeves that enable you to use set-screw knobs on knurled split-post pots. (Make sure you slide them all the way down on the post, then install the knob over the sleeve).
They work terrific. The flat-top stock knobs looked a little out-of-place (to me) on a 50s-style Tele.
PJ "I don't know if it's art, but I like it." |
