#143 (permalink) | |
Remember to use the original CV bridge screws (metric) unless you want to re-thread the body for american screw threads.
God Bless The United Estates of America. |
#144 (permalink) |
Should have posted this question here...oops.
Given the poly finish, would the CV Tele body & neck be easy or difficult to lightly relic? I'm talking light, to the point that the new Road Worn Series look (on the body & esp the neck) would be considered going too far. Perhaps a look 1/2 way between a Closet Classic & RW treatment. Ideas & opinions welcome! |
#145 (permalink) | |
http://cgi.ebay.com/Fender-Telecaste...3A1%7C294%3A50 |
#146 (permalink) | |
"...it's just a wonderful sound..."- GE Smith |
#147 (permalink) | |
I'd put 2 small screws through the side of the cup, if that's the case. ![]() that big buck sticker reminds me of this: ![]()
....and That's When the Racoon Attacked My Leghttp://www.myspace.com/timebanditsberlin |
#148 (permalink) | |
first I thought that's no good, but I've learned to appreciate it. I did 2 gigs with the CV and you can actually dial in a sound and volume and it stays like that. To loosen the nut won't remedy it - I had to tighten the nut because the whole pot was moving. it didn't make any difference to the stiffness though.
#149 (permalink) | |
These are the ones I'm looking at: http://cgi.ebay.co.uk/ws/eBayISAPI.d...B:EOIBSA:UK:31 |
#150 (permalink) |
Well it says : **Fits American / USA and Mexican MIM instruments**
so I suppose those screws aren't metric.
#151 (permalink) |
As far as the pots being tight, I've had luck in the past loosening up solid shaft CTS pots by giving them a few slight taps on the top of the shaft (after removing the knobs) with a small ball peen hammer. However I've never attempted it with the split shaft Alpha pots like the CV has so attempt this at your own risk.
Also a question for the guys who've changed out the pickguards. I'm getting a lot of static off the stock pickguard too, did anyone else besides millhouse notice less static buildup with a real Fender replacement guard? - Jay
"People assume that time is a strict progression of cause to effect, but 'actually' from a non-linear, non-subjective viewpoint - it's more like a big ball of wibbly-wobbly... time-y wimey... stuff." |
#152 (permalink) | |
mmm jagermeister, funny, i have a bottle in the fridge right now but cant seem to come at it (something to do with numerous shots a few weeks back)...my CV experiences have been better than the jagers:) |
#153 (permalink) | |
#155 (permalink) |
Super Moderator
Finally got mine, mods on the way
I got my CV a couple of days ago. My immediate thought was "This guitar is so good I could start gigging it right away." So of course my very next thought was "So how can I modify it?"
I've already ordered a one-ply white guard as so many others have done. I also decided to replace the pickups; the stock pups are good, but I've been enamored of P90s lately. So I ordered a Rio Grande Dirty Harry for the neck, and I'm trying to decide between a couple of different Tele-sized P90ish bridge pickups. The good news is that this guitar just resonates and sustains for days. As most of you have already discovered, this guitar is waaaay beyond just "good for the money" -- it's just plain "GOOD!"
"I go online sometimes, but everyone's spelling is really bad. It's depressing." – Tara, from "Buffy the Vampire Slayer" "It was born at the junction of form and function." – Bill Kirchen, from "Hammer of the Honky-Tonk Gods" |
#156 (permalink) |
Mods make it even better!
I've put a DiMarzio Twang King in the bridge (the stock pup is too dull for my taste), Rockinger compensated saddles, a Fender 3-way switch and a 1 ply white guard on my CV Tele.
A surprisingly big improvement in overall resonation, vibration and sustain of the guitar was the removal of a little wooden shim in the neck pocket. That was totally unnecessary there and the improved body / neck contact really made a difference! Remember to adjust string height and intonation afterwards, also pickup heights.
No superstrats for me, thank you. I'll have a plain old plank instead. |
#157 (permalink) | |
#159 (permalink) | |
There was a thread around here about someone leaving a dryer sheet in the neck pickup cavity and wrapping it around the wires. I'm not sure if that would be a more permanent static solution, but it may keep the April Fresh smell longer. - Jay
#160 (permalink) |
Just a few mods to perfection
So, I finally got around to tweaking my CV. I installed a set of compensated saddles from Stew mac, an electrosocket, USA Switch, a big fat orange drop, some nut lube, new strings, and a single ply black guard.
The comp saddles from stew mac are really great. I actually eyeballed them to nearly perfect just based on where the old saddles were. A couple twists of a screwdriver, and I had perfect intonation across the board. The added tone was noticeable as well thanks to the solid brass I'm guessing. I was going to install some solid shaft CTS pots, but the box from MF didn't arrive in time, so I decided to see if I could make the alphas a little smoother. I sprayed a couple shots of contact cleaner in each one, and they are much better. Not as nice as the CTS pots in my CV strat, but pretty close. I installed a USA switch and connected the shielding in the neck p/up area to the ground in the control cavity. I installed a .047 orange drop on the tone pot, and moved the output from the tone to the middle lug on the volume pot (aka the 50s mod). The volume and tone controls are so much more usable now. It's really great. I used the nice shielded cable that came stock and installed a switchcraft jack and electrosocket. All of the static that I was getting before is now gone. I think it was mostly in the switch and jack. I did a quick polish on the frets, and then I put some nut lube on the saddles, the nut and the string tree and installed a fresh set of 9's and got down to playing. These mods while very inexpensive, made a huge difference in the tone and playability for me. I can't comment enough on the huge difference in the volume and tone controls. Before, they were almost useless, but I kept finding great new tones by rolling the tone back a little and then using the volume to dial up the gain, etc. A little midrange boost on the eq pedal really helps both these and the CV Strat pickups. I wasn't sure how I would like the .047 tone cap, but it suits these pickups really well. When dialed back about 50%, the tone is simply FAT. |
