| Home | Forum | Resources | T-Shirts & Etc | Music | Photos | Reviews | Classifieds | Register | FAQ | Search | Today's Posts | Mark Forums Read |
#41 (permalink) |
I changed the Gotoh split shafts on one Baja out for the Gotohs with the little white buttons, like the ones seen at the Creston Guitars website.
I've now got an aluminum compensated E-A saddle on 2 or 3 of them, and I have a bell bronze 5/16ths E-A compensated saddle on still another. Sounds a bit like brass, a bit like steel - not as mid rangey as the usual brass. People don't see it; they think it is brass. I've substituted 6-32 filistered slot head screws on all the intonation length screws on 5 so far (2 in Florida must wait til next trip) and I'm primarily using allen or hex head saddle height screws since I cannot get slotted height screws in stainless any shorter than 3/8ths inch. And I've installed Taipantone stainless thick neck plates with slotted stainless neck attachment screws for added tightening control on a couple. |
#42 (permalink) |
Parted together a mint blonde Baja body & neck and:
Guitars: '57 Strat, '68 ES 335, '72 Martin D28, '74 Jazz Bass, ESP Custom Strat, '04 LP DC Plus, '07 LP R0, Partocaster Amps: Fargen Blackbird 30, Peavey Classic 30, '65 Tremolux, Marshall AVT50 My 3D Artwork:http://www.andylackow.com |
#43 (permalink) |
MY MODDING:
- removed the S-1 switch - changed the 4-way to 3-way switch - Compensated Brass Saddles - put a ground wire from bridge to pot - changed to 50s wiring - changed Brigde Pickup, i didn't like the CS Broadcaster it sounded boring. First i tried a SD Quarter Pound but it was too muffled Now i ordered a overwound MudCat by LEOSOUNDS (handwound). Greets Last edited by Mr_Martin; December 9th, 2009 at 08:53 AM.. |
#44 (permalink) | |
I don't, I love the S1 switches on my Deluxe HSS and Baja. Never had issues with them |
#45 (permalink) |
I'm leaving mine totally stock. I, like the great neck and the added versatility of the S1 tones. All it needed was a little attention to the high-cut nut slots but, other than that, it was fine out of the box.
I might have the fingerboard de-glossed a bit at a later date. If it had come with a satin finished neck it would have been the perfect Telecaster for me. |
#46 (permalink) |
I have two, one Blonde, one Sand, so I've modded one of them.....
Sand With Bigsby F-stamped B5 kit. ![]() ![]() part of the crowd... ![]() Need to do new pics to add the AVRI52 and the Tuxedo 62ri MIJ. The work was done by a french luthier who has a great reputation and his work on all my guitars has been flawless thus far. I'm very happy with it. |
#47 (permalink) | |
Do they vary or were earlier models produced with the narrower spacing (mine is a 2008)? |
#48 (permalink) |
Since my last post here, I have replaced my chipped nut with another bone nut, twice I had to to it. The slot is oversize width, fortunately towards the head only, this means I have to use an oversize blank, the first one had a flaw in it and split, I'm none to happy with the second. Now the G buzzes a weird 'harmonic' from behind the nut, I guess it needs an extra tree.
I have also turned the control plate round, vol forwards, and replaced the vol pot with my preferred linear B250k for a better taper. That meant losing the S-1 and using a push-pull. The mod is reversible. Now I need a matching pair of knobs. My Baja'06 has the narrow 12th dots spacing.
#49 (permalink) |
Removed the S1 switch on my baja...
...very soon going to be replacing the neck pickup with a gibson mini humbucker! In time I hope to have the same wiring configuration (and pickups) as the brent mason valley arts series... I find it to be AMAZING... and like Brent (back in the day) I can only afford one guitar, but (try to) play a variety of styles, so i need the versatility! I am also changing the (white single ply) pickguard for a 3 ply 7 hole? pickguard in black, I just like the look of those better! Peace
"When the seagulls follow the trawler, it's because they think sardines will be thrown into the sea." - Eric Cantona |
#51 (permalink) | |
I do actually use the s1 switch on mine, not overly so, but for a few of the tunes we do I use it. |
#52 (permalink) |
I took mine in for a set up and to have the wiring checked--it was a bit too noisy when I got it, but it's very good now. Other than that, the only thing I did was add a set of Schaller strap locks.
#53 (permalink) |
Mine is in the middle of getting modded.
OC Duff Plankster and Big Boy set. .09 thickness white pickguard that won't bend new control plate new 4 way switch and pots (no s-1 switching) electrosocket jack RS Guitarworks knobs and saddles |
#54 (permalink) |
Here's the scoop with mine- I've yapped about it much elsewhere here before, but anyway...
When I got it it (used): S1 & 4-Way replaced with standard Tele business Pickups replaced with Vintage Noiseless Most of the finish sanded from the neck... Since then: Bridge Pickup replaced with O.C. Duff "Nancy", (very) slightly overwound. On my shelf waiting for me to get around to it: New bridgeplate (stock $13 Fender) that is going to an awesome tech here in KC to have the "lips" removed and toploader holes bored (so strings can go through the body- or not!) RS Steel compensated saddles Electrosocket jack cup Also, another Duff for the neck. Trying to decide which one I want, but I'm leaning toward the "Whiteguard". Thinking about a Callaham custom control plate too- gonna reverse everything, but think that moving the tone knob (which would be the center position when flipped) a little closer to the volume knob and away from the switch would be good for tone-knob wah, that way when using the neck pickup the switch tip wouldn't be in the way... I found this guitar was eh...okay when I got it, but the price was just too right. So far, the best "mod" I've done was just to adjust the trussrod. Now that the relief is set just right, this thing is pretty great. Can't wait to get it wrapped up! Then I can start (finally) getting my '76 sorted out... |
#55 (permalink) |
My mods are
took out the s1 and the 4 way switch added a 3 way switch and put in 250k pots took out both pups and replaced them with American standard tele pups changed the pickguard with a 3ply white (had to get a 8 screw instead if a 5) and put a bigsby on witch I love! |
#57 (permalink) |
I cannot see why anyone would change anything much ,it all works but ...who knows .its guilding a lily .I changed a jack socket as it was shorting ,put a parchement pickguard on instead of black.Mine is an LPB by the way and put in Wilkingson compensated saddle ,the only real mod you need as it actually does intonate better .If you dont like s-1 dont push the little button down or just put new knobs on without a button .I always open out nut slots with an exacto saw as most nuts are too tight on the top few strings but oddly it was fine until I changed the stock strings out and put on Rotosound .I think Fender got it about right first time out with the Baja.
#58 (permalink) |
Just to update, pretty well got my Baja sorted out, though I think I may swap the RS saddles for Rutters soon. Topload or string-through & lips removed from the bridgeplate, CS Nocaster neck pup, reverse controls, thin refin on the back of the neck where the joker I bought it from had sanded it...overall, I'm happy with it. It's close to what I want for it, think I can get it there with just a little more tweaking.
| New Bajas for 799.99 on MF - get 'em while you can | Stylemaster | Telecaster Discussion Forum | 13 | January 6th, 2010 01:17 PM |
| Are all Bajas really heavy? | degsycaster | Telecaster Discussion Forum | 26 | June 28th, 2008 10:43 AM |
| 'Swan Song' variant on late Classic Bajas | boris bubbanov | Telecaster Discussion Forum | 2 | January 1st, 2008 12:23 PM |
| $699 Bajas @ GC... | Frank_Kimball | Telecaster Discussion Forum | 2 | July 21st, 2007 10:25 AM |
| New Bajas Are Starting To Hit The Stores. | Mark Byrom | Telecaster Discussion Forum | 18 | September 29th, 2006 10:01 AM |
