fret maintenance
relatively new to the forum
Just wanted to see what your opinions are on cleaning frets and fretboards. I also own a MIM 70's stratocaster that is looking a little muddy on the frets due to my negligence! Thank you! |
| Sponsored Links |
I clean with rubbing alcohol, then afterwards give it a rub with lemon oil or linseed oil to keep the fingerboard from cracking or drying out.
The smoker you drink the player you get~Joe Walsh |
#6 (permalink) | |
Naptha - also known as lighter fluid - is a pretty mild solvent. It is sometimes used as a paint thinner for alkyd-base paints. It is not used as a thinner for lacquers. It could do something to a lacquer finish, but I would not expect any damage to a sound finish. If you have a true nitro-cellulose lacquer finish, try some little test areas first.
If you have a recent model it is probably finished with polyurethane - naptha will not affect this finish. winnie pooh said this: Quote:
Lemon oil is not really an oil made from lemons; it is a mineral solvent with some lemon-oil additives. It works great as a cleaner for fine finished wood (not just the rosewood fretboard) and leaves your rosewood fretboard smooth, sweet, and shiny. Most of that dries out in a day or two, but if you want to pamper your guitar, and make it play extra-sweet for an important gig or session, then I recommend a nice lemon-oil treatment. I wipe all my guitars down with lemon oil while I am changing strings - body, neck and everything; after 5 or 10 minutes I buff -dry with a clean soft polishing cloth. I clean my rosewood fretboards with automobile rubbing compound, rubbed in with a toothbrush. Then I wipe the compound off with a soft cloth and warm soapy water. Wipe dry with an old towel, then apply a liberal coat of lemon oil... let it sit for 10 minutes or so, then wipe off the excess. String it up with nice new strings, and you're ready to go! Your guitar will love this, and you will love the way your guitar looks and feels! |
+1 jhundt
naptha = lighter fluid white spirit (paint thinners) = OM1 = oil, mineral, no.1 (~SAE 0) er. 'lemon oil' is a degreasant, which may eventually remove the natural oils and dry out a rosewood fretboard. NB not for use on maple. You can feed a rosewood fretboard with a wood treatment oil. Rosewood being an oily wood might be best treated (~/2y) with an oil for an oily wood like teak oil (also an oily wood). Depends on how you like your fretboard, its quality and whether it shows any sign of splitting. Some like them very dry, me, I prefer them a little slick. My bottle of lemon oil says do not use on maple, I presume they think it might do something to the finish - but is it possible do dissolve a Fender poly-wassname finish (?) Other stuff for cleaning:- powdered pumice (bare wood only); iso-propyl alcohol (lens cleaner etc); furniture finish reviver (very effective - fine and mild version of cutting compound); various proprietry guitar cleaner/polishes; soap and water(!); sewing machine or light mineral oil (for metalwork); toothbrush and rags; elbow grease, not the Dremel (unless you like burn marks). |
