#123 (permalink) |
VENDOR
nope.... no chipping......
rk
www.ronkirn.com |
#124 (permalink) |
Why do you do them after? Or should I say why does every other build I've seen here do them first? I had a problem with my first build because too much lacquer had built up in the holes and I couldn't get the ferrules in, i tried to drill them but they chipped slightly.
I can certainly seeing the advantage as I would imagine that the ferrule just pops in. Once again, I'm very impressed. |
#125 (permalink) | |
VENDOR
rk
www.ronkirn.com |
#126 (permalink) |
VENDOR
Moving right along..... today was to be the finale... but when I opened the box "o parts, I see the wrong pots.... but I did get close....
installing the Fralin P 90's couldn't be easier.... a bit of firm foam beneath, and run in the two mounting screws.. ![]() Once that’s done.. I address the neck pocket…. I always make ‘em tight, so each has to be hand fit at this stage. I begin by removing the lacquer buildup along the edges with a small sanding block. ![]() once that’s done… I shape the corners for a tight fit…. This is before… ![]() I Dremel it into submission.. ![]() RK
www.ronkirn.com |
#127 (permalink) |
VENDOR
This is the fit after a bit of work..
![]() Now on to the bridge…. I use a 48” rule to indicate the path of the strings, this way there are no surprises when I string ‘er up.. It lines up perfectly with the neck and the string-through holes.. ![]() ![]() run the mounting screws in and here it is at this stage.. ![]() rk
www.ronkirn.com |
#128 (permalink) |
VENDOR
Now… I do this…..
![]() and check these. . . ![]() then place the Pickguard in position. ![]() Pant. . . pant…. This thing’s lookin’ good….. I mount the hardware and run in the pickguard screws…Tuesday the correct pots will be here and I’ll be finishing ‘er up.. in the mean time…. ![]() Ron Kirn
www.ronkirn.com |
#132 (permalink) |
Hubba hubba!
I am disappointed though that you are not installing the wiring through the f-holes.
#135 (permalink) | |
VENDOR
rk
www.ronkirn.com |
#138 (permalink) | |
VENDOR
You will have to have a rear access, no getting around it. Ron Kirn
www.ronkirn.com |
#139 (permalink) |
You win the prize Ron ..............This is the best build thread ever.
#140 (permalink) | |
Nope, I refuse to give in If I have to give in, which i won't Cheers dave by the way Ron, I love the way that the pen line on the binding came out! |
#141 (permalink) |
Scubs, good luck with stuffing those controls through the f-holes - with mini pots it might be easier like you said. If I recall correctly, part of the solution used by Gibson on their Supreme, which has no rear access plate, was to use an over-sized rectangular jack plate so they could fish the pots in from there (the other part of the equation was that the pickup routs opened up into the body chambers). I noticed on my ES-339 that they used the exposed-braid coax wire tacked to the backs of the pots with one wire running in a circle connecting all the pots. This tied them together and holds them roughly in position so they'd want to go back where they should be after you stuff them in the f-hole. When fishing controls into a hollowbody Gretsch, I used mini pots and a small strip of brass connecting the two pots (like a mini control plate only on the inside) to hold them together at the right spacing as I fished them inside. Oh, and lots of dental floss or fishing line and a pair of slender Kelly clamps.
Ron, anything unusual about the pots you're waiting for? full-pass? blender? dual ganged? unobtanium alloy?
#142 (permalink) | |
VENDOR
rk
www.ronkirn.com |
#143 (permalink) |
VENDOR
As I creep forward at light speed, (it's a black light),, the pots came in so now I'm trying a few different wiring schematics looking for a specific sound.
![]() ![]() Ron Kirn
www.ronkirn.com |
#145 (permalink) |
I thought I'd be able to do it but not I'm thinking that the capacitor between the two pots may stop me getting them in. Are there any wiring schematics where the cap doesn't go from pot to pot?
Guitar's looking sweet Ron, I really like those white speed knobs. Is that top Sycamore? |
#146 (permalink) | |
VENDOR
rk
www.ronkirn.com |
#148 (permalink) |
VENDOR
well all things come to an end....
![]() I got 'er wired up.... still has an issue to two... humm... but I cant figure out if it's due to the 1949 circuit, or ??? But I'll get that worked out and send 'er on her way..... She has the classic Jazz tone expected from a 60 year Archtop, but pull the tone knob, reverse the middle pup and is has the nasal sound Gerry was lookin' for.... Been an hoot.... Ron Kirn
www.ronkirn.com |
#150 (permalink) |
VENDOR
I'll do some real shots tomorrow... I just finished 'er tonight.
rk
www.ronkirn.com |
#153 (permalink) |
VENDOR
There is no pickup selector... the electronics are from the original 1949 Gibson ES-5.
The three by the F hole are separate volume controls, one for each pup. The forward knob is a tone control, but I added a push pull to reverse phase, to give a nasal tone when engaged. rk
www.ronkirn.com |
#156 (permalink) | |
#157 (permalink) |
Ron, is this one a keeper or is it a special build for some luckey person?
Lord, please give me compassion for the innocent that I see and help me protect and serve those that depend on me. |
#158 (permalink) |
Ron, is this one a keeper or is it a special build for some lucky person?
#159 (permalink) | ||
![]() Is Gerry gonna be the new owner? What a lucky guy!
Slowing down . . . to get faster |
#160 (permalink) |
VENDOR
She's done.... here is the finale'
![]() ![]() ![]() ![]() rk
www.ronkirn.com |
