#42 (permalink) | |
Who cares, does it matter? Match two different pup's in two places? They are different animals. I raise them to try "TRY" to match volume, but that's it.
Howdy Y'all, most of my stuff pertains to country music. my MySpace Music Hill Country Horseworks |
#43 (permalink) |
Oh, the answer to the question is still... no!
#44 (permalink) | |
They are slightly over wound PUPs FWIW. |
#45 (permalink) |
My Esquire is wired direct/vol/vol+tone so that last position is the only versatile one and I use that the most...My Tele I roll the vol and tone off a tad on the bridge and go full on both with the neck...My amp settings are something like treble-6 mid-10 bass-3 reverb-3 bright-off!
Yes!
"You released the ******* fury!" |
#48 (permalink) |
Necessary? That's rather subjective. But I use the tone knob on my Tele all the time, and on my Strat as well. I use the stock 250K/0.05mfd arrangement.
I should add that I do not play much rock, and use overdriven sounds only about 10% of the time; I'm just not very interested in those sounds. I tend to hear the instrument in a more "raw" fashion than most rock players as a result. On stage there is always a need for subtle changes to suit the moment. I set my amp up so that "full up" tone is pretty darn bright, then work down from there. I rarely, if ever, play the bridge PUP with the tone full up - usually about 1/3 down in order to balance with the rest. That arrangement gives me the on-the-fly versatility I like to make the mix sound right. I might use the tone control full up for fills and rhythm parts, then back it off for leads where the guitar is of course louder and more forward. It depends upon what is happening at the moment. Of course, I use the Tele tone knob for "wah" effects. In order for those to work right, the amp has to be set pretty bright. Since somebody asked, my amp settings (Fender BFDR, 1965) are usually Treble at 7 or 8, Bass at 3. I certainly don't want too much bottom end in the mix, that's just mud for me as a vocalist.
---------- Tech Geek and Sensitive Artiste String bender ordinare! |
#49 (permalink) |
I also like to do dual Swells once in a while, with a rubber band over the vol and tone pot knobs. This is a fun and neat effect on a Tele. You can swell the vol and tone simultaneously.
It sounds... well... kind of..... I just can't type it... |
#50 (permalink) |
I use the tone control at times during a performance. Sometimes I need to take some of the bite out of the treble. Sometimes I work the treble to get a "crying" sound out of a sustain. I know some guitarists greater than I'll ever be never touched the tone, but I do for specific sounds I'm after.
![]() Don't die with the music still in you! Psalm 150 |
#52 (permalink) |
So I'm missing out on sounding muffled?
http://www.myspace.com/otiskeithwatkins |
#54 (permalink) |
A tone pot is not necessary, but it can be for tonal modifications on the fly.
If I was playing a set of Slayer covers I would not necessarily need a tone knob on my guitar. If I were to play a set of Blues numbers I may like a tone knob. That's just me, I've owned guitars with and without them.
"Anyone can make the simple complicated. Creativity is making the complicated simple." Charles Mingus |
#56 (permalink) |
I may have actually come up with that one myself. ;)
Try different rotations of the pots when you put on the rubber band, use a wider heavier rubber band. I also have all my Tele controls reversed, so the pinky grab on the tone is perfect reach wise. Let me know what your result/impressions are. |
#58 (permalink) |
I think it is for me.
"Turn it up and it doesn't need any reverb." - Danny Gatton www.dannygatton.info Tiger Town Aces - Music That Bites Back In Redd we trust! Free Bill Kirchen! If lawyers are disbarred and clergymen defrocked, doesn't it follow that electricians can be delighted, musicians denoted, cowboys deranged, models deposed, tree surgeons debarked, and dry cleaners depressed? |
#59 (permalink) |
I use it. Big difference in "tone" between 1 and 10. Kind of like asking if treble is needed on an amp.
My Page http://kandmfarms.com |
#60 (permalink) |
I use alnico 2 bridge pickups (Dimarzio Area T currently) and alnico5 neck pickups so I have no problem going from one to the other.
I never touch my volume control other than to turn it right off for breaks or whatever, and I never touch the tone control either. I hate the mushy sound most 'tone' controls make. I just set the amp right and play, much the same as I would with an acoustic. If I want a different 'tone' I used the selector switch. The 3 options fill all my requirements. But having said that, a while back I put in an orange drop .015 capacitor...and a 500k tone pot...and now I find I can use the tone control (although usually I still don't). It makes relatively subtle differences over most of the sweep without it becoming muffled. |
#61 (permalink) |
Moderator
I hardly ever touch the tone control on my Tele (or my bass).
Heck, I've been playing electric guitar for about 35 years and only in the last 15 have I started using the volume knob! Cheers, Tim
http://www.moodswingers.org |
#63 (permalink) |
I used the tone control in the days when I used the bridge p/u-- a while back.
Didn't used the bridge p/u for a long while in 3 wildly different bands, took the p/u out and biffed the tone pot at the same time. Now I'm h/bucker in the neck position, single 500K volume pot straight to the output. Crybaby on the floor, small adjustments effected with my picking hand position. Never happier. Johnny. |
#64 (permalink) |
Dont use the tone contol at all... on my 72 ri I do use the 2 volumes tho... Would like to have a vol for each pup and no tone... thought that for ages but never got round to finding out if its poss or how to do it if it is
