Old July 5th, 2008, 05:47 PM   #1 (permalink)
gillibi's Avatar
Rewiring for just tone control on bridge pickup, not neck
I'd like to get a bit more presence out of my neck pickup and was wondering if there is a way to bypass the tone control on just the neck pickup, leaving it just for the bridge. Just trying to even out the two pickups tones. Please let me know if there is a way, thanks!!!
Strats, Teles, LPs, 335>Rangemaster clone, custom overdrive, Echoplex clone, Leslie clone>modded Fender combos
gillibi is offline   Reply With Quote
Old July 5th, 2008, 06:27 PM   #2 (permalink)
tjalla's Avatar
Yep... I do this mod often. Super simple... see the wire that goes from the tone pot to the vol pot? Unsolder it from the volume pot and resolder right where the bridge hot wire joins the switch.
Works a treat. Keep the neck PU nice and chimey, preset the bridge PU to the sweet spot - its almost 'set and forget'
The tone knob still works in the middle position, and IMO that's a good thing.
Good luck!
Trevor
tjalla is online now   Reply With Quote
Old July 5th, 2008, 06:31 PM   #3 (permalink)
i did the exact oppostite of this mod; tone on neck only, never the bridge. Tdowns posted a schematic for me to work off of in tele-tech. (thanks, terry)
http://www.tdpri.com/forum/tele-tech...-neck-pup.html
hope this helps.
"Kid, it takes a long time"-Danny Kalb to me in NYC, 1992
dijos is offline   Reply With Quote
Old July 6th, 2008, 12:23 AM   #4 (permalink)
tjalla's Avatar
hope this helps.
...interesting - going for a 'balanced' tele to a 'wide-range' tele... might have to try that sometime!
Old July 6th, 2008, 12:53 PM   #5 (permalink)
gillibi's Avatar
Thanks for all the help, it sounds great now!
Old July 6th, 2008, 01:10 PM   #6 (permalink)
TG
TG's Avatar
I wire my teles that way too.
Another idea for you...
If you replace the tone pot with a 500k one and change the capacitor to something like a .015 orange drop you might find the tone control to be much more user-friendly.
I tend to never use most guitars' tone controls because IMO it generally just turns a nice electric guitar sound to varying shades of muddy. The first few millimeters of turn is usable but after that...mush.
With the 500k pot and a smaller cap I find almost the entire sweep of the pot clear and usable. It's a slow and subtle change as you turn it, and the top end only gets cut right off at the end of the knob's turn.
Old July 6th, 2008, 01:44 PM   #7 (permalink)
tjalla's Avatar
Another cool idea to try - I've used smaller caps before, but not with a 500k. Thanks TG!
Old July 6th, 2008, 08:32 PM   #8 (permalink)
No tone control on the neck PU
I changed the Muddy-caster to no tone control on the neck PU and like it a lot. I realized that I usually have the tone control all the way up for the neck PU. I am surprised at how much more volume I get from the neck PU and how open and clear it sounds. I had to lower the neck PU a little to balance it with the bridge PU. Its a very nice setup.
Mark
kingofdogs1950 is offline   Reply With Quote
Old July 7th, 2008, 03:13 AM   #9 (permalink)
my am dlx has what i think they call the "delta tone" pot. this when cranked all the way open kind of locks into place and this is a bypass. this would give you the no load option on both your pups. when using the bridge pup, for the most part i back the volume and the tone down about 1/3 but for distortion i run the volume wide open and the tone wide open (to bypass the tone circut). also bypass the tone circut on the neck pup as well. kinda cool option
...took the tube out of the v1 spot and replaced it with a dilithium crystal (like on star trek)...
scoots is offline   Reply With Quote
