#2 (permalink) | |
Welcome BTW. Could you clarify that? Every Tele you've played? heard? the one(s) you have? Mine are chimey, and robust. except my 72 rewound neck PUP, which is less so, but not dark to my ears. Ciao |
The AV52 and Nocaster have dark neck pups because they use the vintage wiring that Leo devised before the existence of the electric bass. All of my other Teles sound fine...
It was born at the junction of form and function... |
#5 (permalink) | |
You either have a '52 RI, a CS '51 Nocaster, a '62 Custom Telecaster, a CS '63 Tele or a real vintage (pre-'67) Tele. If not, I guess you have a problem ... |
The neck PU's on the tele models Telemarkman points out are, but most others are warm and creamy. It may well be the model you have. Rewiring it to get a warmer tone isn't too difficult idf you're handy with a soldering iron.
If you get hung up on just guitar players, you've missed something.... Don't ever get to a point where you just gotta be a guitar player. You hear something, go try to get that note and sound as much like that as you can.-Buddy Guy |
If your Tele has modern wiring (not the 50s wiring with the cap that automatically makes the neck pickup sound bassy/dark), and it is still too dark, try a neck pickup with a cover made from German silve/silver nickel - the chromed brass cover on traditional neck pickups is largely responsible for swallowing a lot of treble frequencies; Tele neck pickups with silver nickel covers (like the Fender Nocaster CS, or the German made LeoSounds pickups) will sound much more open, trebly, transparent.
You can also simply remove that brass cover from your neck pickup to make it as open sounding as eg. Strat neck pickups - but then you should protect the coil from damage with eg. some tape or something... |
It's funny, but when I first saw this question, my thought was "relative to bridge pickups, [b]all[b] neck pickups sound [i]dark[i]."
What does "dark" even mean? Lower in volume? Less treble? Tone knob has no effect on it? Or that through a big muff pedal with the tone rolled off it sings "oooohhhh oooohhhh" on soloing on the 12th fret, sending icy chills through you? Compared to? The bridge pickup on the same guitar? (no doubt singing "ehhhh ehhhhh" through the aforementioned big muff) Or a second, different guitar, which frankly, I'm shocked you haven't told us about. :) Maybe all you need to do is raise the neck pickup relative to the bridge pickup. Or lower the bridge pickup and leave the neck pickup alone. If volume isn't the issue, maybe tilt it more toward the thinner strings or a bit more away from the thicker strings, as this would brighten things up - in a relative way. (Disclaimer: I do not advocate guitar relativism for the most part because it can be a slippery slope. The Telecaster is the benchmark - the base reference, if you will. The absolute against which all other guitars are referenced.) |
