Old June 5th, 2008, 10:43 AM   #1 (permalink)
Mighty Mite Finish question
I just got a couple Mighty Mite Tele necks to play with!
1 maple and 1 rosewood.
They are just the basic plain old neck from MM.
I cannot find any info on it, but does anyone know if these necks are
ready to be stained/colored, or do they have some sort of sealer on
them I need to sand off first before they will accept stain?
Thanks
Jason
Musicman1 is offline   Reply With Quote
Old June 5th, 2008, 10:53 AM   #2 (permalink)
Southern ILL's Avatar
Mine has a sealer.
Southern ILL is online now   Reply With Quote
Old June 5th, 2008, 10:55 AM   #3 (permalink)
So, does a "sealer" have to be sanded off to bare wood if I wanted to
stain a color into it?
Old June 5th, 2008, 10:57 AM   #4 (permalink)
mellecaster's Avatar
Probably a Vinyl sealer, but I wouldn't worry too much about that, cause I think you would be better off looks wise, by tinting your clear coat and not trying to stain bare Maple....JMO
Old June 5th, 2008, 11:02 AM   #5 (permalink)
I keep hearing both sides, even on this forum?
Color wood, then clear coat, or
tinting clear coat.
Anyway, back to the question.
If I do want to stain if properly, does the sealer have to be sanded off?
Thanks
Old June 5th, 2008, 11:04 AM   #6 (permalink)
tinting clear coat.
Thanks
Pretty much !...Stain prefers bare wood
Old June 5th, 2008, 11:12 AM   #7 (permalink)
Stain likey bare wood....if you want amber-tint your clear coat. all depends what you are going for.
Old June 5th, 2008, 10:02 PM   #8 (permalink)
You can always test a spot on the heel.
lonesomebill is offline   Reply With Quote
Old June 5th, 2008, 11:24 PM   #9 (permalink)
braderrick's Avatar
I personally could never get the wood to stain the correct shade I wanted, I have had much better luck with tinted laquer, just go easy on it and lightly fog it. You can always darken it but if you go too much you have to remove and start over. Plus you won't have to sand off the sealer.
braderrick is offline   Reply With Quote
Old June 6th, 2008, 04:22 AM   #10 (permalink)
shades's Avatar
I've used a maroon 3M hand scuff pad to take the edge off the MM factory seal finish. Seems to work well as a prep before staining. After some stain a coat of Tung Oil to seal and all is right with the world. Works for me, YMMV.
A.S.N.F.
shades is offline   Reply With Quote
