Old June 2nd, 2008, 10:02 PM   #1 (permalink)
Question on Tele Pickup Output and Movement
Hi,
I'm new to this forum. I just got my first telecaster, and it is a MIJ in very good condition. Close to perfect cosmetically, and the neck feels nice. As this is my first tele, I have some questions on the pickups in this one. Apparently it has 'TL-Vintage' pickups. When I compare the output to my strat (which has texas specials) or my PRS (with Dragons II set at single-coil), the output from the tele is lower than the Strat and the PRS (with amp at same volume). If the Strat and the PRS output's 4/4, the tele's is perhaps 2.5-3/4 compared. Is that to expect? I know the texas specials and the dragons are hotter.
The next question is that when I place a finger in the bridge picup above the low E-string and one below the high E-string, and alternate pushing the pickup in and out, it moves. It doesn't change the sound or make any noise. Just not used to this. Is that normal too or do I need to tighten up the two screws behind the PUP and the one in front?
I look forward to input and to continue using this forum. I am very happy with the tele so far, and getting those questions answered, will probably complete my satisfaction.
Cheers,
Chris
Chris F is offline   Reply With Quote
Old June 2nd, 2008, 10:28 PM   #2 (permalink)
Cole's Avatar
Hi Chris F...
Welcome to the forum. You have discovered that the weaker the pickup the more you must turn your amp up to match the relative volume to the guitars that have stronger pick ups. Welcome to the world of amps & guitars! Don't expect expect them to match in output volumes and it's not a good idea to adjust the height of the pick ups so they will have equal volume when plugged into your amp. You may not like the results.
In a gig situation, most of the time I compensate by cranking my amp high enough for my weakest pickup guitar and turn the guitar volume down for higher output guitars. The idea being you create an evenly matched global volume through the guitar instead of the amp. This is a place to start.
You notice that strat & HB pups are all 2 point height adjustments, however the tele bridge pup has a 3 point. Tightening the screws will change the pickup height. Like strat & HB pups there is a spring or rubber spacer tube to keep tension on the adjustment screws to keep it from vibrating loose. Chances are your pickup is where it needs to be... so you may want to leave it alone. The movement is considered normal.
Go here to make sure your pickup height is at factory specs:
Fender setup guide
Good luck... hope this helps!
~Cole
Cole's website
Cole's MySpace
"The only currency we have is influential communication."
Cole is offline   Reply With Quote
Old June 2nd, 2008, 11:04 PM   #3 (permalink)
Hi Cole,
thank you for your reply. I guess I just have to get used to it. I did suspect it, but it was good to have it confirmed. I have fallen in love with the Tele so much that I have a second one coming next week. I also picked that one up used, made in the US and in good condition.
Again, thanks Cole.
Cheers,
Chris
Old June 3rd, 2008, 02:01 PM   #4 (permalink)
Cole's Avatar
if you haven't discovered it already... there's no cure for your tele-itis son... and I don't think there's no such animal as a recovering tele-holic either! Fortunately it's a joyful bunch of folks here... stick around.
How 'bout some pics of that new tele eh?
~Cole
Cole's website
Cole's MySpace
Old June 3rd, 2008, 10:03 PM   #5 (permalink)
Here it is: 1996 Telecaster (50th Anniversary), Made in Japan. Rosewood neck, TL-Vintage pickups. Plays very nice:
[IMG][/IMG]
I also have a 1988 Fender Tele coming, cream blonde with white pickguard and maple neck. One Voodoo Hotwound and one Seymour Duncan Pickup.
They're GREAT!!
Old June 3rd, 2008, 10:08 PM   #6 (permalink)
Cole's Avatar
oh yeah! You got it bad!! Nice guitar!
~Cole
Cole's website
Cole's MySpace
Old June 4th, 2008, 03:54 AM   #7 (permalink)
woodman's Avatar
cranking your amp beats pickup output any day, in my world. no worries! and welcome!
BAND PAGES:
Old June 4th, 2008, 04:10 AM   #8 (permalink)
Mark Davis's Avatar
The pickup moves cause its mounted on springs.
Old June 6th, 2008, 03:44 PM   #9 (permalink)
Thanks for reply guys. Only regret I have: why didn't I get a Telecaster earlier
Old June 6th, 2008, 06:31 PM   #10 (permalink)
johnnylaw's Avatar
Welcome Chris. And listen to Woodman. I like lower output single coils with a cranked tube amp. Its a musical concoction- good dynamics. Helps to suck more tonal variety out of those fingers!
Hunker down and woodshed for a spell before drawing conclusions. Have fun!
Its not how long you make it, its how you make it long.
johnnylaw is offline   Reply With Quote
