Inspect my Tele's new neck, I got a wierd feeling...
Hello again guys.
Anywho, it arrived today. I took it outta the package and it looked okay from the front. No gaping holes of burn marks. Only 3 things could I find upon closer inspection of the front; 1. The nut was positioned a bit far to the right 2. there were a few scratches near the nut 3. the headstock was slightly longer than expected. here be pics... New Neck 019.jpgNew Neck 020.jpg Okay, so then I turn it over and took a gander. The neck looked fine, that was until my eyes caught the part where the "bolt-on" aspect comes from. Apparently whoever owned this neck before me DID NOT know how to drill and even follow the preset holes that were in the neck. That is if there were any. [EDIT] The truss rod adjustment nut is VERY hard to see. hmmm... A pic is worth a thousand words, so I'll add more in the next post Last edited by Lerb21; May 23rd, 2008 at 07:57 PM. |
| Sponsored Links |
Well ............it wasn't working originally as you well know. It's good you were able to correct it.
Jack's Disclaimer: When I say something.... always ask yourself ..... "What the hell does he know?" _ ![]() Guys - learn to disable the flash on your digital cameras. |
#5 (permalink) | |
New Neck 009.jpgNew Neck 011.jpg |
#7 (permalink) | |
And why would you expect to see the truss rod? The skunk stripe is there to COVER it up! Did you mean the truss rod adjustment nut? Won't that be at the headstock end if you can't see it at the base of the neck? Perhaps I'm missing something?...
. . ![]() . "Behind every argument is someone's ignorance." |
#8 (permalink) | |
From the looks of the skunk stripe, that should have the adjustment at the heel. That's very odd.
#10 (permalink) | |
#11 (permalink) | |
New Neck 006.jpg Kinda hard to see, but in side the nice little hole where the t-rod is inserted you can see the star shape (not really on the pic but with it in your hands) that you'd insert an allen wrench into. |
Well I was wrong on the heel adjustment. Don't see a lot of necks with skunk stripe and separate fingerboard.
So .............. looks like you just need to plug the holes in the heel and drill new mounting holes. I would probably drill an oversized hole 5/16 or 3/8 in. ........... glue in the appropriate hardwood dowel.............saw it flush and drill new holes. You could probably tap that nut from the side to dislodge it then reglue it so it's centered.
#14 (permalink) |
Forgive me if this has been covered, but what concerns me is not that your head is long, but that it is the wrong shape. Was this sold to you as a "Fender" or "Squier" neck...hope not.
"I'm still married to my first wife...and that's my first guitar...she don't talk back to me, she talks for me..." -Stevie ray Vaughan |
#15 (permalink) | |
It doesn't sound like it's warped or cracked.... just a couple of hours work and you got yourself a decent looking neck.
#16 (permalink) | |
The original neck/headstock is not Fender because it is longer than what Fender makes as well as it lacks the tele 'circle' up at the top. But with some sanding it'll start to look a bit more faithful, but not exact. |
