Old May 18th, 2008, 01:28 PM   #1 (permalink)
Help my DIY Relic
So I'm new here and have a BIG question on my tele. First off it's a mutt, the body and electronics are from a late 80's -early 90's Fernandes. Neck is a 94 StewMac that I stained and lacqued, as is the bridge(Stewmac) that I relicd also. My problem is saddle height!! Neck pocket is standard 5/8" and fits perfectly, bridge plate is 3/8" height and saddles are compensated, also sits perfectly. The saddle screws are way down to get a nice playable string height, but still I am not sure if this normal Can anyone help
Im attacthing my url myspace. In the pics part is about 20 pics of it, I would appriatiate any advice.
http://www.myspace.com/takeraparter
lego4040 is offline   Reply With Quote
Old May 18th, 2008, 01:36 PM   #2 (permalink)
aznrambo481's Avatar
I know your problem. you want to put a neck shim in. Put a piece of something thin (business card, thin pick, bits of cereal box) in the deep part of the neck pocket (closer to the bridge). This will angle the neck BACK, making it necessary for the saddles to be a bit higher. This can also help to keep intonation screws from loosening. I don't know about the stewmac bridges, but the cheap squier ones always come loose unless the saddles are placed higher to get a sharper string break. Hope this helps! The shim process is more or less trial and error, but not too difficult.
Check out my bands, and feel free to PM me comments on them!
The Eclectics (guitar/vocals)
SLIP (bass)
aznrambo481 is offline   Reply With Quote
Old May 18th, 2008, 01:39 PM   #3 (permalink)
Buckocaster51's Avatar
You might get a few more responses if you posted those pictures in a place that doesn't require a log-in.
Just saying...
But just a guess...you are probably going to have to put a credit card thickness shim under the back 1/2" or so of the neck in the neck pocket.
Hard to tell for sure though without easily accessible photos.
Oh, and while you're at it...how about some maracas?
BTW - Welcome to the TDPRI!
Old May 18th, 2008, 02:00 PM   #4 (permalink)
surfoverb's Avatar
Cool Jazzmaster!
I like to use a plastic shirt collar stay for a shim, just cut about an 1/4th of an inch off the pointy end and it'll be about the same size as a Fender shim. They're thin too so you can stack them.
Old May 18th, 2008, 02:17 PM   #5 (permalink)
I was thinking it have to go towards front, closer to headstock? So i pulled neck off and found that it had the original thin paper shim at end of heal(by bridge) i pulled it out and put in a med/light pick up front and tightened up, too thick now, I have to put bridge saddles all way down. This is a good sign I think, Im gonna put a business card thickness shim in front again and see what happens.
Old May 18th, 2008, 02:19 PM   #6 (permalink)
Sorry, your right, I forgot bout that. Ive never used this forum and wasnt sure of how I had to post pics. Will post a few asap
Old May 18th, 2008, 03:17 PM   #7 (permalink)
I put a new bus. card shim in front and that really helped. I'll set height with the raius guage and see if I can get better playing out of it
Old May 18th, 2008, 03:37 PM   #8 (permalink)
Is there an easy way to post pics? My pics are on photobucket and my space. That Jazzmaster is still not complete, I hung the chrome bridge and trem over muriactic acid overnite and got it really relic'd. I still havent figured out which way to got with the wiring either. I thought about selling it but cant decide on that either.
Old May 18th, 2008, 03:50 PM   #9 (permalink)
gonna try list pic list
[/IMG]
[/IMG]
[/IMG]
[/IMG]
Old May 18th, 2008, 03:51 PM   #10 (permalink)
F**** That didnt work, sorry guys
Old May 18th, 2008, 03:56 PM   #11 (permalink)
If this dont work I need a tutor
I didnt see attach file section
