Old May 18th, 2008, 01:12 AM   #1 (permalink)
Ironwolf's Avatar
Zodiac. Building a Tele based 12 string.
Late this afternoon, I set up the new planer and started plaining the top for the guitar.
The new Rigid planer is a rather hefty and solid machine.
The glued up top sheet really shows the blade marks from the table saw.
You can see how well the planer cleaned it up here. Final thickness is 7/32 of an inch.
I still have a 16"x24" piece of Black Limba (Korina) left from building the 'Caster SS, so If it doesn't have any flaws, I'll be using it for the body blank.
Oderint Dum Metuant
Ironwolf is offline   Reply With Quote
Old May 18th, 2008, 03:14 AM   #2 (permalink)
spook777's Avatar
Looks like the one I built...we must have good taste :)
On the note about flaws and voids...
Every figured flame top I've seen from AA to AAAAA look the same from piece to piece. Perfect grain, figure from left to right, same coloration...yawn...don't get me wrong if I could I'd build all mine this way, but this one is unique and could never be replicated. Pretty fancy guitars are flawless so customers won't complain...guitars with flaws and voids have character and are unique. Thats why I picked these two pieces of maple. Down by my control plate is a massive void, but I filled it and its just as smooth as the rest of the body after clear coating it.
Specs:
Alder core, figured maple back (found at home depot), walnut pinstripe, figured crotch maple + cocobolo + purpleheart top. Mighty Might Birdseye neck, Sperzel locking tuners, Wilkinson top loading bridge (chopped), Seymour Duncan JB wired full/split/out of phase, Indian rosewood control plate (headstock veneer from Stew Mac), rosewood pickup ring, custom cocobolo knobs from Brian Williams.
BTW I made this with a template Ron Kirn makes. I think he's on this forum.
spook777 is offline   Reply With Quote
Old May 18th, 2008, 07:39 AM   #3 (permalink)
jwells393's Avatar
Ah ............. so that's what the new Ridgids look like. I think the new ones have three cutters. Mine only has two.
Old May 18th, 2008, 10:23 PM   #4 (permalink)
Ironwolf's Avatar
Template and raw body.
I did some work today, I had a lot of other things to do. I did get the body template shaped and the bridge, humbucker and wing chamber positions drawn and/or sketched in. I used it to cut the body out and then rough sanded it. It currently stands at 5.6 lbs.
Oderint Dum Metuant
Old May 22nd, 2008, 10:10 PM   #5 (permalink)
Ironwolf's Avatar
Routed out the body.
This is a horribly out of focus shot, but it does show the body hollowed out. The weight has gone from 5.6lbs to 4.1 with the top sitting on it. once its glued up and the pickup and neck routes cut, it should come in just under 4lbs.
Oderint Dum Metuant
Old May 24th, 2008, 10:12 PM   #6 (permalink)
Ironwolf's Avatar
Next step.
Painted the chambers flat black, glued on the top, trimmed it to the body and routed the pickup positions. The weight is now 3.9lbs. I still need to clean up the f-hole binding. The whitish looking stuff in the control chamber is a reflection in a paint run.
Oderint Dum Metuant
Old May 26th, 2008, 07:50 PM   #7 (permalink)
Ironwolf's Avatar
More routing and sanding.
Routed the neckpocket to standard strat measurements for Warmoth's 12 string neck. Did a 3/8'' round over front and rear and quite a bit of sanding to even it all up.
A little more sanding by hand and it should be ready for grain filling and sanding sealer. Question: Dye the wood before sanding sealer or after the sealer has been applied and sanded off?
Oderint Dum Metuant
Old May 27th, 2008, 04:47 AM   #8 (permalink)
Telegazer's Avatar
It's already bleeding gobs and gobs of spiffy-ness, and the f-hole binding is a really nice addition...Keep up the good work!
Telegazer is offline   Reply With Quote
Old May 27th, 2008, 07:19 AM   #9 (permalink)
Elrond39's Avatar
That's a really cool and different body-shape you've gone for! It reminds me of several guitars at once, without really looking like any particular one of them. Looking forward to seeing this one when it's done.
Tangado haid! Leithio i philinn!
Hold your positions! Fire the arrows!
Elrond39 is offline   Reply With Quote
Old June 13th, 2008, 12:15 AM   #10 (permalink)
Ironwolf's Avatar
Body hardware installed.
This is an awful picture. The flash really hoses up the color; I'll have to do another shot outside, but it shows all the hardware mounted.
I've ordered a birds eye maple and rosewood neck and two sets of tuners from Warmoth. While waiting for them I have a lot more clear lacquer to apply.
Oderint Dum Metuant
Old June 27th, 2008, 09:24 PM   #11 (permalink)
Ironwolf's Avatar
Progress
The neck came in from Warmoth. I worked on the neck pocket template to get a nice fit then re-routed the neck pocket.
This is how it currently looks. I figure about 10 more coats of deft on the body then let it cure, and probably about the same on the neck, except what will be needed to seal in and level over the headstock decals. The temps here are running right at a hundred with sub-20% humidity, so I'm able to get 4 or 5 coats a day on when I'm home. Since I start a two week staycation this evening, I figure I should be able to buff and finish this puppy in about three weeks. Some times the heat is a good thing.
Oderint Dum Metuant
vB code is On
Forums Directory
