Traveling with a Tele: Is this safe to do?
I am going to Haiti for a year to work with the UN there. I dont wanna go thru the hassle with the airline guys with a gigbag and carry on stuff so I was thinking I would unscrew the neck of my 52RI Tele and put that and the body neatly wrapped in towels inside my hardshell suitcase along with my other stuffs in it.
Has anyone tried this? Would I pose any threat to my Tele? Is this recommended? Thanks |
| Sponsored Links |
Yes and it works great. If you do it a lot you may want to have inserts done. Don't forget to bring a screw driver!
www.bourbondynasty.com |
I did this on a quick trip to California..they did ask me to open and looked at it..but it was fine...much easier than checking it into luggage..much safer because only im handling it.. And the peace of mind knowing where it is at all times was priceless
I've done this for the last 6 or 7 years. My wife is a singer and we play a few gigs in the Caribbean every Feb. I took a Carvin 1x12 cab down a while back and left it therre - I bring a Crate Powerblock and the Tele.
Removing the neck works great. I've thought about installing inserts but haven't done so yet. |
What if the neck has been shimmed with something, does Fender ever do that?
It would suck to have a little piece of wood fall out and not be able to get it lined back up right, especially when you're out of the country. I've had a few experiences flying with guitars and it's never been a problem at all. The attendants either put it in the first class coat closet or behind the last row of seats.
Fender 52RI - Gibson SG Standard '77 Deluxe Reverb SunFace w/ Sundial - ProCo RAT - Fulltone GT-500 Keeley AD-9 - Boss CH-1 |
i've seen a lot of shimmed Fenders, but they were glued IIRC. doesn't seem like that would be a deal-breaker.
Truth is stranger than fact ... www.myspace.com/woodymitchellmusic BAND PAGES: www.myspace.com/stragglerswing (Stragglers - Western Swing) www.myspace.com/loafersgloryband (Loafers Glory - '70s country-rock) |
#9 (permalink) | |
The other day I saw a luggage-type bag for a trombone (IIRC) and I thought it was perfect size for a Tele with the neck off that would work as gate check. |
I do that all the time with my ASAT and 63 CS. If you travel a lot you'll have to do some work on the screw holes.
"I am Jack's total lack of surprise."http://www.thehighriders.com |
The coolest part about this vid is Keef goes right back to playing and the guitar is still in tune.
![]() éí 'aaníígÓÓ 'áhoot'é Would you mind holding this bag while we go through the custom shop????? Redd Volkaert is a Jedi Knight at one with the Force!!! |
#14 (permalink) |
I wouldn't be afraid to do that, going to California, Europe, Japan, Mexico City, Singapore, etc. but the chance of bringing it back home for Haiti is 50/50. Or less.
May I suggest the idea of buying a Squier Tele Standard and getting it set up about the way you like your guitars, use that while yer down there, and then make it a gift to someone there if it is still in your possession when you're scheduled to return. I understand things are 'real' down there.
Bubban0v |
#18 (permalink) |
I travel every couple of months, so I recently started doing this with a Squire mini strat, and take along a Micro cube. It all fits in a carry on.
Replace the screws with hex head screws so you can carry a small ratchet on the plane, they frown on screw drivers. In the future I'll drill and install threaded inserts if I wear the screw holes out. |
#19 (permalink) |
I did that once with a Washburn electric
I have had no trouble with electric guitars on planes ONLY when guitar is hardbody.....hard shell case...strings loosened....
this space intentionally left blank |
#20 (permalink) |
Plenty safe, and instead of inserts....
...just soak the threads in the neck screw holes with some superglue. They'll harden up and take a LARGE number of neck removals without giving you any issues. I've actually "restored" some semi-stripped neck screw holes with superglue this way.
Don't fill the hole with the glue, but use a toothpick, matchstick, etc to give the inner threads a good solid coating....the superglue will mostly penetrate the wood, and make it really nice and hard. Let it dry, and maybe soap the screws the first time you assemble it again. Don't get superglue on the guitar finish, glue your fingers together, splash it in your eye and glue your eyelids together, etc... George |
#22 (permalink) |
I think if you take it to Haiti it's gonna disappear.
'52RI, HW1 Texas Tele, EJ Strat, MIJ JM, Epi Casino (AlnicoV), Gibson '61 RI SG, Steinberger, Squier PBass (heavily modded) |
#23 (permalink) |
Where the screw holes are, you would glue in round metal threaded inserts, and you would now use flat-ended machine screws--not pointy wood screws--to attach the neck. This way, you're not stripping the wood using wood screws each time you remove and reinsert.
#24 (permalink) |
Thanks all for the replies so far. HMmmmm.....I am there for almost 18 months so I am thinking maybe buy a cheap electric at a guitar store there somewhere and leave it or gift it to someone when I come back. Maybe I'll just take my Pignose and the RC booster along.
#25 (permalink) |
I wouldn't count on too many guitar stores in Haiti either.
Best to bring a cheap Squier--nothing too fancy or shiny. It is a very poor country and probably not the safest place on the planet to go running around with a pimped out guitar at night. Per capita income is less than than a good tele--$400. And bring LOTS of strings, which may be like gold down there and a perfect gift for the players you will meet. |
