Old May 12th, 2008, 10:39 AM   #1 (permalink)
tele 5-way 3 pickup wiring Mod
I added a middle strat pickup to my tele with a standard 5-way switch (not the superswitch) using the Nashville tele wiring scheme. Is it possible to alter position #2 (2nd from the headstock end) from [neck+middle] to [neck+bridge]? I would like the others to remain the same if possible.
Thanks for any suggestions
Wayne
wags74 is offline   Reply With Quote
Old May 12th, 2008, 11:06 AM   #2 (permalink)
Right now, you probably have neck, neck+middle, middle, middle+bridge, and bridge. If you simply swap the bridge and middle pickup hot leads, on the switch, you will get neck, neck+bridge, bridge, bridge+middle, and middle. That is about the best you can do, with a non-superswitch.
Jim.Collins is offline   Reply With Quote
Old May 12th, 2008, 01:49 PM   #3 (permalink)
Sounds easy enough. Thats exactly what I'm looking for. Thanks for the tip!
vB code is On
Forums Directory
