Are we torqueing into
Basswood, Mahogany, Ash, Sen, Alder, or Poplar? I'd be willing to bet that the density of the wood varies enough to make it difficult to set a spec. But I did find that some mention of Torque specs can apply to a Vintique type set up where you are tightening a machine screw into an insert. I think most experienced assemblers trust hand tightening best. Anyone else?
torque
---0.F.--- |
Torque..
This is easy... you tighten em enough to hold the neck on...
If it's floppin' around.... they're too lose, and if the wood's crushed, you tightened 'em too tight... Actually it don;t much matter. If after you get it tightened and reassembled and your sound isn't good, it's probably because you need more practice. Ron Kinr |
Stupid answer maybe....but
Once you get the torque driver, test the torque on a new 52RI, Fender must have set tolerances and that should give you what you want.
All those who believe in psycho-kinesis, raise my hand ! |
#8 (permalink) | |
http://www.brianvanderark.com/ |
Let us know.
There is probably a good deal of distance between "tight enough" and "stripped." All I know is that if I put my Mikata drill on "3" with a charged battery it gets em nice and tight but doesn't strip em. I'd say that once you get em "tight" you don't change the angle much with a bit more torque. But it would be nice to know the correct torque, and it would be a good reason to go out and buy a new tool - "But Shirl, you dont want me to overtighten those neck screws, do you? Peds says it has to be exactly 23.7 ft-lbs of torque. I could ruin the guitar!"
