#81 (permalink) | |
I'd have to get some ash to see how much harder that would be to bend but the rosewood worked fine. |
#83 (permalink) |
Bruce...I'm not much of a woodworker, but I assumed you would want to profile the "fix-piece" so it's pre-formed. You know, cut the shape you want on a bandsaw. Am I way off base?
PJ "I don't know if it's art, but I like it." |
#86 (permalink) | |
Yeah, maybe. That's one idea. If my idea about bending a stip around the perimeter won't work I'm thinking along the same lines as jwells and colt have said. Probably make some templates to route the edges and use them to cut the repair peices as well. Sand the top, back and sides back to flush and route the edge like it's supposed to be. |
#87 (permalink) |
If you take the entire profile of the guitar down to meet the extra radius you put on there, then trace where you are, and profile the
add-on piece, it should match very closely, no? Then, use a 60s Tele template to re-profile the body? That's where I thought you might go with this project. Which is why I thought some shops who build guitars might be able to make "quick" work of something like this, since they have those templates to cut blanks, which would be the secondary part of he job. Then, of course, the edge radius.
#88 (permalink) |
I've got a stripped '66 that was refinned by a non pro. I've toyed with the idea of getting it refinned properly, but I've decided to leave it be. I've had the guitar for 25 years and futzing with the finish would disrupt that.
If you do decide to do something with yours I'd think in terms of a relatively conservative, professional resoration on the body. I'd have someone fill the routes properly, but I'd leave the radiused edges intact. And then I'd have someone like Mark Jenny do a nice relic'd refinish. If you're asking our advice here, I would respectfully suggest that he'll so much better work than you at a moderate cost, especially given the value of the guitar. FWIW, the guitar is valuable, but not insanely so. You see mid 60s refin teles with issues for $3-$4K on e-bay. best Allen |
#89 (permalink) | |
I hadn't thoought about the body template. But it just occured to me - I stripped the guitar twice and the previous owner took it down at least once. Wonder how much wood is missing? If I'm going to do all of this work I want it to turn out right. I'm not concerned about making the templates. I just spent about 5 or 6 hours over the last week or so making templates of the neck on the 66. I used them to start cutting a rosewood neck I'm building. |
#90 (permalink) |
Hey, Bruce, if you stay tuned-in to your thread, I'm sure somebody will come forward with the best approach.
I keep thinking about the scrap that's left when you cut a Tele body out of a rectangular piece of wood. Isn't that a similar shaped piece you'd want to drop your body into, then re-cut it?
#93 (permalink) |
Hi Ron. Sweet Tele! Thanks for encouragement but believe me I don’t need any. I’m fired up for this project! I just have to figure out which way to I’m going.
Does your guitar have smooth or threaded saddles? Are they original? |
#95 (permalink) | |
#96 (permalink) | |
I need to see how much this method would fix first and see if I can even bend the ash strips. I've not tried to bend any ash. I also don't know if this method would be any easier or better than what you and Jwells are suggesting. |
#97 (permalink) |
[quote=Ron Garson;1221896]The saddles are threaded ones, and rather tarnished. The neck date is March '66.
I have the bridge that came on my guitar but it has solid saddles. Jwells said that his 66 has threaded saddles too. I wonder if mine were changed before I got the guitar. Have you ever seen a 66 with solid saddles? I'm not real concerned with this small detail. I'm just curious now. |
#98 (permalink) |
According to Duchossoir, the threaded saddles were used from late 1958 until early 1968. At that time the threaded saddle were replaced with grooved steel saddles. Earlier steel saddles from the '50s did not have the grooves.
I went back and see that your saddles don't have the grooves. I suppose there's always the possibility that a Fender assembler came across an old set of saddles in the back of the drawer and put them in. ...... ![]() |
#100 (permalink) | |
I'll have to get up with him and pick his brain a little. |
#101 (permalink) | |
1950 smooth chrome plated steel 1950-54 brass (several variations) 1954-58 smooth chrome plated steel (two variations, 45 & 90 degree angles) 1958-68 threaded chrome plated steel (first fine threaded, later coarse threaded) 1968-82 slotted stainless steel |
#104 (permalink) | |
I contacted Mark Jenny. Couldn’t tell from his site for sure but he said he only does finishes. I also started searching for some ash yesterday. Just didn’t have much time. I figure if I don’t repair the guitar myself I’ll use the wood for another project. I checked Stew Mac and LMII. Anyone care to provide another good source? |
#105 (permalink) |
I talk to this guy at the east coast guitar shows every year. I know he does some nice restoration finishes, but not sure about bodywork. But, you could give him a call:
Jack's Guitars Finishes 89 W. Gensee Street Baldwinsville, NY 13027 315.638.0926
