62 Custom reissue
Hello all, I'm a long time lurker. Finally decided to join the board.
I just recently bought me a beautiful ocean turquoise 62 Custom reissue. I haven't taken the neck off to verify the date, but it's believed to be around an 02. It's basically new with no scratches and all the case candy, and no fret wear. I have a question: When I switch to the neck pickup, It is very very low. The middle position and and bridge position sounds great. Is this normal for a 62 reissue? |
I hate the "vintage" wiring. Kudos to Fender for making it period correct, but it's very limiting compared to modern wirring. I'm sure some like it, but it seems the majority prefer the more modern wirring.
Sorry, not the real Ed Bickert. Just a fan. |
#5 (permalink) | |
Or do you mean low in output level (volume)? If the pickup is set too far away from the strings, that could cause some lower output. So if that's the problem try adjusting pickup height closer to the strings and see if that helps. |
#7 (permalink) | |
#10 (permalink) | |
Great bluesy tones out of my AV'62RI p/ups. ![]() Add a tiny bit of dirt and just heaven. And welcome aboard!!!!
Gear List |
#13 (permalink) | |
If you are indeed a "long time lurker", then you will know that it is customary for one to provide pics of one's Telecasters, especially when it sounds as tasty as yours does.... Don't you have a camera? |
#14 (permalink) |
Hi Telecustom, welcome to the board.
As you will know, the USA built 62 and 52 ri's are amongst the most respected models amongst the TDPRI community. BUT, (and this is just my personal opinion) unless you actually *like* the very bassy muddy neck pickup sound of the "old style" vintage wiring, its really daft not to re-wire to modern wiring, and provide yourself with easy access to one of the Tele's most glorious voicings, - both pickups together in the middle position. In case you are wondering about propriety of doing this, Fender actually provide a kit with which to do this with new 62 and 52 ri's, so they are actually encouraging you, and facilitating you, to do it. Its an easy job to do yourself if you can handle a soldering iron, and if you don't have the conversion kit you can do it with just a short piece of wire, as it just involves a few wire moves and the removal of the capacitor on the tone pot. You are invited also to change the other capacitor between the tone and volume pot from .05 mf to .022, (er, might be a decimal point out there) but if you don't have the .022 to hand, it makes not a lot of difference, and many people prefer the .05 cap anyway. I did it on my own 62, and it has improved an already great guitar. But, as I said, if you actually like the sound of the old wiring................ Rick J
"If you want to know what an electric guitar is supposed to sound like, just listen to this." - British DJ John Peel introducing a Roy Buchanan track on BBC radio in the late 60's. |
It might be best if I just leave the wiring the way it is, and keep it unique. If I feel in the mood for a different sound I can grab one of my other Tele's.
This 62 RI is definetely my favorite Tele. I'm partial to the "C" neck also. |
#17 (permalink) |
I switched my MIA '62ri to modern wiring and have never looked back.
I love the sound of that neck pickup, it has an airy acoustic quality to my ears. If only the bridge pickup sounded as good.
"I'm a maestro, I'm a maestro," Taj Mahal, 8/20/05. |
#18 (permalink) |
OK, if you want to leave the wiring vintage style, so be it. The two pickups together sound can still be got by carefully placing the switch between the middle (neck on its own) and the bridge position. Not easy to get on the fly, but available all the same for either a whole song, or for recording etc.
Now lets see those pics! Rick J
