Help please: Acoustic strings on electric
Hi!
I love the sound of phosphor bronze strings, and would like to put some on my tele, thing is, will the extra tension damage the neck, i would have thought so, but then i remembered that SRV played with 0.16's any suggestions? Thanks Joe
If you're not careful, It'll stick to your cheeks, and You'll smell like a native, For a couple of weeks In France |
| Sponsored Links |
SRV played with .013s tuned down. But I was told acoustic strings might not pick up on the single coil magnets and transfer the vibrations to sound as well unless you used nickel strings.
You didn't mention the gauge of the strings you want to use. They make phosphor bronze acoustic strings down to 10's, so there isn't much difference there. I don't think even 12's or 13's would damage the neck. You won't get the phosphor bronze sound through your amp, though. The pickups will "pick up" the bronze strings because they bronze is wound over a steel core, but I doubt they will sound even close to good. Try it, all you have to loose is 6 or 7 dollars for a set of strings!
You may want to try DR Zebras - they are a mixed string made for acoustic electrics. I use them on my J-160E and they play and sound great - gives a great Beatles 'I Feel Fine' feedback. Every other coil is nickel-plated steel, every other coil is phosphor bronze and they get 'picked up' by an electric pickup.
DR Zebras |
I like to use D'Aquisto Tony Rice strings on my flattops...now just because I like to use them doesn't mean that I always do...anyway...I have been using them on a Samick Gibson L-5 copy and they play and sound superbly.
I think I have tried phosphor bronze strings on electrics and took them off almost immediately. There must not be enough steel core there to tickle the magnets enough. Or something like that. I should edit this to add that the D'Aquisto Tony Rice strings ARE not phosphor bronze...or any type of bronze. They are very much steel or nickel appearing. Nice silver appearance.
"If you can't say something nice... don't say nothing at all." - Thumper the Rabbit "An awfully lot of time can be wasted waiting for the right time." - Gunsmoke's Doc Adams Last edited by Buckocaster51; April 19th, 2008 at 11:40 AM. |
upon further reflection, i don't think i will, a few bucks is all i have at the moment, and have no means of getting more money, so i think should just play it safe and buy Ernie Balls, but i'll buy a heavier gauge
Plain and simple: acoustic strings do NOT use magnetic material in the windings. Bronze wrapped acoustic strings will sound VERY weak through a magnetic pickup on a Tele.
The magnetic pickups used on acoustic guitars (e.g., Sunrise, Fishman Rare Earth, etc.) are generally voiced to greatly emphasize the wound strings over the plain strings in order to overcome this difference. Using "acoustic" gauges such as .012 - .053 (lights) or .013 - .056 (medium) is probably fine, but do it using nickel wound strings. Don't forget - what we call "slinky" strings for electrics didn't appear on the market until the 1960s. When Teles and Strats were first sold, everybody played with these "heavy" gauges, no different than acoustic gauges. So the Telecaster can take the tension. We can thank James Burton for figuring out the whole skinny string business on solid body guitars.
---------- Tech Geek and Sensitive Artiste String bender ordinare! |
#16 (permalink) |
To quote bradpdx: "Plain and simple: acoustic strings do NOT use magnetic material in the windings. Bronze wrapped acoustic strings will sound VERY weak through a magnetic pickup on a Tele."
I found this out to my cost many, many years ago. |
